venus-os:large
venus-os:large [2021-10-15 09:16] – [5.5. Node-RED FAQ] mvader | venus-os:large [2021-11-25 16:37] – [1.1 Venus OS Large, Node-RED and Signal K server?] dfaber | ||
Line 12: | Line 12: | ||
**Signal K server** is aimed for yachts, and multiplexes data from NMEA0183, NMEA 2000, Signal K and other sensor inputs. It makes all that data available for Apps, such as [[https:// | **Signal K server** is aimed for yachts, and multiplexes data from NMEA0183, NMEA 2000, Signal K and other sensor inputs. It makes all that data available for Apps, such as [[https:// | ||
+ | From VRM, a connection to Node-RED, the Node-RED dashboard and Signal K can be made. | ||
+ | Note that only the services that are enabled are shown in the VRM menu. | ||
==== 1.2 Status and where this development is going ==== | ==== 1.2 Status and where this development is going ==== | ||
