venus-os:mfd-navico
venus-os:mfd-navico [2020-06-11 17:26] – [4. Configuration] mbosma | venus-os:mfd-navico [2020-06-25 10:52] – [4. Configuration] mbosma | ||
Line 45: | Line 45: | ||
No other settings, such as IP addresses or similar are required. The [[venus-os: | No other settings, such as IP addresses or similar are required. The [[venus-os: | ||
- | It is possible to connect the a router to the same LAN; and that way connect the GX Device to the internet. | + | It is possible to connect the a router to the same LAN; and that way connect the GX Device to the internet. The GX device can also be connected to the internet via Wi-Fi or with a [[https:// |
+ | Note that the [[https:// | ||
===== 5. Configuring Multiple Battery Monitors ===== | ===== 5. Configuring Multiple Battery Monitors ===== | ||
Line 60: | Line 62: | ||
- | ===== 7. Troubleshooting ===== | + | ===== 7. NMEA 2000 ===== |
+ | The MFD can also be connected to the GX device using NMEA 2000, see [[https:// | ||
+ | The MFD can be configured easily to display the data from the GX device. There is no need to change any instance.\\ | ||
+ | To setup the data sources on the MFD, go to //Settings > Network > Sources > Advanced...// | ||
+ | * 127506 - DC Detailed Status | ||
+ | * 127507 - Charger Status | ||
+ | * 127508 - Battery Status | ||
+ | * 127509 - Inverter Status | ||
+ | * J1939 AC PGNs | ||
+ | ===== 8. Troubleshooting ===== | ||
Q1: The MFD page shows outdated information or shows the connection issue page, but the GX device is running and connected and the Victron icon is present on the home page.\\ | Q1: The MFD page shows outdated information or shows the connection issue page, but the GX device is running and connected and the Victron icon is present on the home page.\\ |
