venus-os:large
venus-os:large [2021-10-15 09:16] – [5.5. Node-RED FAQ] mvader | venus-os:large [2024-03-03 12:38] – [8.1 Disk space issues / data partition full] mvader | ||
Line 2: | Line 2: | ||
+ | **Node-RED** | ||
+ | - Automatic log book | ||
Line 45: | Line 39: | ||
+ | * Ekrano GX | ||
* Cerbo GX | * Cerbo GX | ||
+ | * Cerbo-S GX | ||
* Venus GX | * Venus GX | ||
* Octo GX | * Octo GX | ||
Line 52: | Line 48: | ||
Line 58: | Line 54: | ||
Line 66: | Line 62: | ||
Line 74: | Line 70: | ||
- | | RaspberryPi3 | + | |
- | | RaspberryPi4 | + | |
+ | See [[https:// | ||
Line 118: | Line 127: | ||
+ | There is also a 3 part introductory webinar on Node-RED and Venus available at the Victron Tech YouTube channel: | ||
+ | __Standard nodes + Victron nodes__ | ||
- | The Node-RED editor | + | It is always wise to create an extra backup before performing an update of the firmware. |
Line 142: | Line 176: | ||
Line 155: | Line 189: | ||
+ | === SolarCharger | ||
Line 171: | Line 215: | ||
- | === Q: How can I update the Victron node pallette === | + | WARNING: the vast majority of systems using Node-RED will not, and should not (!), have to modify any of the files here described. Venus OS itself, including Venus OS large and Node-RED, is made such that its not necessary to dive into the command line. |
+ | * [[https:// | ||
+ | The [[https:// | ||
+ | === Q2: How can I update the Victron node pallette === | ||
Line 186: | Line 284: | ||
- | === Q: Can I install the @signalk/ | + | === Q4: How do I restart Node-RED from the Venus GUI? === |
+ | In order to restart Node-RED you need to disable and enable it from the menu. You can find this under //Venus OS Large Features -> Node-RED// | ||
No, at least not into the node-red instance which comes as part of Venus OS Large. To @signalk/ | No, at least not into the node-red instance which comes as part of Venus OS Large. To @signalk/ | ||
Line 197: | Line 303: | ||
- disable the Venus OS Node-RED, in GX Device -> Settings -> Venus OS Large -> Node-RED | - disable the Venus OS Node-RED, in GX Device -> Settings -> Venus OS Large -> Node-RED | ||
- install the Victron pallette into the Node-RED thats part of SignalK server | - install the Victron pallette into the Node-RED thats part of SignalK server | ||
+ | - Edit the ''/ | ||
+ | - Start Node-RED | ||
+ | module.exports = { | ||
Line 203: | Line 346: | ||
Line 209: | Line 352: | ||
+ | * Auqua Map | ||
+ | * iNavX | ||
+ | * iSailor | ||
+ | * Navionics | ||
Line 226: | Line 373: | ||
+ | * [[http:// | ||
Line 290: | Line 414: | ||
Line 303: | Line 426: | ||
Line 308: | Line 432: | ||
+ | === Cerbo GX === | ||
+ | === Cerbo GX MK2 === | ||
+ | === Ekrano GX === | ||
Line 334: | Line 483: | ||
+ | # https:// | ||
+ | cp / | ||
+ | npm list -g | ||
+ | # /usr/lib | ||
+ | # ├── node-red@3.1.0 | ||
+ | # ├── npm@9.5.1 | ||
+ | svc -d / | ||
+ | ## Restore that file | ||
+ | mv / | ||
+ | cd / | ||
+ | svc -u / | ||
- | {{ :venus-os: | + | |
+ | - and similar. | ||
+ | The '' | ||
+ | root@einstein:/ | ||
+ | Filesystem | ||
+ | devtmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | overlay | ||
+ | The '' | ||
+ | root@Cerbo:/ | ||
+ | 1103640 / | ||
+ | 1099352 / | ||
+ | 1099276 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3920 / | ||
+ | 744 / | ||
+ | 164 / | ||
+ | 160 / | ||
+ | 116 / | ||
+ | 116 / | ||
+ | 164608 / | ||
+ | 160312 / | ||
+ | 160240 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3924 / | ||
+ | 744 / | ||
