venus-os:mfd-garmin
venus-os:mfd-garmin [2019-04-16 16:23] – mvader | venus-os:mfd-garmin [2019-10-19 04:17] – guy_stewart | ||
- | moved to: https://docs.victronenergy.com/ | + | ====== Garmin MFD integration ====== |
+ | Preliminary manual | ||
+ | ===== Introduction ===== | ||
+ | The integration technology used is called [[https:// | ||
+ | ===== Compatibility ===== | ||
+ | OneHelm is currently available for the GPSMAP® 8400/8600 MFD series. | ||
+ | Also, Active Captain is supported. This screenshot shows ActiveCaptain, | ||
+ | ===== Wiring ===== | ||
+ | The Garmin needs to be connected to the [[https:// | ||
+ | * Marine Network Cables - 6ft - PART NUMBER 010-10550-00 | ||
+ | * Marine Network Cables - 20ft - PART NUMBER 010-10551-00 | ||
+ | * Marine Network Cables - 40ft - PART NUMBER 010-10552-00 | ||
+ | * Marine Network Cables - 500ft - PART NUMBER 010-10647-01 | ||
+ | ===== Configuration ===== | ||
+ | ==== GX device settings ==== | ||
+ | - Ordered List Item | ||
+ | - Go to Settings -> Services, and there enable MQTT. | ||
+ | - Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD, and by what name. Make sure to check out [[https://www.dropbox.com/ | ||
+ | - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | ||
+ | ==== Networking ==== | ||
+ | No special networking settings are necessary. Not on the Garmin; and not on the Victron GX Device. | ||
+ | The Garmin MFDs run a DHCP server; and the [[https:// | ||
+ | To connect the GX Device to the internet and the [[https:// | ||
+ | ===== Configuring Multiple Battery Monitors ===== | ||
+ | {{youtube> | ||
+ | ===== Step by Step ===== | ||
+ | {{:venus-os:garmin-gx_1.jpg? | ||
