venus-os:large
venus-os:large [2021-11-26 12:07] – [5.1 Introduction] dfaber | venus-os:large [2022-05-11 08:53] – dfaber | ||
Line 132: | Line 132: | ||
Line 148: | Line 148: | ||
When installing a newer version of a palette than what is pre-installed in Venus OS, node-red will use that newer version. | When installing a newer version of a palette than what is pre-installed in Venus OS, node-red will use that newer version. | ||
==== 5.3 Controlling relays ==== | ==== 5.3 Controlling relays ==== | ||
Line 183: | Line 183: | ||
==== 5.5. Node-RED FAQ ==== | ==== 5.5. Node-RED FAQ ==== | ||
+ | === Q: Write/read file gives " | ||
=== Q: How can I update the Victron node pallette === | === Q: How can I update the Victron node pallette === | ||
Line 193: | Line 197: | ||
+ | === Q: How do I restart Node-RED from the Venus GUI? === | ||
+ | === Q: How does safe mode work and what is it? === | ||
=== Q: Can I install the @signalk/ | === Q: Can I install the @signalk/ |
