venus-os:large
venus-os:large [2021-11-25 14:46] – [1.1 Venus OS Large, Node-RED and Signal K server?] dfaber | venus-os:large [2024-04-03 19:07] – [5.1 Introduction] mvader | ||
Line 2: | Line 2: | ||
+ | **Node-RED** | ||
- | From VRM, a connection to Node-RED, the Node-RED dashboard | + | |
- | {{ :venus-os:large-proxy.png? | + | |
+ | - Automatic log book | ||
- | Note that only the services that are enabled are shown in the VRM menu. | + | The [[https:// |
- | ==== 1.2 Status and where this development is going ==== | + | |
- | Currently, these images are available as beta versions. They work well, several users are using this without any issues; and are super happy with the provided functionality. | + | For more information on Signal K on Venus OS, see below chapter. |
- | The remaining work are mostly small improvements, | ||
- | - the normal one as we've been building for years now. With all normal & supported functionality. | + | ===== 2. Where to find support ===== |
- | - the large flavour. All the same as the normal one, but with addition of Signal K & Node-RED. | + | |
- | Switching between them will be easy: a simple switch in the gui. Updating will be easy as well, the online updates will work, just like they do now for the normal images. | + | There is and will be no official support on the functionalities of Venus OS large. |
- | For now not that easy yet: installing and updating is done using the offline install method: with usb stick or sd-card. | + | For support, turn to the [[https://community.victronenergy.com/spaces/31/index.html|Modifications Space on Victron Community]] and/or the [[https://community.victronenergy.com/smart-spaces/71/node-red.html|Node-RED Space on Victron Community]]. |
- | Why not keep it all in one like it has been until now? To save download and install time for the (vast majority) of users that will not use these features. These new features increase the download (& installed) size enormously, and also they are really cool; but do not fall within normal Victron support. Which is why we want to keep them separate. | + | |
Line 49: | Line 39: | ||
+ | * Ekrano GX | ||
* Cerbo GX | * Cerbo GX | ||
+ | * Cerbo-S GX | ||
* Venus GX | * Venus GX | ||
* Octo GX | * Octo GX | ||
Line 56: | Line 48: | ||
Line 62: | Line 54: | ||
Line 70: | Line 62: | ||
Line 78: | Line 70: | ||
- | | RaspberryPi3 | + | |
- | | RaspberryPi4 | + | |
+ | See [[https:// | ||
Line 122: | Line 127: | ||
- | The Node-RED editor | + | It is always wise to create an extra backup before performing an update of the firmware. |
Line 146: | Line 179: | ||
Line 159: | Line 192: | ||
+ | === SolarCharger | ||
Line 175: | Line 218: | ||
+ | * [[https:// | ||
+ | The [[https:// | ||
Line 190: | Line 287: | ||
- | === Q: Can I install the @signalk/ | + | === Q4: How do I restart Node-RED from the Venus GUI? === |
+ | In order to restart Node-RED you need to disable and enable it from the menu. You can find this under //Venus OS Large Features -> Node-RED// | ||
No, at least not into the node-red instance which comes as part of Venus OS Large. To @signalk/ | No, at least not into the node-red instance which comes as part of Venus OS Large. To @signalk/ | ||
Line 201: | Line 306: | ||
- disable the Venus OS Node-RED, in GX Device -> Settings -> Venus OS Large -> Node-RED | - disable the Venus OS Node-RED, in GX Device -> Settings -> Venus OS Large -> Node-RED | ||
- install the Victron pallette into the Node-RED thats part of SignalK server | - install the Victron pallette into the Node-RED thats part of SignalK server | ||
+ | - Edit the ''/ | ||
+ | - Start Node-RED | ||
+ | module.exports = { | ||
Line 207: | Line 349: | ||
Line 213: | Line 355: | ||
+ | * Auqua Map | ||
+ | * iNavX | ||
+ | * iSailor | ||
+ | * Navionics | ||
Line 230: | Line 376: | ||
+ | * [[http:// | ||
Line 294: | Line 417: | ||
Line 307: | Line 429: | ||
Line 312: | Line 435: | ||
+ | === Cerbo GX === | ||
+ | === Cerbo GX MK2 === | ||
+ | === Ekrano GX === | ||
Line 338: | Line 486: | ||
+ | # https:// | ||
+ | cp / | ||
+ | npm list -g | ||
+ | # /usr/lib | ||
+ | # ├── node-red@3.1.0 | ||
+ | # ├── npm@9.5.1 | ||
+ | svc -d / | ||
+ | ## Restore that file | ||
+ | mv / | ||
+ | cd / | ||
+ | svc -u / | ||
- | {{ :venus-os: | + | |
+ | - and similar. | ||
+ | The '' | ||
+ | root@einstein:/ | ||
+ | Filesystem | ||
+ | devtmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | overlay | ||
+ | The '' | ||
+ | root@Cerbo:/ | ||
+ | 1103640 / | ||
+ | 1099352 / | ||
+ | 1099276 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3920 / | ||
+ | 744 / | ||
+ | 164 / | ||
+ | 160 / | ||
+ | 116 / | ||
+ | 116 / | ||
+ | 164608 / | ||
+ | 160312 / | ||
+ | 160240 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3924 / | ||
+ | 744 / | ||
