venus-os:large [2021-10-15 09:16] – [5.5. Node-RED FAQ] mvader | venus-os:large [2021-11-26 12:07] – [5.1 Introduction] dfaber |
**Signal K server** is aimed for yachts, and multiplexes data from NMEA0183, NMEA 2000, Signal K and other sensor inputs. It makes all that data available for Apps, such as [[https://www.wilhelmsk.com/|WilhelmSK]], a highly customizable boat instrument display. The [[https://www.victronenergy.com/blog/2019/06/13/sailing-with-signal-k/|Sailing with Signal K blogpost on our website]] is a great read for more information and ideas. | **Signal K server** is aimed for yachts, and multiplexes data from NMEA0183, NMEA 2000, Signal K and other sensor inputs. It makes all that data available for Apps, such as [[https://www.wilhelmsk.com/|WilhelmSK]], a highly customizable boat instrument display. The [[https://www.victronenergy.com/blog/2019/06/13/sailing-with-signal-k/|Sailing with Signal K blogpost on our website]] is a great read for more information and ideas. |
| From VRM, a connection to Node-RED, the Node-RED dashboard and Signal K can be made. |
| {{ :venus-os:large-proxy.png?1024 |}} |
| Note that only the services that are enabled are shown in the VRM menu. |
==== 1.2 Status and where this development is going ==== | ==== 1.2 Status and where this development is going ==== |
Also Node-RED features a [[https://flows.nodered.org/node/node-red-dashboard|fully customisable dashboard]], viewable in a webbrowser - both locally but also remotely, via the VRM Servers. | Also Node-RED features a [[https://flows.nodered.org/node/node-red-dashboard|fully customisable dashboard]], viewable in a webbrowser - both locally but also remotely, via the VRM Servers. |
A good tutorial on how to work with Node-RED is here: https://nodered.org/docs/tutorials/first-flow. | A good tutorial on how to work with Node-RED is here: https://nodered.org/docs/tutorials/first-flow. On https://github.com/victronenergy/node-red-contrib-victron/wiki/Example-Flows you can find example flows that use the Victron Energy nodes. |
The Node-RED editor is at http://venus.local:1880/. For some systems, you'll have to replace ''venus.local'' by the ip-address. | The Node-RED editor can be accessed from your LAN at http://venus.local:1880/. For some systems, you'll have to replace ''venus.local'' by the ip-address. You can also access the Node-RED editor from VRM, where it is available via the //Venus OS Large// menu. |
Please note that updating the ''@victronenergy/node-red-contrib-victron'' module is not (yet) possible from either the Node-RED UI as the commandline. The recommended way to get to the new node-red-contrib-victron version is to await a new Venus OS large build. | Please note that updating the ''@victronenergy/node-red-contrib-victron'' module is not possible from either the Node-RED editor as the commandline. The recommended way to get to the new node-red-contrib-victron version is to await a new Venus OS large build. |
==== 5.2 Installing extra nodes ==== | ==== 5.2 Installing extra nodes ==== |
