venus-os:large
Previous revision | |||
— | venus-os:large [2024-05-02 00:04] (current) – [6.2 Documentation and support for Signal K] mvader | ||
+ | ====== Venus OS Large image: Signal K and Node-RED ====== | ||
+ | This manual documents Venus OS Large. Venus OS is the the software running on our [[https:// | ||
+ | **Node-RED** offers PLC like programming for connecting hardware devices, APIs and online services. It provides a browser-based editor that makes it easy to wire together flows. With it, one can for example program a functionality such as activating a relay based on a temperature measurement combined with time. Or make far more complex algorithms, tying relays, measurements, | ||
+ | Also Node-RED features a [[https:// | ||
+ | **Signal K server** Signal K Server is a server application that runs on a central hub in a boat; in this case a Victron GX device. A few of its most used features are: | ||
+ | - WiFi navigation and AIS data server to charting apps such as iSailor, Navionics, iNavX, Aqua Map. | ||
+ | - The perfect Anchor alarm, for features and details see [[https:// | ||
+ | - Automatic log book | ||
+ | The [[https:// | ||
+ | For more information on Signal K on Venus OS, see below chapter. | ||
+ | ===== 2. Where to find support ===== | ||
+ | There is and will be no official support on the functionalities of Venus OS large. | ||
+ | For support, turn to the [[https:// | ||
+ | There, first search if someone else had a similar question already. And if you can’t find such, then create a new question. Make sure you add Node-RED to the topic. | ||
+ | For support on SignalK, there is a #victron channel in [[http:// | ||
+ | ===== 3. Requirements ===== | ||
+ | ==== 3.1 GX Device compatibility ==== | ||
+ | The compatible GX devices are: | ||
+ | * Ekrano GX | ||
+ | * Cerbo GX | ||
+ | * Cerbo-S GX | ||
+ | * Venus GX | ||
+ | * Octo GX | ||
+ | * MultiPlus-II GX | ||
+ | * EasySolar-II GX | ||
+ | The Color Control GX (CCGX) as well as the CanVU GX are unfortunately not able to run Venus OS Large. | ||
+ | Venus OS large is also available for certain RaspberryPi models. Installation files below, and installation & other raspberrypi specific instructions [[https:// | ||
+ | ==== 3.2 CPU & Memory resources ==== | ||
+ | Both SignalK as well as Node-RED are rather resource intensive software applications to run on the GX Device. From a CPU usage point of view as well as RAM memory. | ||
+ | Ofcourse, how intensive depends on what kind of flows (node-red) or how many messages & handling of them (SignalK) happens in the system. | ||
+ | From a GX device point of view, from the support models the Venus GX is the one with the least resources. Running both SignalK and Node-RED at the same time will be " | ||
+ | When running out of RAM or CPU, the device will slow down. And eventually also reboot by itself due to the watchdog. | ||
+ | ===== 3. How to install and update ===== | ||
+ | === Step 1. Preparations === | ||
+ | * __Cerbo GX__ - No preparations required. | ||
+ | * __Venus GX__ - First install & boot v2.73,or a later version. And only thereafter install Venus OS Large. The reason for this is to make sure the partitioning of the flash is per requirements of Venus OS Large. | ||
+ | * __MultiPlus-II GX__ - No preparations required. | ||
+ | * __EasySolar-II GX__ - No preparations required. | ||
+ | * __RaspberryPi 3__ - No preparations required. | ||
+ | * __RaspberryPi 4__ - No preparations required. | ||
+ | Note, when installing on a RaspberryPi, | ||
+ | === Step 2. Update to the latest firmware version (v2.90 or later) === | ||
+ | See Settings -> Firmware -> Online updates. For more information, | ||
+ | === Step 3. Set the image type Venus OS Large === | ||
+ | Go to Settings -> Firmware -> Online updates -> Image type: | ||
+ | === Step 3. Verify and enable === | ||
+ | - Verify that the image was successfully installed: go to the Settings menu, and check that the Venus OS Large menu is available. | ||
+ | - Enable either Signal K or Node-RED. Note that though its possible to enable both, doing that on a Venus GX is " | ||
+ | Visible once successfully installed, the Venus OS Large menu: | ||
+ | === How to update === | ||
+ | Both online and offline update methods can be used. The Image type setting, see the How to install chapter, defines what image type is being updated. See the GX manual for more details. | ||
+ | After installing and then enabling either one or both of the features, they need to be configured through a website in your browser. | ||
+ | To access the Node-RED flow editor, type https:// | ||
+ | See [[https:// | ||
+ | ==== 5.1 Introduction ==== | ||
+ | Node-RED is a tool for connecting hardware devices, APIs and online services in new and interesting ways. It provides a browser-based editor that makes it easy to wire together flows. With it, one can for example program a functionality such as activating a relay based on a temperature measurement. Or make far more complex algorithms, tying relays, measurements, | ||
+ | A good tutorial on how to work with Node-RED is here: https:// | ||
+ | It is always wise to create an extra backup before performing an update of the firmware. | ||
+ | Do note that the above instruction only makes a backup of your flows, not of the Node-RED configuration. The configuration is stored in '' | ||
+ | ==== 5.3 Installing extra nodes ==== | ||
+ | Node-RED comes with a core set of useful nodes, but there are many more available from both the Node-RED project as well as the wider community. | ||
+ | For example nodes that give access to weather data, or with timer functionality, | ||
+ | You can search for available nodes in the Node-RED library. | ||
+ | The Victron Palette comes pre-installed. | ||
+ | Read the [[https:// | ||
+ | To install new nodes/ | ||
+ | Palettes will be installed on the data partition on the GX Device. Which means that they will remain installed when updating Venus OS to a new version. | ||
+ | Refer to the remove button in the palette manager to remove self-installed palettes. | ||
+ | When installing a newer version of a palette than what is pre-installed in Venus OS, Node-RED will use that newer version. | ||
+ | Make sure that there is always 30MB of free space remaining on the data partition. One of the [[https:// | ||
+ | ==== 5.4 Controlling relays ==== | ||
+ | === GX Device relays === | ||
+ | To be able to control the relay(s) on the GX Device, configure them to be Manually controlled: | ||
+ | === Battery Monitor Relay === | ||
+ | The relay in a BMV can be controlled. Make sure to set, using VictronConnect, | ||
+ | The relay in a Lynx Shunt VE.Can can be controlled. Make sure to set the relay function to " | ||
+ | === SolarCharger MPPT Relay === | ||
+ | Currently it is not possible to control the relay in a MPPT Solar Charger, even though there is a Victron node offering such functionality. The reason it doesn' | ||
+ | Note that only the larger model solar chargers feature a relay. | ||
+ | === (VE.Bus connected-) Multi, Quattro and similar product relays === | ||
+ | Besides the flow and automation functionally, | ||
+ | It is viewable in a web browser - both locally as well as remote, via the VRM Servers. See chapter 6.2 for how to see it remotely. | ||
+ | Once that is done, you can find the nodes in the palettes on the left. Once the dashboard has been configured and deployed, an extra tile will appear in the //Venus OS Large// menu on VRM, allowing to connect to the dashboard via VRM. | ||
+ | Example dashboard: | ||
+ | ==== 5.6 Configuration files ==== | ||
+ | * [[https:// | ||
+ | === Q2: How can I update the Victron node pallette === | ||
+ | As that pallette is part of the total Venus OS large package, it can only be updated by installing a newer Venus OS large version. | ||
+ | In case you see that there is a newer version Victron pallette available online, and thats not yet shipping in a Venus OS Large version, then the only option is to wait: a new Venus OS Large version is usually made available shortly after updating that pallette. | ||
+ | === Q3: How can I password protect Node-RED === | ||
+ | Password protection of Node-Red is linked to the remote console. If a password is set for the remote console, this password is also used for securing Node-Red. The username is '' | ||
+ | - Edit the ''/ | ||
+ | - Start Node-RED | ||
+ | module.exports = { | ||
+ | ===== 6. Signal K ===== | ||
+ | ==== 6.1 Introduction ==== | ||
+ | === 6.1.1 Why have Signal K on your GX Device? === | ||
+ | By adding Signal K, the GX device becomes a data hub for all marine electronics on your yacht. For example AIS, boat speed and wind data, and more. The Signal K is the interface between all those devices and protocols on one side, and mobile Apps on phones, tablets and the alikes on the other. Note that SignalK itself is not a visualisation tool, its purpose is purely to gather all the data and make it available for web- phone-, and tablet-apps for the visualisation. | ||
+ | Also, there are SignalK plugins to forward the data to influxdb & Grafana. | ||
+ | Popular Apps compatible with Signal K: | ||
+ | * Auqua Map | ||
+ | * iNavX | ||
+ | * iSailor | ||
+ | * Navionics | ||
+ | * ... (welcome to add more here) | ||
+ | === 6.1.2 Instruments compatible with Signal K === | ||
+ | * All Victron products that can be connected to a GX device | ||
+ | * NMEA0183 and NMEA2000 GPS data, AIS data, Wind Temperature and other environmental data, tbd | ||
+ | * Engine data available on NMEA2000 and SAE 1939 | ||
+ | * Fusion Stereo | ||
+ | And many more. | ||
+ | === 6.1.3 What is Signal K ? === | ||
+ | Signalk-server is a software application that, in the context of this manual, runs on your GX Device and interface to all Victron protocols and more. It uses plugins, and there is a large community of enthusiasts around it, making it one of the most flexible and complete pieces of software that understands the plethora of protocols of all different manufacturers that make marine electronics. | ||
+ | For more information on Signal K, read the [[https:// | ||
+ | Note that Signal K is not a Victron project. At Victron, we are great fans of sailing, open source as well as community driven projects. And Signal K is a perfect example of such project. And when running on a GX Device its a perfect marriage. | ||
+ | === 6.1.3 Considerations on how to install Signal K === | ||
+ | The type of install described in this document, running Venus OS including SignalK, has these advantages: no need to use a rapsberrypi, | ||
+ | The other common type of Signal K Server install, installed on a RaspberryPi running Raspbian, has the advantages of more flexibility, | ||
+ | There is no one right way for everyone to do this; the best solution will depend on the requirement. | ||
+ | For raspberrypi owners, note that its very easy to try both methods and switch between them: simply have two sdcards. | ||
+ | ==== 6.2 Documentation and support for Signal K ==== | ||
+ | Do not contact normal Victron support for any help on SignalK. Its based on community support, not official support. | ||
+ | ==== 6.3 First use & configuring ==== | ||
+ | === Step 1. Opening the dashboard === | ||
+ | Open a web browser, and go to the SignalK Dashboard by navigating to http:// | ||
+ | Further documentation about that is ... (some link to signalk-node documentation? | ||
+ | === Step 2. Configure serial connections === | ||
+ | Use this to, for example, configure a USB-connected NMEA0183 connection in SignalK. To do so, go to the dashboard (http:// | ||
+ | Make sure to not add a connection using any of the built-in serial ports (/ | ||
+ | Note that once configured in SignalK, for example a USB-serial port, that port is no longer normally available in Venus OS. For example, when plugging in a USB-GPS; and then adding a connection for its corresponding tty in the SignalK, makes for that GPS to be no longer be recognised and available in Venus OS. | ||
+ | === Step 3. Configure can-bus connections === | ||
+ | For the Venus GX, and Cerbo GX, SignalK comes pre-configured with a NMEA2000 listener for the VE.Can ports, its named " | ||
+ | Note that, to keep that operational, | ||
+ | === Step 4. Adding Signalk Plugins or Webapps === | ||
+ | TODO: explain & warn about data partition size & space (since thats where plugins are installed by signalk on Venus OS). Filling up the datapartition can corrupt Venus OS. More information about data partition on Venus OS here: https:// | ||
+ | === Cerbo GX === | ||
+ | === Cerbo GX MK2 === | ||
+ | === Ekrano GX === | ||
+ | ==== 6.5 Signal K FAQ ==== | ||
+ | === Q1 - How to best handle & install a GPS === | ||
+ | You want the data available in SignalK and in Venus OS, so that it gets to VRM. And preferably a quality GPS. | ||
+ | __USB GPS Dongle__ | ||
+ | Plugging it into the GX Device will make it be recognised automatically; | ||
+ | __NMEA2000 GPS__ | ||
+ | Connect it to the GX Device on the canbus port. Consider using our '' | ||
+ | In Venus OS v2.60, support for NMEA2000 GPS-es was added. | ||
+ | Signal K can then get it in two ways: directly from the NMEA2000 canbus in case thats configured as a data provider in Signal K. And via the native Venus OS functionality through the Victron-signalk-plugin. | ||
+ | Conclusion (untested), when using a NMEA2000 GPS, it will be available to both Venus OS and Signal K. | ||
+ | __Part of a NMEA0183 network__ | ||
+ | Tbd. Actually a NMEA0183-network is probably something that doesnt exist: you can't have NMEA0183 in a network, its point to point. | ||
+ | # https:// | ||
+ | cp / | ||
+ | npm list -g | ||
+ | # /usr/lib | ||
+ | # ├── node-red@3.1.0 | ||
+ | # ├── npm@9.5.1 | ||
+ | svc -d / | ||
+ | ## Restore that file | ||
+ | mv / | ||
+ | cd / | ||
+ | svc -u / | ||
+ | ===== 7. Remote access via VRM ===== | ||
+ | The three available web interfaces, the Node-RED flow editor, Node-RED dashboard and the Signal K admin panel can also be accessed remotely, via VRM. | ||
+ | After enabling them, to the VRM, and there click the Venus OS Large menu. Note that this might be slow, depending on the quality of the connection. | ||
+ | ===== 8. Troubleshooting ===== | ||
+ | ==== 8.1 Disk space issues / data partition full ==== | ||
+ | Using both Signal K Server, as well as Node-RED, it is quite easy to completely fill up the data partition. Which can cause all sorts of issues, like: | ||
+ | - Venus OS itself no longer working correctly, | ||
+ | - Signal K Server refuses to start / no longer works, | ||
+ | - and similar. | ||
+ | Note that Venus OS itself does **not** show a notification or warning when the data disk is full. And know that the other disks are read-only unless remounted to read/write as per [[https:// | ||
+ | Depending on what the issue is, there are a few things you can do: | ||
+ | The '' | ||
+ | root@einstein:/ | ||
+ | Filesystem | ||
+ | devtmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | overlay | ||
+ | The '' | ||
+ | root@Cerbo:/ | ||
+ | 1103640 / | ||
+ | 1099352 / | ||
+ | 1099276 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3920 / | ||
+ | 744 / | ||
+ | 164 / | ||
+ | 160 / | ||
+ | 116 / | ||
+ | 116 / | ||
+ | 164608 / | ||
+ | 160312 / | ||
+ | 160240 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3924 / | ||
+ | 744 / | ||
venus-os/large.1680935261.txt.gz · Last modified: 2023-04-08 08:27 (external edit)
