venus-os:large
venus-os:large [2023-12-21 10:42] – external edit 127.0.0.1venus-os:large [2025-07-15 23:17] (current) – [5.12 Node-RED FAQ] mvader
Line 9: Line 9:
 Also Node-RED features a [[https://flows.nodered.org/node/node-red-dashboard|fully customisable dashboard]], viewable in a webbrowser - both locally but also remotely, via the VRM Servers. Also Node-RED features a [[https://flows.nodered.org/node/node-red-dashboard|fully customisable dashboard]], viewable in a webbrowser - both locally but also remotely, via the VRM Servers.
-To get a good idea of its possibilities, see our [[https://github.com/victronenergy/node-red-contrib-victron/wiki/Example-Flows|example flows]].+To get a good idea of its possibilities, see the [[https://github.com/victronenergy/node-red-contrib-victron/wiki/Example-Flows|example flows]].
 **Signal K server** Signal K Server is a server application that runs on a central hub in a boat; in this case a Victron GX device. A few of its most used features are: **Signal K server** Signal K Server is a server application that runs on a central hub in a boat; in this case a Victron GX device. A few of its most used features are:
Line 28: Line 28:
 There is and will be no official support on the functionalities of Venus OS large. There is and will be no official support on the functionalities of Venus OS large.
-For support, turn to the [[https://community.victronenergy.com/spaces/31/index.html|Modifications Space on Victron Community]] and/or the [[https://community.victronenergy.com/smart-spaces/71/node-red.html|Node-RED Space on Victron Community]].+For support, turn to the [[https://community.victronenergy.com/c/modifications/|Modifications Space on Victron Community]]. Another good resource is [[https://community.victronenergy.com/tag/node-red|all posts tagged as Node-RED]].
-There, first search if someone else had a similar question already. And if you can’t find such, then create a new question. Make sure you add Node-RED to the topic.+On Community, first search if someone else had a similar question already. And if you can’t find such, then create a new question. Make sure to tag it with Node-RED.
-For support on SignalK, there is a #victron channel in [[http://slack-invite.signalk.org/|the SignalK Slack]] workspace.+**Signal K community**
 +For support on SignalK, the largest crowd of helpful people can be found in the Signal K Discord & Signal K github discussions forum. Both are best found here: https://signalk.org/community/
 ===== 3. Requirements ===== ===== 3. Requirements =====
Line 56: Line 57:
 Both SignalK as well as Node-RED are rather resource intensive software applications to run on the GX Device. From a CPU usage point of view as well as RAM memory. Both SignalK as well as Node-RED are rather resource intensive software applications to run on the GX Device. From a CPU usage point of view as well as RAM memory.
-Ofcourse, how intensive depends on what kind of flows (node-redor how many messages & handling of them (SignalK) happens in the system.+The level of intensity largely depends on the system's specific configuration - whether it's the type of flows in node-red or the volume and processing requirements of messages in SignalK.
 From a GX device point of view, from the support models the Venus GX is the one with the least resources. Running both SignalK and Node-RED at the same time will be "pushing it" to say it simply. The Cerbo GX is already much faster, as it has a dual core CPU as well as much more RAM. More details about CPU & RAM differences are in this document: https://github.com/victronenergy/venus/wiki/machines. From a GX device point of view, from the support models the Venus GX is the one with the least resources. Running both SignalK and Node-RED at the same time will be "pushing it" to say it simply. The Cerbo GX is already much faster, as it has a dual core CPU as well as much more RAM. More details about CPU & RAM differences are in this document: https://github.com/victronenergy/venus/wiki/machines.
Line 82: Line 83:
 Go to Settings -> Firmware -> Online updates -> Image type: Go to Settings -> Firmware -> Online updates -> Image type:
- +{{ :venus-os:venus-os_image_type_selector_v2.png?nolink&500 |}}
-{{ :venus-os:image_type_selector.png?nolink&500 |}}+
 Now, change the Image type to Large. Then go one menu up, and Check for a new version and install that. Now, change the Image type to Large. Then go one menu up, and Check for a new version and install that.
 +This typically takes about 2 minutes.
 +=== Step 4. Verify and enable ===
-=== Step 3. Verify and enable ===+  - Verify that the image was successfully installed: go to the Settings menu, and check that under the integrations for availability.
 +  - Enable either Signal K or Node-RED. Note that though its possible to enable both, doing that on a Venus GX is "pushing it", the system might become slow. This is less of a problem on a Cerbo GX or an Ekrano GX, as it has more resources (faster CPU). Installer access level is required to enable/disable these settings.
-  - Verify that the image was successfully installed: go to the Settings menuand check that the Venus OS Large menu is available. +Visible once successfully installed, the integration settings:
-  Enable either Signal K or Node-RED. Note that though its possible to enable both, doing that on a Venus GX is "pushing it", the system might become slow. This is less of a problem on a Cerbo GX, as it has more resources (faster CPU). Installer access level is required to enable/disable these settings.+{{ :venus-os:venus_os_large_menu_v2.png?nolink&500 |}}
-Visible once successfully installed, the Venus OS Large menu:
-{{ :venus-os:venus_os_large_menu.png?nolink&500 |}}
 === How to update === === How to update ===
Line 120: Line 122:
 ===== 5. Node-RED ===== ===== 5. Node-RED =====
-{{ :venus-os:node-red-contrib-victron-nodes.png?nolink |}}+{{ https://raw.githubusercontent.com/victronenergy/node-red-contrib-victron/master/docs/images/node-palette.png?nolink |}}
 ==== 5.1 Introduction ==== ==== 5.1 Introduction ====
Line 129: Line 131:
 A good tutorial on how to work with Node-RED is here: https://nodered.org/docs/tutorials/first-flow. On https://github.com/victronenergy/node-red-contrib-victron/wiki/Example-Flows you can find example flows that use the Victron Energy nodes. Searching for [[https://flows.nodered.org/search?term=victron|Victron]] on [[https://flows.nodered.org/search?term=victron|https://flows.nodered.org/]] will give all community flows that have been tagged "victron". A good tutorial on how to work with Node-RED is here: https://nodered.org/docs/tutorials/first-flow. On https://github.com/victronenergy/node-red-contrib-victron/wiki/Example-Flows you can find example flows that use the Victron Energy nodes. Searching for [[https://flows.nodered.org/search?term=victron|Victron]] on [[https://flows.nodered.org/search?term=victron|https://flows.nodered.org/]] will give all community flows that have been tagged "victron".
-There is also a 3 part introductory webinar on Node-RED and Venus available at the Victron Tech YouTube channel:+==== 5.2 Three part introductory webinar ====
 +This is a 3 part introductory webinar on Node-RED and Venus available at the Victron Tech YouTube channel:
 [[https://www.youtube.com/watch?v=i_iaciqn_Fg| 1. Getting started]] [[https://www.youtube.com/watch?v=i_iaciqn_Fg| 1. Getting started]]
Line 142: Line 146:
 The Node-RED editor can be accessed from your LAN at https://venus.local:1881/. For some systems, you'll have to replace ''venus.local'' by the ip-address. You can also access the Node-RED editor from VRM, where it is available via the //Venus OS Large// menu.  The Node-RED editor can be accessed from your LAN at https://venus.local:1881/. For some systems, you'll have to replace ''venus.local'' by the ip-address. You can also access the Node-RED editor from VRM, where it is available via the //Venus OS Large// menu.
-__Standard nodes + Victron nodes__+==== 5.3 Node specifications ====
 Node-RED comes with a core set of useful nodes, and within the Venus OS large install there is a set of Victron nodes added to that: the Victron Pallet. All of the different nodes are described [[https://github.com/victronenergy/node-red-contrib-victron/wiki/Available-nodes|here]]. Node-RED comes with a core set of useful nodes, and within the Venus OS large install there is a set of Victron nodes added to that: the Victron Pallet. All of the different nodes are described [[https://github.com/victronenergy/node-red-contrib-victron/wiki/Available-nodes|here]].
 For developers: source code for the node-red-contrib-victron modules is [[https://github.com/victronenergy/node-red-contrib-victron/|here]], and note that updating is not possible from either the Node-RED editor as the commandline. The recommended way to get to the new node-red-contrib-victron version is to await a new Venus OS large build.  For developers: source code for the node-red-contrib-victron modules is [[https://github.com/victronenergy/node-red-contrib-victron/|here]], and note that updating is not possible from either the Node-RED editor as the commandline. The recommended way to get to the new node-red-contrib-victron version is to await a new Venus OS large build.
 +==== 5.4 Examples ====
 +Our most up to date library of examples can be accessed from within Node-RED. See the main menu (accessible from the top right), and then click Import. Or ctrl-i.
 +{{ :venus-os:examples_node-red.png?direct |}}
 +To see the examples when you don't have access to a Node-RED installation and flow-editor, see their copy here: https://github.com/victronenergy/node-red-contrib-victron/wiki/Example-Flows.
-==== 5.Back-up and restore ====+==== 5.Back-up and restore ====
 Just as with other software it is important to keep your Node-RED flows save and secure. We advise you to periodically backup your flows using the palette manager "//Export -> all flows//" option to download the ''flows.json'' file to your PC.  Just as with other software it is important to keep your Node-RED flows save and secure. We advise you to periodically backup your flows using the palette manager "//Export -> all flows//" option to download the ''flows.json'' file to your PC.
Line 158: Line 170:
 Do note that the above instruction only makes a backup of your flows, not of the Node-RED configuration. The configuration is stored in ''.config.*.json'' files under ''/data/home/nodered/.node-red/'' Do note that the above instruction only makes a backup of your flows, not of the Node-RED configuration. The configuration is stored in ''.config.*.json'' files under ''/data/home/nodered/.node-red/''
-==== 5.Installing extra nodes ====+==== 5.Installing extra nodes ====
 Node-RED comes with a core set of useful nodes, but there are many more available from both the Node-RED project as well as the wider community. Node-RED comes with a core set of useful nodes, but there are many more available from both the Node-RED project as well as the wider community.
Line 180: Line 192:
 Make sure that there is always 30MB of free space remaining on the data partition. One of the [[https://github.com/victronenergy/node-red-contrib-victron/wiki/Example-Flows#monitor-disk-usage | example flows]] shows how to check the free space using a Node-RED dashboard .  Make sure that there is always 30MB of free space remaining on the data partition. One of the [[https://github.com/victronenergy/node-red-contrib-victron/wiki/Example-Flows#monitor-disk-usage | example flows]] shows how to check the free space using a Node-RED dashboard .
-==== 5.Controlling relays ====+==== 5.Controlling relays ====
 +For a relay to be controllable via Node-RED, it needs to be switched to manual control first. In most cases this needs to be done by using [[https://www.victronenergy.com/panel-systems-remote-monitoring/victronconnect|VictronConnect]].
 +{{:venus-os:victron-connect-relay-manual.png?400|}}
 === GX Device relays === === GX Device relays ===
Line 197: Line 215:
 === SolarCharger MPPT Relay === === SolarCharger MPPT Relay ===
-Currently it is not possible to control the relay in a MPPT Solar Chargereven though there is a Victron node offering such functionality. The reason it doesn't work, is that VictronConnect does not have the required "Manual control" option in the list of selectable Relay modes for the MPPTs. This will be fixed at some point.+In order to switch the relay via Node-REDfirst use VictronConnect to switch the operation mode to //manual control//.
 Note that only the larger model solar chargers feature a relay. Note that only the larger model solar chargers feature a relay.
Line 205: Line 223:
 === RS series (inverter, multi) relays === === RS series (inverter, multi) relays ===
-Currently not controllableWill be controllable in the future.+First set the relay to //manual control// using VictronConnectOnce that has been done, the relay can be controlled using Node-RED.
 === Charger relays === === Charger relays ===
 The only charger which has a relay that is controllable is the Smart IP43 Charger. To use that for remote control, set its mode, using the VictronConnect app, to be remote controllable. Note that its use is limited: the relay is only powered (and thus only controllable) when the charger is switched on. It doesn't work when it's turned off with AC connected. This limitation applies to the 230V models as well as the later 120V/240V models. The only charger which has a relay that is controllable is the Smart IP43 Charger. To use that for remote control, set its mode, using the VictronConnect app, to be remote controllable. Note that its use is limited: the relay is only powered (and thus only controllable) when the charger is switched on. It doesn't work when it's turned off with AC connected. This limitation applies to the 230V models as well as the later 120V/240V models.
-==== 5.Node-RED Dashboard ====+==== 5.Node-RED Dashboard ====
 Besides the flow and automation functionally, Node-RED also offers a fully customisable dashboard. Including graphs, indicators as well as controls such as switches and sliders. Besides the flow and automation functionally, Node-RED also offers a fully customisable dashboard. Including graphs, indicators as well as controls such as switches and sliders.
Line 222: Line 240:
 {{ :venus-os:vrm_node_red_ui_step_3.png?direct&600 |VRM Node-RED UI - Step 3}} {{ :venus-os:vrm_node_red_ui_step_3.png?direct&600 |VRM Node-RED UI - Step 3}}
-==== 5.Configuration files ====+==== 5.Configuration files ====
 WARNING: the vast majority of systems using Node-RED will not, and should not (!), have to modify any of the files here described. Venus OS itself, including Venus OS large and Node-RED, is made such that its not necessary to dive into the command line. WARNING: the vast majority of systems using Node-RED will not, and should not (!), have to modify any of the files here described. Venus OS itself, including Venus OS large and Node-RED, is made such that its not necessary to dive into the command line.
Line 241: Line 259:
 For more information on such Node-RED configuration customisations, see https://nodered.org/docs/user-guide/runtime/configuration. For more information on such Node-RED configuration customisations, see https://nodered.org/docs/user-guide/runtime/configuration.
-==== 5.7. Ready-to-use solutions ====+==== 5.10 Ready-to-use solutions ====
 Node-RED can also be used for doing more advanced tasks. Some examples of ready-to-use solutions are: Node-RED can also be used for doing more advanced tasks. Some examples of ready-to-use solutions are:
Line 247: Line 265:
   * [[https://flows.nodered.org/node/node-red-contrib-eskomsepush|EskomSePush]] - use Node-RED for charging the batteries before the next load shedding happens (for South African users)   * [[https://flows.nodered.org/node/node-red-contrib-eskomsepush|EskomSePush]] - use Node-RED for charging the batteries before the next load shedding happens (for South African users)
-==== 5.8. Using data from VRM  ====+==== 5.11 Using data from VRM  ====
 For some flows it can be useful to retrieve data from the VRM Portal Database. For example to retrieve de Solar irradiation or yield forecasts. For some flows it can be useful to retrieve data from the VRM Portal Database. For example to retrieve de Solar irradiation or yield forecasts.
Line 272: Line 290:
 The [[https://flows.nodered.org/node/victron-vrm-api|Victron VRM API node]] makes it easy to use the VRM API from a Node-RED flow. Alternatively take a look at above mentioned Dynamic-ESS flow. The [[https://flows.nodered.org/node/victron-vrm-api|Victron VRM API node]] makes it easy to use the VRM API from a Node-RED flow. Alternatively take a look at above mentioned Dynamic-ESS flow.
-==== 5.9. Node-RED FAQ ====+==== 5.12 Node-RED FAQ ====
 === Q1: Write/read file gives "Error: EACCESS: permission denied' === === Q1: Write/read file gives "Error: EACCESS: permission denied' ===
Line 284: Line 302:
 In case you see that there is a newer version Victron pallette available online, and thats not yet shipping in a Venus OS Large version, then the only option is to wait: a new Venus OS Large version is usually made available shortly after updating that pallette. In case you see that there is a newer version Victron pallette available online, and thats not yet shipping in a Venus OS Large version, then the only option is to wait: a new Venus OS Large version is usually made available shortly after updating that pallette.
-=== Q3: How can I password protect Node-RED ===+=== Q3: How can I password protect Node-RED / My Node-RED is password protected ===
-Password protection of Node-Red is linked to the remote console. If a password is set for the remote console, this password is also used for securing Node-Red. The username is ''admin'', the password is the remote console password.+__Venus OS v3.50 and later__
 +For systems that have a security profile set (under Settings -> General -> Security Profile), the password protection is linked to the chosen security profile. The password that has been set for either security profile "weak" or "secured" is also used to access Node-RED, in combination with username ''admin''.
 +__ Venus OS versions prior to v3.50__
 +The Node-RED's password protection is tied to the remote console. If a password is set for the remote console, this password is also used for securing Node-Red. The username is ''admin'', the password is the remote console password.
 === Q4: How do I restart Node-RED from the Venus GUI? === === Q4: How do I restart Node-RED from the Venus GUI? ===
Line 325: Line 349:
   export NODE_EXTRA_CA_CERTS=/data/etc/ssl/venus.local.crt   export NODE_EXTRA_CA_CERTS=/data/etc/ssl/venus.local.crt
 === Q9: How often do the Victron input nodes send a msg? === === Q9: How often do the Victron input nodes send a msg? ===
 The input nodes send out a message on each value change. If the ‘//only changes//’ checkbox is set, this will be the only output of the node. If the '//only changes//' checkbox is not set, the node also sends out the current value each 5 seconds. If you want more fine grained control, consider storing the desired values in a context in combination with triggered intervals. See [[https://github.com/victronenergy/node-red-contrib-victron/wiki/Example-Flows#only-messages-at-regular-intervals|here]] for an example on how to do that. The input nodes send out a message on each value change. If the ‘//only changes//’ checkbox is set, this will be the only output of the node. If the '//only changes//' checkbox is not set, the node also sends out the current value each 5 seconds. If you want more fine grained control, consider storing the desired values in a context in combination with triggered intervals. See [[https://github.com/victronenergy/node-red-contrib-victron/wiki/Example-Flows#only-messages-at-regular-intervals|here]] for an example on how to do that.
 +=== Q10: How can I get Node-RED to also listen to http port 1880 ===
 +There are some nodes that are only able to connect to a http site. In that case you probably also want to enable http on port 1880. This can be achieved by creating (or adding to) a user configuration file ''/data/home/nodered/.node-red/settings-user.js'', containing:
 +  module.exports = {
 +     /* Make sure that we also listen on port 1880 on all interfaces */
 +     uiHost: "::"
 +And restart Node-RED.
 +=== Q11: Is there a way to have the context survive reboots? ===
 +By default the context is stored in RAM memory of the GX device only. When the GX device reboots or loses lower, the context information is lost.
 +In order to keep the context data, it is needed to [[https://nodered.org/docs/api/context/store/localfilesystem|store the context to disk]]. This can be achieved by creating (or adding to) a user configuration file ''/data/home/nodered/.node-red/settings-user.js'', containing:
 +    contextStorage: {
 +      default: {
 +        module: "localfilesystem",
 +        config: {
 +          flushInterval: 300 // Save context data every 5 minutes
 +With the above settings, context files will get created periodically in ''/data/home/nodered/.nodered/context/''. In order not to wear out the flash memory too much, don't write too often.
 ===== 6. Signal K ===== ===== 6. Signal K =====
Line 381: Line 434:
   * [[https://demo.signalk.org/documentation/|The official Signal K documentation]]   * [[https://demo.signalk.org/documentation/|The official Signal K documentation]]
   * [[https://community.victronenergy.com/search.html?c=&includeChildren=&f=&type=question+OR+idea+OR+kbentry+OR+answer+OR+topic+OR+user&redirect=search%2Fsearch&sort=relevance&q=signal+k|Signal K topics on the Victron Community forum]]   * [[https://community.victronenergy.com/search.html?c=&includeChildren=&f=&type=question+OR+idea+OR+kbentry+OR+answer+OR+topic+OR+user&redirect=search%2Fsearch&sort=relevance&q=signal+k|Signal K topics on the Victron Community forum]]
-  * [[http://slack-invite.signalk.org/|Signal K Slack]] - a real time chat group including a special Victron channel.+  * [[https://discord.gg/uuZrwz4dCS |Signal K Discord]] - a real time chat group including a special Victron channel.
 Do not contact normal Victron support for any help on SignalK. Its based on community support, not official support. Do not contact normal Victron support for any help on SignalK. Its based on community support, not official support.
-==== 6.First use & configuring ====+==== 6.First use & configuring ====
-=== Step 1Opening the dashboard ===+Follow these steps to turn your GX into a NMEA to WiFi gateway within 5 minutes.
-Open a web browser, and go to the SignalK Dashboard by navigating to http://venus.local:3000.+These instructions assume that your GX device has already been set-up with Venus OS Large, and Signal K is enabled.
 +=== Step 1Signal K Admin page ===
-Further documentation about that is ... (some link to signalk-node documentation?)+Open a web browser, and go to the Signal K admin page by navigating to http://venus.local:3000.
-=== Step 2Configure serial connections ===+{{ :venus-os:img_2580.jpeg |}}
-Use this to, for example, configure a USB-connected NMEA0183 connection in SignalKTo do so, go to the dashboard (http://0.0.0.0:3000), and there to Server -> Connections.+=== Step 2Set the admin password ===
-Make sure to not add a connection using any of the built-in serial ports (/dev/ttyO0, /dev/ttyO2, /dev/ttyO4, /dev/ttyO5). These are the VE.Bus- and VE.Direct ports on the Venus GX, and it is not necessary to configure them in SignalK. Data from any devices there connected is already available in SignalK, by means of the "Victron Venus Plugin"; see Dashboard -> Server -> Plugin Config.+Go to Security -> Users and create an admin user for Signal K and protect it with a secure password.
-Note that once configured in SignalK, for example a USB-serial port, that port is no longer normally available in Venus OS. For example, when plugging in a USB-GPS; and then adding a connection for its corresponding tty in the SignalK, makes for that GPS to be no longer be recognised and available in Venus OS.+{{ :venus-os:img_2579.png |}}
-=== Step 3. Configure can-bus connections ===+=== Step 3. Vessel information ===
-For the Venus GXSignalK comes pre-configured with a NMEA2000 listener for the VE.Can ports, its named "n2k-on-ve.can-socket", and uses the canboatjs.+Go to Settings and enter some basic information about your boat.
 +{{ :venus-os:img_9926.png |}}
 +=== Step 4. NMEA2000 Can-bus connection ===
 +For NMEA2000 networksits recommended to have all connected devices use isolated connections. Therefore, when connecting the an NMEA2000 network, we recommend using the Ekrano GX and the Cerbo MK2 GX. Connect to the port physically labelled “VE.Can 1”.
 +Signal K is preconfigured to have its port operational for this.
 +Here is how you can see the preconfigured connection in the Signal K Dashboard:
Line 410: Line 475:
- +Note that, to keep that operational, that port must remain configured as a 250kbit VE.Can & NMEA2000 port in the Remote Console:
-Note that, to keep that operational, that port must be configured as a 250kbit VE.Can & NMEA2000 port in the Remote Console.+
Line 417: Line 481:
 +For more information on CAN-busses, see chapter 6.4.
-=== Step 4Adding Signalk Plugins or Webapps ===+=== Step 5Optional: Configure NMEA0183 serial connections ===
-TODO: explain & warn about data partition size & space (since thats where plugins are installed by signalk on Venus OS)Filling up the datapartition can corrupt Venus OS. More information about data partition on Venus OS here: https://github.com/victronenergy/venus/wiki/data-partition+Use this to, for example, configure a USB-connected NMEA0183 connection in SignalKGo to Server -> Connections.
 +Make sure to not add a connection using any of the built-in serial ports (/dev/ttyO0, /dev/ttyO2, /dev/ttyO4, /dev/ttyO5). These are the VE.Bus- and VE.Direct ports on the Venus GX, and it is not necessary to configure them in SignalK. Data from any devices there connected is already available in SignalK, via the "Victron Venus Plugin"; see Dashboard -> Server -> Plugin Config.
 +Note that once configured in SignalK, for example a USB-serial port, that port is no longer normally available in Venus OS. For example, when plugging in a USB-GPS; and then adding a connection for its corresponding tty in the SignalK, makes for that GPS to be no longer be recognised and available in Venus OS.
 +=== Step 6. Verify received data ===
 +Go to the Databrowser to see the data now available to Signal K, and to tablets and nav. apps on   WiFi:
 +{{ :venus-os:img_2578.png |}}
 +=== Step 7. Configure your nav app ===
 +Steps needed here will differ per app. The key required data is:
 +  * Host/IP address: **venus.local**
 +  * Protocol: **TCP**
 +  * Port: **10110**
 +=== Done! ===
 +Now you should have all your data such as position from the boat’s GPS, speed, wind data, as well as AIS targets in your favourite nav app. Like here in Navionics:
 +{{ :venus-os:img_2581.jpeg?nolink |}}
 +=== Where to go from here? Anchor alarms, trip recording, automatic log books and more ===
 +  * Anchor alarm: https://demo.signalk.org/documentation/features/anchoralarm/anchoralarm.html
 +  * Automatic log book & trip recording: https://svrenaissance.com/starlink-and-victron-a-match-made-in-heaven-for-boaters/
 +==== 6.4 CAN-bus ports ====
 +Below lists documents the mapping from physical ports on the device to the interface within Venus OS. This information is needed when you want to deviate from the standard configuration.
 +=== Cerbo GX ===
 +^ Enclosure label ^ Interface ^ Notes ^
 +| VE.Can 1 | can0 | Non-isolated and default enabled in SignalK |
 +| BMS-Can | can1 | Non-isolated, not usable within SignalK for NMEA2000 |
 +Within the Victron product range, CAN-bus ports that are labelled BMS-Can are limited in their functionality due to hardware constraints. Their only use is to connect to a managed battery such as BYD and Pylontech, used in landbased ESS & Off-grid systems - not in the marine market.
 +=== Cerbo GX MK2 ===
 +| VE.Can 1 | vecan0 | Isolated and default enabled in SignalK |
 +| VE.Can 2 | vecan1 | Non-isolated |
 +=== Ekrano GX ===
 ==== 6.5 Signal K FAQ ==== ==== 6.5 Signal K FAQ ====
Line 543: Line 659:
 ==== 8.1 Disk space issues / data partition full ==== ==== 8.1 Disk space issues / data partition full ====
-Using both Signal K Server, as well as Node-RED, it is quite easy to completely fill up the data partition. Which can cause all sorts of issueslike:+Using both Signal K Server, as well as Node-RED, it is possible to completely fill up the data partition.
 +The GX device will issue a warning, #46 Data partition full, as soon as the free space of the data partition is below 5%.
 +To see the exact free spacego to Settings -> General -> Modifications.
 +Having the data partition full will lead to unexpected results. The system is not built to be resilient for that. Some examples:
   - Venus OS itself no longer working correctly,   - Venus OS itself no longer working correctly,
Line 550: Line 672:
   - and similar.   - and similar.
-Note that Venus OS itself does **not** show a notification or warning when the data disk is full. And know that the other disks are read-only unless remounted to read/write as per [[https://www.victronenergy.com/live/ccgx:root_access|these root access instructions]].+Depending on what the issue is, there are a few things you can do:
-The easy solution is to do full GX factory reset, as per the instructions in the GX user manuals. This includes downloading a file called venus-data.tgz.+  - Remove all Node-RED flows and installed node palettes. See next chapter on how to do that.
 +  - Remove all Signal K Server log files. In case you're using SignalK, then we recommend to try that option first. See next chapter on how to do that (requires a USB stick or SD Card), and once done make sure to double check you're Signal K log setup; Most importantly, make sure that the ''Keep only most recent data log files'' option is enabled. That feature is enabled by default, and can be found in the Signal K -> Server -> Settings section.
 +  - Do full GX factory reset, as per the instructions in the GX user manuals. This includes downloading a file called venus-data.tgz; see GX manual for detailsDisadvantage is that you'll need to reconfigure the GX.
 +  - A more detailed approach is logging into the SSH console, and checking for disk space:
-A more detailed approach is logging in on SSH, and checking for disk space. Here are a few useful commands.+**Tips and tricks to login a diagnose disk space**
 +Require root access: https://www.victronenergy.com/live/ccgx:root_access.
 The ''df'' command shows disk space including percentage in user for all mounted storages. Note the 100% full of below data partition. That is a problem. It should show maybe 10, 20 or 30%, but never 100% in use. The ''df'' command shows disk space including percentage in user for all mounted storages. Note the 100% full of below data partition. That is a problem. It should show maybe 10, 20 or 30%, but never 100% in use.
Line 600: Line 727:
 744 /data/log/swupdate 744 /data/log/swupdate
 </code> </code>
 +==== 8.2 Backup / Reset to factory defaults  ====
 +There are scenarios where you want to make a backup of your data or when you want to clear logging or even start all over and go back to factory defaults. In order to make this process easy, you can put one (or more) of the following files on an USB stick and reboot your device. The files will be unpacked and the scripts within will execute. Once the script is ready with its tasks, a notification of 3 beeps can be heard (on a Multiplus-II GX the notification will be shown in the display). After which the USB stick can be removed.
 +  * [[https://www.victronenergy.com/upload/software/venus-factory-default/venus-data-00-backup-data-partition.tgz|venus-data-00-backup-data-partition.tgz]] - copies all that is on the ''/data'' partition onto the usb stick
 +  * [[https://www.victronenergy.com/upload/software/venus-factory-default/venus-data-20-signalk-reset.tgz|venus-data-20-signalk-reset.tgz]] - removes all files and directories from ''/data/conf/signalk/'', which lets you start over again with SignalK.
 +  * [[https://www.victronenergy.com/upload/software/venus-factory-default/venus-data-30-signalk-delete-data-logs.tgz|venus-data-30-signalk-delete-data-logs.tgz]] - removes only the SignalK log files
 +  * [[https://www.victronenergy.com/upload/software/venus-factory-default/venus-data-20-node-red-reset.tgz|venus-data-20-node-red-reset.tgz]] - removes the files from ''/data/home/nodered/'', which lets you start with Node-RED from scratch.
 +See [[https://www.victronenergy.com/live/ccgx:root_access#hooks_to_install_run_own_code_at_boot|here]] for more information on how this process works.
venus-os/large.1703151765.txt.gz · Last modified: by 127.0.0.1
