venus-os:mfd-garmin
venus-os:mfd-garmin [2019-02-21 13:05] – mvader | venus-os:mfd-garmin [2019-10-19 04:17] – guy_stewart | ||
- | ====== | + | ====== Garmin |
- | Garmin themselves calls this technology OneHelm. | + | Preliminary manual |
- | https:// | + | ===== Introduction ===== |
- | ==== Comptibility | + | The integration technology used is called [[https:// |
+ | ===== Compatibility ===== | ||
OneHelm is currently available for the GPSMAP® 8400/8600 MFD series. | OneHelm is currently available for the GPSMAP® 8400/8600 MFD series. | ||
- | ==== Wiring ==== | + | Also, Active Captain is supported. This screenshot shows ActiveCaptain, |
- | an adapter is necessary: | + | {{:venus-os: |
- | | + | ===== Wiring ===== |
- | | + | The Garmin needs to be connected to the [[https:// |
+ | * Marine Network Cables - 6ft - PART NUMBER 010-10550-00 | ||
+ | ===== Configuration ===== | ||
+ | ==== GX device settings ==== | ||
+ | - Ordered List Item | ||
+ | - Go to Settings -> Services, and there enable MQTT. | ||
+ | - Go to Settings -> System Setup -> Scroll to the bottom -> Battery measurements. And there set up what batteries you want to see on the MFD, and by what name. Make sure to check out [[https:// | ||
+ | - For boats; and other applications with DC loads such as lighting and a Battery Monitor installed, make sure to enable the "Has DC system setting" | ||
==== Networking ==== | ==== Networking ==== | ||
+ | No special networking settings are necessary. Not on the Garmin; and not on the Victron GX Device. | ||
+ | The Garmin MFDs run a DHCP server; and the [[https:// | ||
+ | To connect the GX Device to the internet and the [[https:// | ||
- | Needs to be done with ethernet. Not wifi. | + | ===== Configuring Multiple Battery Monitors ===== |
- | (DHCP server op de Garmin) | + | {{youtube> |
- | ==== Usage ==== | + | ===== Step by Step ===== |
- | Screenshots |
