venus-os:mfd-raymarine
venus-os:mfd-raymarine [2020-03-02 21:28] – [1. Introduction] mvader | venus-os:mfd-raymarine [2020-03-26 17:05] – [1. Introduction] mvader | ||
+ | This document explains how to connect to Raymarine MFDs using an Ethernet connection. | ||
The integration technology used is called [[http:// | The integration technology used is called [[http:// | ||
+ | TThere is also another way to connect, which by NMEA2000. See the [[https:// | ||
Line 22: | Line 24: | ||
* A80513 - RayNet male to RJ45 adaptor cable | * A80513 - RayNet male to RJ45 adaptor cable | ||
+ | Connecting a Axiom MFD to a network router lead ls to IP address conflicts, due to the integrated DHCP server. | ||
+ | To connect the [[https:// | ||
On the Victron GX Device, go to Settings → Services, and there enable both MQTT on LAN (SSL) and MQTT on LAN (Plaintext). | On the Victron GX Device, go to Settings → Services, and there enable both MQTT on LAN (SSL) and MQTT on LAN (Plaintext). | ||
Line 28: | Line 33: | ||
No other settings, such as IP addresses or similar are required, since the Axiom MFDs have an integrated DHCP server. | No other settings, such as IP addresses or similar are required, since the Axiom MFDs have an integrated DHCP server. | ||
===== 5. Configuring Multiple Battery Measurements ===== | ===== 5. Configuring Multiple Battery Measurements ===== | ||
