venus-os:large
venus-os:large [2024-02-18 17:52] – [6.4 First use & configuring] mvader | venus-os:large [2024-03-03 12:38] – [8.1 Disk space issues / data partition full] mvader | ||
Line 587: | Line 587: | ||
Note that Venus OS itself does **not** show a notification or warning when the data disk is full. And know that the other disks are read-only unless remounted to read/write as per [[https:// | Note that Venus OS itself does **not** show a notification or warning when the data disk is full. And know that the other disks are read-only unless remounted to read/write as per [[https:// | ||
- | The easy solution | + | Depending on what the issue is, there are a few things you can do: |
- | A more detailed approach is logging in on SSH, and checking for disk space. Here are a few useful commands. | + | - Do full GX factory reset, as per the instructions in the GX user manuals. This includes downloading a file called venus-data.tgz; |
The '' | The '' |
