venus-os:mfd-navico
venus-os:mfd-navico [2020-05-01 11:10] – [1. Introduction] mvader | venus-os:mfd-navico [2020-06-11 17:26] – [4. Configuration] mbosma | ||
Line 34: | Line 34: | ||
+ | On the Victron GX Device, go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// | ||
- | On the Victron GX Device, go to Settings | + | {{:venus-os: |
- | Next, go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. | + | Next, go to //Settings -> System Setup -> Scroll to the bottom -> Marine MFD App configuration// |
No other settings, such as IP addresses or similar are required. The [[venus-os: | No other settings, such as IP addresses or similar are required. The [[venus-os: |
