venus-os:large
venus-os:large [2021-10-15 09:16] – [5.5. Node-RED FAQ] mvader | venus-os:large [2021-12-10 10:36] – [5.2 Installing extra nodes] dfaber | ||
Line 12: | Line 12: | ||
**Signal K server** is aimed for yachts, and multiplexes data from NMEA0183, NMEA 2000, Signal K and other sensor inputs. It makes all that data available for Apps, such as [[https:// | **Signal K server** is aimed for yachts, and multiplexes data from NMEA0183, NMEA 2000, Signal K and other sensor inputs. It makes all that data available for Apps, such as [[https:// | ||
+ | From VRM, a connection to Node-RED, the Node-RED dashboard and Signal K can be made. | ||
+ | Note that only the services that are enabled are shown in the VRM menu. | ||
==== 1.2 Status and where this development is going ==== | ==== 1.2 Status and where this development is going ==== | ||
Line 118: | Line 122: | ||
- | The Node-RED editor | + | The Node-RED editor |
- | Please note that updating the '' | + | Please note that updating the '' |
==== 5.2 Installing extra nodes ==== | ==== 5.2 Installing extra nodes ==== | ||
Line 128: | Line 132: | ||
Line 189: | Line 193: | ||
+ | === Q: How do I restart Node-RED from the Venus GUI? === | ||
+ | === Q: How does safe mode work and what is it? === | ||
=== Q: Can I install the @signalk/ | === Q: Can I install the @signalk/ |
