venus-os:mfd-navico
venus-os:mfd-navico [2019-04-30 00:17] – [2. Compatibility] mvader | venus-os:mfd-navico [2022-06-01 08:41] – [2. Compatibility] mbosma | ||
Line 4: | Line 4: | ||
Navico is the overall brand behind the B&G, Simrad and Lowrance MFDs. | Navico is the overall brand behind the B&G, Simrad and Lowrance MFDs. | ||
+ | This document explains how to connect to Navico MFDs using an Ethernet connection. | ||
Line 9: | Line 15: | ||
Navico compatible hardware: | Navico compatible hardware: | ||
- | Note that this feature also works on the NSS EVO2. But only limited. And its not officially supported and also there will be no new software releases made by either Victron nor Navico to fix any issues that may arise. In other words, it is not a supported configuration by Navico but the consumer can feel free to use it (if they contact Navico or Victron service, our team will tell them it is not a supported configuration). More testing and user feedback will have to show what does and what does not work on the EVO2. | + | Note that this feature also works on the Simrad |
+ | At this moment it is not possible to control the Victron MFD App other than the touchscreen.\\ | ||
+ | This means that you cannot use | ||
+ | * Local controls, i.e. WheelKey and arrow keys | ||
+ | * Simrad OP50 | ||
+ | * B&G ZC2 | ||
===== 3. Wiring ===== | ===== 3. Wiring ===== | ||
- | The Navico device needs to be connected to the Venus-device using Ethernet. Its not possible to connect over WiFi. For the ethernet connection, a Navico adapter is required: | + | The Navico device needs to be connected to the [[venus-os: |
* ETHADAPT-2M 127-56 | * ETHADAPT-2M 127-56 | ||
* CABLE RJ45M-5F ETH ADPTR NONWATERPRF | * CABLE RJ45M-5F ETH ADPTR NONWATERPRF | ||
- | ==== Venus-device settings | + | On the Victron GX Device, go to //Settings -> Services//, and there enable both //MQTT on LAN (SSL)// and //MQTT on LAN (Plaintext)// |
+ | Next, go to //Menu → Settings → System Setup → Battery Measurements// | ||
+ | No other settings, such as IP addresses or similar are required. The [[venus-os: | ||
+ | It is possible to connect the a router to the same LAN; and that way connect the GX Device to the internet. The GX device can also be connected to the internet via Wi-Fi or with a [[https:// | ||
+ | Note that the [[https:// | ||
+ | ===== 5. Configuring Multiple Battery Monitors ===== | ||
+ | {{youtube> | ||
+ | ===== 6. Step by step ===== | ||
+ | {{:venus-os: | ||
- | - Go to Settings -> Services, and there enable MQTT. | + | The MFD can also be connected |
- | - Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD; and by what name. | + | |
- | ==== Networking ==== | + | The MFD can be configured easily to display the data from the GX device. There is no need to change any instance.\\ |
- | No settings are necessary. | + | To setup the data sources on the MFD, go to //Settings > Network > Sources > Advanced...// |
- | It is possible to connect the a router | + | The following Victron related PGNs are supported: |
+ | * 127507 - Charger Status | ||
+ | * 127508 - Battery Status; Voltage, Current | ||
+ | * 127509 - Inverter Status | ||
+ | * J1939 AC PGNs | ||
+ | ===== 8. Troubleshooting ===== | ||
- | ===== 5. Usage ===== | + | Q1: The MFD page shows outdated information or shows the connection issue page, but the GX device is running and connected and the Victron icon is present on the home page.\\ |
+ | A1: Try reloading the page by pressing the menu on the top right corner and select HOME. | ||
- | TBD add screenshots and so forth. | + | {{: |
