venus-os:mfd-navico
venus-os:mfd-navico [2019-03-18 22:56] – [4. Configuration] mvadervenus-os:mfd-navico [2023-06-22 17:30] (current) – Removed and linked to corresponding GX manual chapter sloges
 ====== Navico MFD Integration ====== ====== Navico MFD Integration ======
-===== 1. Introduction ===== +Moved to: https://www.victronenergy.com/media/pg/Cerbo_GX/en/marine-mfd-integration-by-app.html#UUID-d5fa693e-1c4b-ec20-be20-e0baf8803e6e
-Navico is the overall brand behind the B&G, Simrad and Lowrance MFDs. +
-===== 2. Compatibility ===== +
-{{:venus-os:navico_compatibility.png?nolink | }} +
-===== 3. Wiring ===== +
-The Navico device needs to be connected to the Venus-device using Ethernet. Its not possible to connect over WiFi. For the ethernet connection, a Navico adapter is required: +
-  * ETHADAPT-2M 127-56 +
-===== 4. Configuration ===== +
-==== Venus-device settings ==== +
-   - Go to Settings -> Services, and there enable MQTT. +
-   - Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. +
-==== Networking ==== +
-No settings are necessary. The Venus-device and the Navico devices connect to each other using a technology called linklocal addressing. +
-It is possible to connect the a router to the same LAN; and that way provide for internet access. +
-===== 5. Usage ===== +
-TBD add screenshots and so forth.+
venus-os/mfd-navico.1552949765.txt.gz · Last modified: by mvader
