venus-os:large
venus-os:large [2022-09-12 21:43] – [1.1 Venus OS Large, Node-RED and Signal K server?] mvader | venus-os:large [2024-05-02 00:04] (current) – [6.2 Documentation and support for Signal K] mvader | ||
Line 5: | Line 5: | ||
This manual documents Venus OS Large. Venus OS is the the software running on our [[https:// | This manual documents Venus OS Large. Venus OS is the the software running on our [[https:// | ||
- | **Node-RED** offers PLC like programming for connecting hardware devices, APIs and online services.It provides a browser-based editor that makes it easy to wire together flows. With it, one can for example program a functionality such as activating a relay based on a temperature measurement. Or make far more complex algorithms, tying relays, measurements, | + | **Node-RED** offers PLC like programming for connecting hardware devices, APIs and online services. It provides a browser-based editor that makes it easy to wire together flows. With it, one can for example program a functionality such as activating a relay based on a temperature measurement |
+ | - WiFi navigation and AIS data server to charting apps such as iSailor, Navionics, iNavX, Aqua Map. | ||
+ | - The perfect Anchor alarm, for features and details see [[https:// | ||
+ | - Automatic log book | ||
+ | The [[https:// | ||
+ | For more information on Signal K on Venus OS, see below chapter. | ||
Line 19: | Line 28: | ||
There is and will be no official support on the functionalities of Venus OS large. | There is and will be no official support on the functionalities of Venus OS large. | ||
- | For support, turn to the [[https:// | + | For support, turn to the [[https:// |
- | There, first search if someone else had a similar question already. And if you can’t find such, then create a new question. | + | There, first search if someone else had a similar question already. And if you can’t find such, then create a new question. Make sure you add Node-RED to the topic. |
Line 30: | Line 39: | ||
+ | * Ekrano GX | ||
* Cerbo GX | * Cerbo GX | ||
+ | * Cerbo-S GX | ||
* Venus GX | * Venus GX | ||
* Octo GX | * Octo GX | ||
Line 43: | Line 54: | ||
Line 79: | Line 90: | ||
Line 116: | Line 127: | ||
The Node-RED editor can be accessed from your LAN at https:// | The Node-RED editor can be accessed from your LAN at https:// | ||
- | __Standard nodes + Victron nodes__ | + | ==== 5.3 Node specifications ==== |
Node-RED comes with a core set of useful nodes, and within the Venus OS large install there is a set of Victron nodes added to that: the Victron Pallet. All of the different nodes are described [[https:// | Node-RED comes with a core set of useful nodes, and within the Venus OS large install there is a set of Victron nodes added to that: the Victron Pallet. All of the different nodes are described [[https:// | ||
For developers: source code for the node-red-contrib-victron modules is [[https:// | For developers: source code for the node-red-contrib-victron modules is [[https:// | ||
==== 5.2 Back-up and restore ==== | ==== 5.2 Back-up and restore ==== | ||
Line 185: | Line 211: | ||
=== Charger relays === | === Charger relays === | ||
- | The only charger which has a relay that is controllable is the Phoenix | + | The only charger which has a relay that is controllable is the Smart IP43 Charger. To use that for remote control, set its mode, using the VictronConnect app, to be remote controllable. Note that its use is limited: the relay is only powered (and thus only controllable) when the charger is switched on. It doesn' |
==== 5.5 Node-RED Dashboard ==== | ==== 5.5 Node-RED Dashboard ==== | ||
Line 192: | Line 218: | ||
Line 208: | Line 234: | ||
There are more configuration files in ''/ | There are more configuration files in ''/ | ||
Line 217: | Line 244: | ||
For more information on such Node-RED configuration customisations, | For more information on such Node-RED configuration customisations, | ||
- | ==== 5.7. Node-RED FAQ ==== | + | ==== 5.7. Ready-to-use solutions |
- | === Q: Write/read file gives " | + | Node-RED can also be used for doing more advanced tasks. Some examples of ready-to-use solutions are: |
+ | * [[https:// | ||
Since Venus OS 2.90 and on wards, Node-RED no longer runs as user '' | Since Venus OS 2.90 and on wards, Node-RED no longer runs as user '' | ||
Line 229: | Line 287: | ||
- | === Q: How do I restart Node-RED from the Venus GUI? === | + | === Q4: How do I restart Node-RED from the Venus GUI? === |
In order to restart Node-RED you need to disable and enable it from the menu. You can find this under //Venus OS Large Features -> Node-RED//. | In order to restart Node-RED you need to disable and enable it from the menu. You can find this under //Venus OS Large Features -> Node-RED//. | ||
- | === Q: How does safe mode work and what is it? === | + | === Q5: How does safe mode work and what is it? === |
From the Venus GUI you can select Node-RED to be enabled in "safe mode". This means that Node-RED will start without starting the flows. This allows you to open the flows in the editor and make changes without the flows running. When you deploy your changes, the flows are then started. The safe mode can be handy if one of the flows has an error that causes high CPU loads on the Venus device or other issues. | From the Venus GUI you can select Node-RED to be enabled in "safe mode". This means that Node-RED will start without starting the flows. This allows you to open the flows in the editor and make changes without the flows running. When you deploy your changes, the flows are then started. The safe mode can be handy if one of the flows has an error that causes high CPU loads on the Venus device or other issues. | ||
- | === Q: Can I install the @signalk/ | + | === Q6: Can I install the @signalk/ |
No, at least not into the node-red instance which comes as part of Venus OS Large. To @signalk/ | No, at least not into the node-red instance which comes as part of Venus OS Large. To @signalk/ | ||
Line 249: | Line 307: | ||
- install the Victron pallette into the Node-RED thats part of SignalK server | - install the Victron pallette into the Node-RED thats part of SignalK server | ||
- | === Q: I get the error: Failed to remove, unrecognised module === | + | === Q7: I get the error: Failed to remove, unrecognised module === |
This is seen when trying to remove a module that has been previously uninstalled, | This is seen when trying to remove a module that has been previously uninstalled, | ||
Line 261: | Line 319: | ||
After following these steps Node-RED should know about the module again and you should be able to remove or upgrade it. | After following these steps Node-RED should know about the module again and you should be able to remove or upgrade it. | ||
- | === Q: The browser complains about non private connection === | + | === Q8: The browser complains about non private connection === |
Node-RED on Venus now uses SSL for its connection. As the certificate is signed by a "self signed certificate", | Node-RED on Venus now uses SSL for its connection. As the certificate is signed by a "self signed certificate", | ||
Another implication might be that you need to prepend the connection with '' | Another implication might be that you need to prepend the connection with '' | ||
+ | module.exports = { | ||
Line 272: | Line 349: | ||
Line 278: | Line 355: | ||
+ | * Auqua Map | ||
+ | * iNavX | ||
+ | * iSailor | ||
+ | * Navionics | ||
Line 295: | Line 376: | ||
+ | * [[https://discord.gg/uuZrwz4dCS | ||
Line 351: | Line 417: | ||
Line 364: | Line 429: | ||
Line 369: | Line 435: | ||
+ | === Cerbo GX === | ||
+ | === Cerbo GX MK2 === | ||
+ | === Ekrano GX === | ||
Line 395: | Line 486: | ||
+ | # https:// | ||
+ | cp / | ||
+ | npm list -g | ||
+ | # /usr/lib | ||
+ | # ├── node-red@3.1.0 | ||
+ | # ├── npm@9.5.1 | ||
+ | svc -d / | ||
+ | ## Restore that file | ||
+ | mv / | ||
+ | cd / | ||
+ | svc -u / | ||
Line 402: | Line 576: | ||
+ | ===== 8. Troubleshooting ===== | ||
+ | ==== 8.1 Disk space issues / data partition full ==== | ||
+ | Using both Signal K Server, as well as Node-RED, it is quite easy to completely fill up the data partition. Which can cause all sorts of issues, like: | ||
+ | - Venus OS itself no longer working correctly, | ||
+ | - Signal K Server refuses to start / no longer works, | ||
+ | - and similar. | ||
+ | Note that Venus OS itself does **not** show a notification or warning when the data disk is full. And know that the other disks are read-only unless remounted to read/write as per [[https:// | ||
+ | Depending on what the issue is, there are a few things you can do: | ||
+ | The '' | ||
+ | root@einstein:/ | ||
+ | Filesystem | ||
+ | devtmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | overlay | ||
+ | The '' | ||
+ | root@Cerbo:/ | ||
+ | 1103640 / | ||
+ | 1099352 / | ||
+ | 1099276 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3920 / | ||
+ | 744 / | ||
+ | 164 / | ||
+ | 160 / | ||
+ | 116 / | ||
+ | 116 / | ||
+ | 164608 / | ||
+ | 160312 / | ||
+ | 160240 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3924 / | ||
+ | 744 / | ||
+ | See [[https:// |
venus-os/large.1663011826.txt.gz · Last modified: 2022-09-12 21:43 by mvader
