venus-os:mfd-raymarine
venus-os:mfd-raymarine [2020-02-25 08:45] – [4. Configuration] mbosma | venus-os:mfd-raymarine [2020-06-11 17:30] – [4. Configuration] mbosma | ||
- | The integration technology used is called [[http:// | + | This document explains how to connect to Raymarine MFDs using an Ethernet connection. |
+ | The integration technology used is called [[http:// | ||
Line 22: | Line 26: | ||
* A80513 - RayNet male to RJ45 adaptor cable | * A80513 - RayNet male to RJ45 adaptor cable | ||
+ | Connecting a Axiom MFD to a network router lead ls to IP address conflicts, due to the integrated DHCP server. | ||
+ | To connect the [[https:// | ||
- | On the Victron GX Device, go to Settings → Services, and there enable both MQTT on LAN (SSL) and MQTT on LAN (Plaintext). | + | On the Victron GX Device, go to //Settings → Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)//. |
- | Next, go to Settings → System Setup → Scroll to the bottom → Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. | + | Next, go to //Settings → System Setup → Scroll to the bottom → Marine MFD App configuration// |
- | No other settings, such as IP addresses or similar are required, since the Axiom MFDs have an integrated DHCP server. | + | {{: |
+ | No other settings, such as IP addresses or similar are required, since the Axiom MFDs have an integrated DHCP server. | ||
===== 5. Configuring Multiple Battery Measurements ===== | ===== 5. Configuring Multiple Battery Measurements ===== | ||
