Both sides previous revision
Both sides next revision
venus-os:large [2021-11-25 16:37] dfaber [1.1 Venus OS Large, Node-RED and Signal K server?] |
venus-os:large [2021-11-26 12:07] dfaber [5.1 Introduction] |
Also Node-RED features a [[https://flows.nodered.org/node/node-red-dashboard|fully customisable dashboard]], viewable in a webbrowser - both locally but also remotely, via the VRM Servers. | Also Node-RED features a [[https://flows.nodered.org/node/node-red-dashboard|fully customisable dashboard]], viewable in a webbrowser - both locally but also remotely, via the VRM Servers. |
A good tutorial on how to work with Node-RED is here: https://nodered.org/docs/tutorials/first-flow. | A good tutorial on how to work with Node-RED is here: https://nodered.org/docs/tutorials/first-flow. On https://github.com/victronenergy/node-red-contrib-victron/wiki/Example-Flows you can find example flows that use the Victron Energy nodes. |
The Node-RED editor is at http://venus.local:1880/. For some systems, you'll have to replace ''venus.local'' by the ip-address. | The Node-RED editor can be accessed from your LAN at http://venus.local:1880/. For some systems, you'll have to replace ''venus.local'' by the ip-address. You can also access the Node-RED editor from VRM, where it is available via the //Venus OS Large// menu. |
Please note that updating the ''@victronenergy/node-red-contrib-victron'' module is not (yet) possible from either the Node-RED UI as the commandline. The recommended way to get to the new node-red-contrib-victron version is to await a new Venus OS large build. | Please note that updating the ''@victronenergy/node-red-contrib-victron'' module is not possible from either the Node-RED editor as the commandline. The recommended way to get to the new node-red-contrib-victron version is to await a new Venus OS large build. |
==== 5.2 Installing extra nodes ==== | ==== 5.2 Installing extra nodes ==== |
