venus-os:large
venus-os:large [2021-01-06 22:05] – [Status and where this development is going] mvader | venus-os:large [2025-07-15 23:17] (current) – [5.12 Node-RED FAQ] mvader | ||
====== Venus OS Large image: Signal K and Node-RED ====== | ====== Venus OS Large image: Signal K and Node-RED ====== | ||
- | (DRAFT - THIS DOCUMENT IS ABOUT NOT YET COMPLETELY FINISHED FUNCTIONALITY) | ||
- | This manual documents the " | ||
+ | This manual documents Venus OS Large. Venus OS is the the software running on our [[https:// | ||
+ | **Node-RED** offers PLC like programming for connecting hardware devices, APIs and online services. It provides a browser-based editor that makes it easy to wire together flows. With it, one can for example program a functionality such as activating a relay based on a temperature measurement combined with time. Or make far more complex algorithms, tying relays, measurements, | ||
- | ==== 1.1 Status and where this development is going ==== | + | Also Node-RED features a [[https:// |
- | Currently, these images are available as beta versions. Working well, several users are using this without any issues; and are super happy with the provided functionality. | + | To get a good idea of its possibilities, see the [[https:// |
- | The remaining work are mostly small improvements, | + | **Signal K server** Signal K Server is a server application that runs on a central hub in a boat; in this case a Victron GX device. A few of its most used features are: |
- | There will be two flavours of Venus OS to install: | + | - WiFi navigation and AIS data server |
+ | - The perfect Anchor alarm, for features and details see [[https:// | ||
+ | - Automatic log book | ||
- | - the normal one as we've been building for years now. With all normal & supported functionality. | + | The [[https:// |
- | - the large- aka extended | + | |
- | Switching between them will be easy: a simple switch in the gui. Updating will be easy as well, the online updates will work, just like they do now for the normal images. | + | For more information on Signal K on Venus OS, see below chapter. |
- | For now not that easy yet: installing and updating is done using the offline install method: with usb stick or sd-card. | ||
- | Why not keep it all in one like it has been until now? To save download and install time for the (vast majority) of users that will not use these features. And they increase the download (& installed) size enourmously. | ||
- | More details here: | + | ===== 2. Where to find support ===== |
- | * https:// | + | There is and will be no official support on the functionalities of Venus OS large. |
- | * https:// | + | |
+ | For support, turn to the [[https:// | ||
+ | On Community, first search if someone else had a similar question already. And if you can’t find such, then create a new question. Make sure to tag it with Node-RED. | ||
- | ===== 2. Where to find support ===== | + | **Signal K community** |
- | + | For support | |
- | There is and will be **no official support** on the functionalities included | + | |
===== 3. Requirements ===== | ===== 3. Requirements ===== | ||
==== 3.1 GX Device compatibility ==== | ==== 3.1 GX Device compatibility ==== | ||
- | A compatible GX device: | + | The compatible GX devices are: |
+ | * Ekrano GX | ||
* Cerbo GX | * Cerbo GX | ||
- | * Venus GX (serial number HQ1842 or later, or upgraded to the large partition layout - more information in Appendix A) | + | |
* Octo GX | * Octo GX | ||
* MultiPlus-II GX | * MultiPlus-II GX | ||
* EasySolar-II GX | * EasySolar-II GX | ||
- | The CCGX and CanVU GX are unfortunately not able to run the extended version. | ||
- | Venus OS extended is also available for certain RaspberryPi models. Installation files below, and installation & other raspberrypi specific instructions [[https:// | ||
- | ==== 3.2 CPU & Memory resources ==== | + | The Color Control GX (CCGX) as well as the CanVU GX are unfortunately not able to run Venus OS Large. |
- | Both SignalK as well as Node-red are rather resource intensive software applications to run on the GX Device. From a CPU usage point of view as well as RAM memory. | + | Venus OS large is also available for certain RaspberryPi models. Installation files below, and installation & other raspberrypi specific instructions [[https:// |
- | Ofcourse, how intensive depends on what kind of flows (node-red) or how many messages & handling of them (SignalK) happens in the system. | + | ==== 3.2 CPU & Memory resources ==== |
- | From a GX device | + | Both SignalK as well as Node-RED are rather resource intensive software applications to run on the GX Device. |
- | Cerbo GX is already much faster, as it has a dual core CPU as well as much more RAM. | + | The level of intensity largely depends on the system' |
- | More details about CPU & RAM differences are in this document: https:// | + | From a GX device point of view, from the support models the Venus GX is the one with the least resources. Running both SignalK and Node-RED at the same time will be " |
+ | === Step 1. Preparations === | ||
+ | * __Cerbo GX__ - No preparations required. | ||
+ | * __Venus GX__ - First install & boot v2.73,or a later version. And only thereafter install Venus OS Large. The reason for this is to make sure the partitioning of the flash is per requirements of Venus OS Large. | ||
+ | * __MultiPlus-II GX__ - No preparations required. | ||
+ | * __EasySolar-II GX__ - No preparations required. | ||
+ | * __RaspberryPi 3__ - No preparations required. | ||
+ | * __RaspberryPi 4__ - No preparations required. | ||
+ | Note, when installing on a RaspberryPi, | ||
+ | === Step 2. Update to the latest firmware version (v2.90 or later) === | ||
+ | See Settings -> Firmware -> Online updates. For more information, | ||
+ | === Step 3. Set the image type Venus OS Large === | ||
+ | Go to Settings -> Firmware -> Online updates -> Image type: | ||
+ | This typically takes about 2 minutes. | ||
+ | === Step 4. Verify and enable === | ||
+ | - Verify that the image was successfully installed: go to the Settings menu, and check that under the integrations for availability. | ||
+ | - Enable either Signal K or Node-RED. Note that though its possible to enable both, doing that on a Venus GX is " | ||
+ | Visible once successfully installed, the integration settings: | ||
+ | === How to update === | ||
+ | Both online and offline update methods can be used. The Image type setting, see the How to install chapter, defines what image type is being updated. See the GX manual for more details. | ||
+ | After installing and then enabling either one or both of the features, they need to be configured through a website in your browser. | ||
+ | To access the Node-RED flow editor, type https:// | ||
+ | See [[https:// | ||
+ | {{ https:// | ||
+ | ==== 5.1 Introduction ==== | ||
+ | Node-RED is a tool for connecting hardware devices, APIs and online services in new and interesting ways. It provides a browser-based editor that makes it easy to wire together flows. With it, one can for example program a functionality such as activating a relay based on a temperature measurement. Or make far more complex algorithms, tying relays, measurements, | ||
+ | Also Node-RED features a [[https:// | ||
+ | A good tutorial on how to work with Node-RED is here: https:// | ||
+ | ==== 5.4 Examples ==== | ||
+ | Our most up to date library of examples can be accessed from within Node-RED. See the main menu (accessible from the top right), and then click Import. Or ctrl-i. | ||
- | === Step by step instructions === | + | {{ : |
- | * **Step 1.** (For Venus GX-es with a serial number below HQ1842 only) - first perform the procedure as explained in Appendix A below. Warning, that procedure can only be carried | + | To see the examples when you don't have access to a Node-RED installation and flow-editor, see their copy here: https:// |
- | * **Step 2.** Disable Auto updates. See Settings -> Firmware -> Online updates in Remote Console. | + | |
- | * **Step 3.** Download the latest Venus-OS Extended image from the last comments on [[https:// | + | |
- | * **Step 4.** Install that file using the [[ccgx: | + | |
- | * **Step 5.** Verify that the image was successfully installed: go to Settings | + | |
- | * **Step 6.** Enable either Signal K or Node-RED. Note that though its possible to enable both, doing so on a Venus GX is " | + | |
- | * **Finished**. The Venus OS Extended image has now been installed successfully. Continue in either the Node-RED or the Signal K chapter below. | + | |
- | === Special note for the RaspberryPi | + | ==== 5.5 Back-up and restore ==== |
- | Unfortunately, | + | Just as with other software it is important to keep your Node-RED flows save and secure. We advise you to periodically backup your flows using the palette manager "// |
- | ===== 4. Node-RED ===== | + | |
- | A good tutorial | + | On a fresh installation you can then use the " |
- | The Node-RED editor | + | It is always wise to create an extra backup before performing an update of the firmware. |
- | The username is " | + | Do note that the above instruction only makes a backup of your flows, not of the Node-RED configuration. The configuration |
- | ==== 4.1 Introduction ==== | + | |
- | ==== 4.2 Installing extra nodes ==== | + | ==== 5.6 Installing extra nodes ==== |
- | The Victron | + | The Victron |
- | Read the [[https:// | + | Read the [[https:// |
- | To install new nodes/pallettes | + | To install new nodes/palettes |
Palettes will be installed on the data partition on the GX Device. Which means that they will remain installed when updating Venus OS to a new version. | Palettes will be installed on the data partition on the GX Device. Which means that they will remain installed when updating Venus OS to a new version. | ||
- | it is possible | + | Refer to the remove button in the palette manager |
- | its not possible to remove | + | When installing a newer version of a palette than what is pre-installed |
- | When installing a newer version of a palette than what is pre-installed in Venus OS, node-red | + | Make sure that there is always 30MB of free space remaining on the data partition. One of the [[https:// |
- | Todo add what happens if user has a palette self installed and Venus OS then comes with a newer version pre-installed. | + | ==== 5.7 Controlling relays ==== |
- | Make sure that there is always 30MB of free space remaining on the data partition. TODO: how can a user see that? Also mem usage / mem free & some cpu stats would be nice to see. Maybe with a dashboard & flow? ;o) | + | For a relay to be controllable via Node-RED, it needs to be switched to manual control first. In most cases this needs to be done by using [[https:// |
- | ==== 4.3 Controlling relays ==== | + | ;#; |
- | Controllable, | + | To be able to control the relay(s) on the GX Device, |
- | === MPPT Relay === | + | ;#; |
- | Note that while there is a Victron node that offers to control the relay in a solar charger (only large solar chargers have a relay!), its currently not workable since VictronConnect does not offer the required " | + | {{: |
- | Currently not possible, the driver | + | The relay in a BMV can be controlled. Make sure to set, using VictronConnect, |
- | === Multi & Quattro Relays === | + | The relay in a Lynx Shunt VE.Can can be controlled. Make sure to set the relay function |
- | Includes alarm relays as well as the AC-out 2 relay: its not possible | + | |
- | ===== 5. Signal K ===== | + | The Relay in the Lynx Smart BMS is not available for control via Node-RED. |
- | ==== 5.1 Introduction ==== | + | === SolarCharger MPPT Relay === |
+ | In order to switch the relay via Node-RED, first use VictronConnect to switch the operation mode to //manual control// | ||
+ | Note that only the larger model solar chargers feature a relay. | ||
+ | === (VE.Bus connected-) Multi, Quattro and similar product relays === | ||
+ | First set the relay to //manual control// using VictronConnect. Once that has been done, the relay can be controlled using Node-RED. | ||
+ | ==== 5.8 Node-RED Dashboard ==== | ||
+ | Besides the flow and automation functionally, | ||
+ | It is viewable in a web browser - both locally as well as remote, via the VRM Servers. See chapter 6.2 for how to see it remotely. | ||
+ | The [[https:// | ||
+ | Once that is done, you can find the nodes in the palettes on the left. Once the dashboard has been configured and deployed, an extra tile will appear in the //Venus OS Large// menu on VRM, allowing to connect to the dashboard via VRM. | ||
+ | Example dashboard: | ||
+ | ==== 5.9 Configuration files ==== | ||
+ | ==== 5.10 Ready-to-use solutions ==== | ||
+ | * [[https:// | ||
+ | ==== 5.11 Using data from VRM ==== | ||
+ | ==== 5.12 Node-RED FAQ ==== | ||
+ | === Q2: How can I update the Victron node pallette === | ||
+ | As that pallette is part of the total Venus OS large package, it can only be updated by installing a newer Venus OS large version. | ||
+ | In case you see that there is a newer version Victron pallette available online, and thats not yet shipping in a Venus OS Large version, then the only option is to wait: a new Venus OS Large version is usually made available shortly after updating that pallette. | ||
+ | === Q3: How can I password protect Node-RED / My Node-RED is password protected === | ||
+ | __Venus OS v3.50 and later__ | ||
+ | For systems that have a security profile set (under Settings -> General -> Security Profile), the password protection is linked to the chosen security profile. The password that has been set for either security profile " | ||
+ | __ Venus OS versions prior to v3.50__ | ||
+ | The Node-RED' | ||
+ | In order to restart Node-RED you need to disable and enable it from the menu. You can find this under //Venus OS Large Features -> Node-RED// | ||
+ | - Edit the ''/ | ||
+ | - Start Node-RED | ||
+ | module.exports = { | ||
+ | === Q11: Is there a way to have the context survive reboots? === | ||
+ | By default the context is stored in RAM memory of the GX device only. When the GX device reboots or loses lower, the context information is lost. | ||
+ | In order to keep the context data, it is needed to [[https:// | ||
+ | contextStorage: | ||
+ | default: { | ||
+ | module: " | ||
+ | config: { | ||
+ | flushInterval: | ||
+ | With the above settings, context files will get created periodically in ''/ | ||
+ | ===== 6. Signal K ===== | ||
+ | ==== 6.1 Introduction ==== | ||
- | === 5.1.1 Why have Signal K on your GX Device? === | + | === 6.1.1 Why have Signal K on your GX Device? === |
Line 142: | Line 395: | ||
+ | * Auqua Map | ||
+ | * iNavX | ||
+ | * iSailor | ||
+ | * Navionics | ||
- | === 5.1.2 Instruments compatible with Signal K === | + | === 6.1.2 Instruments compatible with Signal K === |
* All Victron products that can be connected to a GX device | * All Victron products that can be connected to a GX device | ||
Line 155: | Line 412: | ||
- | === 5.1.3 What is Signal K ? === | + | === 6.1.3 What is Signal K ? === |
- | Note that Signal K is not a Victron project. At Victron, we a great fans of sailing, open source as well as community driven projects. And Signal K is a perfect example of such project. And when running on a GX Device its a perfect marriage. | + | Note that Signal K is not a Victron project. At Victron, we are great fans of sailing, open source as well as community driven projects. And Signal K is a perfect example of such project. And when running on a GX Device its a perfect marriage. |
- | === 5.1.4 Signal K - the data format | + | === 6.1.3 Considerations on how to install |
- | Strictly speaking, Signal K is not software but a data format. And Signalk-server is the name of the software. | + | The type of install described in this document, running Venus OS including SignalK, has these advantages: no need to use a rapsberrypi, |
- | This section explains | + | The other common type of Signal K Server install, installed on a RaspberryPi running Raspbian, has the advantages of more flexibility, |
- | Signal K is a modern and open data format | + | There is no one right way for everyone to do this; the best solution will depend on the requirement. |
- | - create a shared data model for marine related data | + | For raspberrypi owners, note that its very easy to try both methods |
- | - make marine related data easy to access, handle | + | |
- | The shared data model allows you to handle the data in a uniform way independent of how the data is produced. In practice this means that you can refer to your battery voltage with `electrical/ | + | ==== 6.2 Documentation |
- | Easy access means that you can use modern standards like HTTP, WebSockets and JSON that are in widespread. There is a wealth of knowledge and skilled people are easy to find, with no special | + | * [[https:// |
- | In Venus OS it brings all the data available in the GX system, including NMEA 2000 data, to a single data model and programming interface. | + | Do not contact normal Victron support for any help on SignalK. Its based on community support, not official support. |
- | === 5.1.3 Considerations on how to install Signal K === | ||
- | The type of install described in this document, running Venus OS including SignalK, has these advantages: TODO elaborate. Doing this was born out of a wish to make SignalK more mainstream, less of a rapsberrypi / hobbieists/ | + | ==== 6.3 First use & configuring ==== |
- | The other common type of SignalK install, installed on a RaspberryPi running Raspbian, has the advantages of more flexibility, | + | Follow these steps to turn your GX into a NMEA to WiFi gateway within 5 minutes. |
- | There is no one right way for everyone to do this; the best solution will depend on the requirement. | + | These instructions assume that your GX device has already been set-up with Venus OS Large, and Signal K is enabled. |
+ | === Step 1. Signal K Admin page === | ||
- | For raspberrypi owners, note that its very easy to try both methods | + | Open a web browser, and go to the Signal K admin page by navigating to http:// |
- | ==== 5.2 Where to find support? ==== | + | {{ : |
- | As above already introduced, use [[https:// | + | === Step 2. Set the admin password |
- | Do not contact normal Victron support | + | Go to Security -> Users and create an admin user for Signal K and protect it with a secure password. |
+ | === Step 3. Vessel information === | ||
+ | Go to Settings and enter some basic information about your boat. | ||
- | ==== 5.3 Signal K details ==== | + | === Step 4. NMEA2000 Can-bus connection |
- | TODO: remove these versions, and replace by a link to the change-log. | + | For NMEA2000 networks, its recommended to have all connected devices use isolated connections. Therefore, when connecting the an NMEA2000 network, we recommend using the Ekrano GX and the Cerbo MK2 GX. Connect |
- | And instead add information on what specifics we do in the Signal K install. | + | Signal K is preconfigured to have its port operational for this. |
- | - Signalk-node version | + | Here is how you can see the preconfigured connection in the Signal K Dashboard: |
- | - Victron Venus Plugin, v1.10.0 | + | |
- | ==== 5.4 First use & configuring ==== | + | ;#; |
- | === Step 1. Opening | + | Note that, to keep that operational, |
- | Open a web browser, and go to the SignalK Dashboard by navigating to http://venus.local:3000. | + | ;#; |
+ | {{:venus-os:cerbo-gx-vecan-nmea2000.png? | ||
- | Further documentation about that is ... (some link to signalk-node documentation? | + | For more information on CAN-busses, see chapter 6.4. |
- | === Step 2. Configure serial connections === | + | === Step 5. Optional: |
- | Use this to, for example, configure a USB-connected NMEA0183 connection in SignalK. | + | Use this to, for example, configure a USB-connected NMEA0183 connection in SignalK. |
- | Make sure to not add a connecting | + | Make sure to not add a connection |
Note that once configured in SignalK, for example a USB-serial port, that port is no longer normally available in Venus OS. For example, when plugging in a USB-GPS; and then adding a connection for its corresponding tty in the SignalK, makes for that GPS to be no longer be recognised and available in Venus OS. | Note that once configured in SignalK, for example a USB-serial port, that port is no longer normally available in Venus OS. For example, when plugging in a USB-GPS; and then adding a connection for its corresponding tty in the SignalK, makes for that GPS to be no longer be recognised and available in Venus OS. | ||
- | === Step 3. Configure can-bus connections | + | === Step 6. Verify received data === |
- | For the Venus GX, SignalK comes pre-configured with a NMEA2000 listener for the VE.Can ports, its named " | + | Go to the Databrowser to see the data now available to Signal K, and to tablets and nav. apps on WiFi: |
- | Note that, to keep that operational, | + | {{ : |
- | === Step 4. Adding Signalk Plugins or Webapps | + | === Step 7. Configure your nav app === |
- | TODO: explain & warn about data partition size & space (since thats where plugins are installed by signalk on Venus OS). Filling up the datapartition can corrupt Venus OS. More information about data partition on Venus OS here: https:// | + | Steps needed here will differ per app. The key required |
- | ==== 5.5 Signal K FAQ ==== | + | * Host/IP address: **venus.local** |
+ | * Protocol: **TCP** | ||
+ | * Port: **10110** | ||
+ | === Done! === | ||
- | === Q1 How to best handle & install a GPS === | + | Now you should have all your data such as position from the boat’s GPS, speed, wind data, as well as AIS targets in your favourite nav app. Like here in Navionics: |
+ | === Where to go from here? Anchor alarms, trip recording, automatic log books and more === | ||
+ | * Anchor alarm: https:// | ||
+ | * Automatic log book & trip recording: https:// | ||
+ | === Cerbo GX === | ||
+ | === Cerbo GX MK2 === | ||
+ | | VE.Can 1 | vecan0 | Isolated and default enabled in SignalK | | ||
+ | === Ekrano GX === | ||
+ | ==== 6.5 Signal K FAQ ==== | ||
+ | === Q1 - How to best handle & install a GPS === | ||
Line 257: | Line 564: | ||
- | ===== 6. Remote access via VRM ===== | ||
- | ==== 6.1 Node-RED flow editor and Signal K ==== | ||
- | === Step by step instructions | + | === Q2 - What happens when I updated a pre-installed Plugin? |
- | * **Step 1.** Log into/open the regular VRM ' | + | |
- | * **Step 2.** Modify the URL to include | + | A few plugins are installed by default on Venus OS Large. These include |
- | * **Step 3.** Click on the **Node-RED** or **Signal K** button in the Proxy relay screen; depending on location and the speed of internet connection, there may be a short delay while loading | + | When a newer version of such plugin is available, it is still possible to install |
- | {{ :venus-os: | + | |
- | * **Step 4.** The Node-RED flow editor or Signal K interface screen | + | The newer version of the plugin gets installed onto the data partition. And Signal K server |
- | ==== 6.2 Node-RED Dashboard/ | + | |
- | It it also possible to access | + | |
- | === Step by step instructions === | + | WARNING: |
- | * **Step 1.** Follow steps #1 to 4 in section 6.1 above in order to ' | + | |
- | * **Step 2.** The ' | + | Note that the same icon is also available for the pre-installed plugins. Pressing it does nothing |
- | * **Step 3.** The Node-RED dashboard/ | + | === Q3 - Can I update signalk-server? === |
- | ===== Appendix A - Repartitioning | + | Signal K Server comes preinstalled with Venus OS. And except by " |
- | The Venus GX has sufficient flash memory | + | The normal -and recommended- method |
- | Perform this procedure only when connected via Ethernet port. | + | In case you can’t wait, and don’t mind the extra work as well as risks, here is how to update it yourself. |
- | Do not use the built-in WiFi AP to performing | + | Be warned, |
- | **WARNING**: | + | Note that all changes made to the rootfs will be overwritten the next time you do a Venus OS update. |
- | It is impossible to brick the device using this procedure. Its always possible to run the installer again. But, to make the device operational again, also the files must be restored, if anything then with other contents. | + | Step 1: Get yourself [[https:// |
- | Venus GX-es with serial number HQ1842xxxxx and later already have the new partition layout from the factory. | + | Step 2: Follow this procedure: |
- | === Requirements === | + | < |
- | * An SD Card | + | ## Backup a file you'll need to restore later |
- | * Computer skills | + | # dev-tip: a list of especially installed files on a Victron install is here: |
+ | # https:// | ||
+ | cp / | ||
- | Note that a USB stick will not work. Installer images can only be ran using an SD Card. | + | ## See version as well as install location for signalk-server |
+ | npm list -g | ||
- | === Step A. Enable and obtain root access === | + | # output will be something like this: |
+ | # /usr/lib | ||
+ | # ├── node-red@3.1.0 | ||
+ | # ├── npm@9.5.1 | ||
- | See [[https://www.victronenergy.com/ | + | ## Stop signalk-server |
+ | svc -d /service/signalk-server | ||
- | === Step B. Secure factory files === | + | ## Update to a newer version, here is how to update to last released version: |
- | Copy below four files to your computer. | + | # And to update to a more specific version, do something similar to this: |
- | * / | + | # Output will be something like this: |
- | * / | + | # added 120 packages, removed 179 packages, and changed 586 packages in 6m |
- | | + | # 57 packages are looking for funding |
- | Below commandline instructions show how to do that on linux from the commandline. For Windows try Mobaxterm, or WinSCP. Putty won't work, its not for transferring files. There is Putty SCP (PSCP), as well, but then you need to know how to handle the commandline in Windows. We recommend using the other two. | + | ## Restore |
+ | mv / | ||
- | Procedure | + | ## Install the signalk-venus-plugin in same place where it normally is on Venus OS |
+ | cd / | ||
- | < | + | ## If you want, see updated version: |
- | mkdir my-temp | + | npm list -g |
- | cd my-temp | + | |
- | mkdir conf | + | # output will be similar as above, but then with newer version |
- | mkdir venus | + | |
- | scp " | + | ## start signalk-server again, and see log output: |
- | scp " | + | svc -u / |
+ | ===== 7. Remote access via VRM ===== | ||
- | === Background information on the factory files === | + | The three available web interfaces, |
- | The first two are needed for the built-in accesspoint to work. Without | + | After enabling |
- | Third file is not used anywhere (at this moment), but easy enough to recreate by hand as well. | + | {{ : |
- | Fourth file: without it the system won't be able to send data to VRM anymore. Either make sure to keep that file, or after having booted the new version, go to the VRM Portal, Settings -> General. And scroll to the bottom. There will be an option to reset the token. This option is only visible after the portal has received data from the reflashed device. | + | ===== 8. Troubleshooting ===== |
- | === Step C. Run the installer image === | + | ==== 8.1 Disk space issues / data partition full ==== |
- | First, download | + | Using both Signal K Server, as well as Node-RED, it is possible to completely fill up the data partition. |
- | Then, write it to an sdcard (tip: use BalenaEtcher, see Google) | + | The GX device will issue a warning, #46 Data partition full, as soon as the free space of the data partition is below 5%. |
- | Finally, run the installer by inserting the sdcard containing the installer, and then power up while pressing the small recessed button on the right of the long green connector with, for example, a paperclip. | + | To see the exact free space, go to Settings -> General -> Modifications. |
- | There is a bi-color LED on the other side of the same long green connector, indicating the status: | + | Having the data partition full will lead to unexpected results. The system |
- | Side info: see here for more details | + | Depending |
- | Once done, reboot | + | - Remove all Node-RED flows and installed node palettes. See next chapter on how to do that. |
+ | - Remove all Signal K Server log files. In case you're using SignalK, then we recommend to try that option first. See next chapter on how to do that (requires a USB stick or SD Card), and once done make sure to double check you're Signal K log setup; Most importantly, make sure that the '' | ||
+ | - A more detailed approach is logging into the SSH console, and checking for disk space: | ||
- | After the boot (30 to 60 seconds) the LED will be slow blinking green. Indicating that the WiFi access point is off (as expected). More information about the LED operation is in the Venus GX manual. | + | **Tips and tricks |
- | Now, re-obtain yourself root access to continue. Note that all settings will be wiped by the installer: | + | |
- | * you'll need to go to Remote Console on LAN, then change | + | Require root access: https://www.victronenergy.com/ |
- | * As warned above, you’ll need to do this on the LAN port. The built-in WiFi access-point will be disabled, and any previously configured WiFi (client-) configuration will be lost as the installer will have wiped all settings. | + | |
- | === Step D. Restore | + | The '' |
- | Again, this is how to do it on Linux: | + | < |
+ | root@einstein:/ | ||
+ | Filesystem | ||
+ | devtmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | overlay | ||
+ | The '' | ||
- | scp ./ | + | root@Cerbo:/ |
- | scp ./venus/* " | + | 1103640 / |
+ | 1099352 / | ||
+ | 1099276 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 /data/ | ||
+ | 3920 /data/log | ||
+ | 744 / | ||
+ | 164 / | ||
+ | 160 / | ||
+ | 116 / | ||
+ | 116 / | ||
+ | </code> | ||
- | # reboot | + | This is a view of a more healthy tree: |
- | ssh 192.168.178.122 reboot | + | < |
+ | root@Cerbo:/ | ||
+ | 164608 / | ||
+ | 160312 / | ||
+ | 160240 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3924 / | ||
+ | 744 / | ||
- | Once completed, the WiFi access point will be operational again. | + | ==== 8.2 Backup / Reset to factory defaults |
+ | There are scenarios where you want to make a backup of your data or when you want to clear logging or even start all over and go back to factory defaults. In order to make this process easy, you can put one (or more) of the following files on an USB stick and reboot your device. The files will be unpacked and the scripts within will execute. | ||
- | === Step E. Install extended Venus OS === | + | * [[https:// |
- | Now, the Venus GX has been repartitioned, | + | See [[https:// |
venus-os/large.1609967102.txt.gz · Last modified: by mvader
