venus-os:large
venus-os:large [2021-11-26 12:07] – [5.1 Introduction] dfaber | venus-os:large [2022-02-07 17:11] – [5.2 Installing extra nodes] dfaber | ||
Line 132: | Line 132: | ||
Line 148: | Line 148: | ||
When installing a newer version of a palette than what is pre-installed in Venus OS, node-red will use that newer version. | When installing a newer version of a palette than what is pre-installed in Venus OS, node-red will use that newer version. | ||
==== 5.3 Controlling relays ==== | ==== 5.3 Controlling relays ==== | ||
Line 193: | Line 193: | ||
+ | === Q: How do I restart Node-RED from the Venus GUI? === | ||
+ | === Q: How does safe mode work and what is it? === | ||
=== Q: Can I install the @signalk/ | === Q: Can I install the @signalk/ |
