venus-os:mfd-navico
venus-os:mfd-navico [2019-03-18 23:56] – [4. Configuration] mvader | venus-os:mfd-navico [2019-08-15 12:42] – replace venus-device with GX device guy_stewart | ||
Line 6: | Line 6: | ||
+ | Navico compatible hardware: | ||
- | + | Note that this feature also works on the NSS EVO2. But only limited. And its not officially supported and also there will be no new software releases made by either Victron nor Navico to fix any issues that may arise. In other words, it is not a supported configuration by Navico but the consumer can feel free to use it (if they contact Navico or Victron service, our team will tell them it is not a supported configuration). More testing and user feedback will have to show what does and what does not work on the EVO2. | |
===== 3. Wiring ===== | ===== 3. Wiring ===== | ||
- | The Navico device needs to be connected to the Venus-device using Ethernet. Its not possible to connect over WiFi. For the ethernet connection, a Navico adapter is required: | + | The Navico device needs to be connected to the [[venus-os: |
* ETHADAPT-2M 127-56 | * ETHADAPT-2M 127-56 | ||
+ | * CABLE RJ45M-5F ETH ADPTR NONWATERPRF | ||
- | ==== Venus-device settings ==== | + | ==== GX device settings ==== |
- Go to Settings -> Services, and there enable MQTT. | - Go to Settings -> Services, and there enable MQTT. | ||
Line 25: | Line 27: | ||
==== Networking ==== | ==== Networking ==== | ||
- | No settings are necessary. The Venus-device and the Navico devices connect to each other using a technology called linklocal addressing. | + | No settings are necessary. The [[venus-os: |
It is possible to connect the a router to the same LAN; and that way provide for internet access. | It is possible to connect the a router to the same LAN; and that way provide for internet access. |
