venus-os:mfd-raymarine
venus-os:mfd-raymarine [2019-11-13 11:19] – mbosma | venus-os:mfd-raymarine [2023-06-22 19:32] (current) – Removed and linked to corresponding GX manual chapter sloges | ||
====== Raymarine MFD Integration ====== | ====== Raymarine MFD Integration ====== | ||
- | This manual is still being actively developed. | + | https://www.victronenergy.com/media/pg/Cerbo_GX/en/marine-mfd-integration-by-app.html#UUID-906e773b-f29c-2b77-56a8-d9ade87cc418 |
- | The integration technology used is called [[http://www.raymarine.com/multifunction-displays/lighthouse3/lighthouse-apps.html|LightHouse Apps]]. | + | |
- | The MFD integration is compatible with the Axiom, Axiom Pro and Axiom XL MFDs running on LightHouse 3. The eS & gS Series multifunction displays which have been upgraded to LightHouse 3 are **not** compatible. | + | |
- | Raymarine MFDs need at least LightHouse v3.11 for compatibility. | + | |
- | The MFD needs to be connected to the [[https://www.victronenergy.com/ | + | |
- | The RayNet adapters can be purchased from Raymarine: | + | |
- | * A62360 | + | |
- | * A80151 - RayNet (F) to RJ45 (M) - 3m | + | |
- | * A80159 - RayNet (F) to RJ45 (M) - 10m | + | |
- | * A80247 - RayNet (F) to RJ45 (F) Adapter | + | |
- | * A80513 - RayNet male to RJ45 adaptor cable | + | |
- | On the Victron GX Device, go to Settings → Services, and there enable MQTT. | + | |
- | Next, go to Settings → System Setup → Scroll to the bottom → Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. | + | |
- | No other settings, such as IP addresses or similar are required, since the Axiom MFDs have an integrated DHCP server. | + | |
- | {{youtube> | + | |
- | ===== 6. Step by Step ===== | + | |
- | {{:venus-os: | + | |
