venus-os:large
venus-os:large [2021-04-07 15:08] – [1.2 Status and where this development is going] mvader | venus-os:large [2024-04-03 19:07] (current) – [5.1 Introduction] mvader | ||
Line 2: | Line 2: | ||
+ | **Node-RED** | ||
+ | - Automatic log book | ||
Line 45: | Line 39: | ||
+ | * Ekrano GX | ||
* Cerbo GX | * Cerbo GX | ||
+ | * Cerbo-S GX | ||
* Venus GX | * Venus GX | ||
* Octo GX | * Octo GX | ||
Line 52: | Line 48: | ||
Line 58: | Line 54: | ||
Line 66: | Line 62: | ||
* __Cerbo GX__ - No preparations required. | * __Cerbo GX__ - No preparations required. | ||
- | * __Venus GX__ - In case your Venus GX has a serial number below HQ1842, perform | + | * __Venus GX__ - First install & boot v2.73,or a later version. And only thereafter install Venus OS Large. The reason for this is to make sure the partitioning of the flash is per requirements of Venus OS Large. |
- | * __RaspberryPi 3__ - Unfortunately, | + | * __RaspberryPi 3__ - No preparations required. |
- | | RaspberryPi3 | + | |
- | | RaspberryPi4 | + | |
- | ===== 4. Node-RED ===== | + | === How to update |
+ | Both online and offline update methods can be used. The Image type setting, see the How to install chapter, defines what image type is being updated. See the GX manual for more details. | ||
- | ==== 4.1 Introduction ==== | + | After installing and then enabling either one or both of the features, they need to be configured through a website in your browser. |
+ | To access the Node-RED flow editor, type https:// | ||
+ | See [[https:// | ||
+ | === Node-RED flow editor | ||
+ | ==== 5.1 Introduction ==== | ||
Node-RED is a tool for connecting hardware devices, APIs and online services in new and interesting ways. It provides a browser-based editor that makes it easy to wire together flows. With it, one can for example program a functionality such as activating a relay based on a temperature measurement. Or make far more complex algorithms, tying relays, measurements, | Node-RED is a tool for connecting hardware devices, APIs and online services in new and interesting ways. It provides a browser-based editor that makes it easy to wire together flows. With it, one can for example program a functionality such as activating a relay based on a temperature measurement. Or make far more complex algorithms, tying relays, measurements, | ||
Line 112: | Line 127: | ||
- | The Node-RED editor is at http:// | + | ==== 5.2 Three part introductory webinar ==== |
- | The username | + | This is a 3 part introductory webinar on Node-RED and Venus available at the Victron Tech YouTube channel: |
- | ==== 4.2 Installing extra nodes ==== | + | |
+ | Node-RED comes with a core set of useful nodes, and within | ||
+ | It is always wise to create an extra backup before performing an update of the firmware. | ||
+ | Do note that the above instruction only makes a backup of your flows, not of the Node-RED configuration. The configuration is stored in '' | ||
+ | ==== 5.3 Installing extra nodes ==== | ||
Line 135: | Line 179: | ||
- | ==== 4.3 Controlling relays ==== | + | ==== 5.4 Controlling relays ==== |
Line 148: | Line 192: | ||
+ | The relay in a Lynx Shunt VE.Can can be controlled. Make sure to set the relay function to " | ||
- | === MPPT Relay === | + | === SolarCharger |
- | ==== 4.4 Node-RED Dashboard ==== | + | === (VE.Bus connected-) Multi, Quattro and similar product relays === |
Line 164: | Line 218: | ||
- | Once that is done, you can find the nods in the palettes on the left. | + | Once that is done, you can find the nodes in the palettes on the left. Once the dashboard has been configured and deployed, an extra tile will appear in the //Venus OS Large// menu on VRM, allowing to connect to the dashboard via VRM. |
- | ===== 5. Signal K ===== | + | ==== 5.6 Configuration files ==== |
- | ==== 5.1 Introduction ==== | + | WARNING: the vast majority of systems using Node-RED will not, and should not (!), have to modify any of the files here described. Venus OS itself, including Venus OS large and Node-RED, is made such that its not necessary to dive into the command line. |
+ | * [[https:// | ||
+ | The [[https:// | ||
+ | === Q2: How can I update the Victron node pallette === | ||
+ | As that pallette is part of the total Venus OS large package, it can only be updated by installing a newer Venus OS large version. | ||
+ | In case you see that there is a newer version Victron pallette available online, and thats not yet shipping in a Venus OS Large version, then the only option is to wait: a new Venus OS Large version is usually made available shortly after updating that pallette. | ||
+ | === Q3: How can I password protect Node-RED === | ||
+ | Password protection of Node-Red is linked to the remote console. If a password is set for the remote console, this password is also used for securing Node-Red. The username is '' | ||
+ | In order to restart Node-RED you need to disable and enable it from the menu. You can find this under //Venus OS Large Features -> Node-RED// | ||
+ | - Edit the ''/ | ||
+ | - Start Node-RED | ||
+ | module.exports = { | ||
+ | ===== 6. Signal K ===== | ||
+ | ==== 6.1 Introduction ==== | ||
- | === 5.1.1 Why have Signal K on your GX Device? === | + | === 6.1.1 Why have Signal K on your GX Device? === |
Line 183: | Line 355: | ||
+ | * Auqua Map | ||
+ | * iNavX | ||
+ | * iSailor | ||
+ | * Navionics | ||
- | === 5.1.2 Instruments compatible with Signal K === | + | === 6.1.2 Instruments compatible with Signal K === |
* All Victron products that can be connected to a GX device | * All Victron products that can be connected to a GX device | ||
Line 196: | Line 372: | ||
- | === 5.1.3 What is Signal K ? === | + | === 6.1.3 What is Signal K ? === |
- | === 5.1.4 Signal K - the data format | + | === 6.1.3 Considerations on how to install |
- | Strictly speaking, Signal K is not software but a data format. And Signalk-server is the name of the software. | + | The type of install described in this document, running Venus OS including SignalK, has these advantages: no need to use a rapsberrypi, |
- | This section explains the rationale behind the data format. | + | The other common type of Signal K Server |
- | Signal K is a modern and open data format for marine use. Its goal is to | + | |
- | - create a shared data model for marine related data | + | |
- | - make marine related data easy to access, handle and build applications on | + | |
- | The shared data model allows you to handle the data in a uniform way independent of how the data is produced. In practice this means that you can refer to your battery voltage with `electrical/ | + | |
- | Easy access means that you can use modern standards like HTTP, WebSockets and JSON that are in widespread. There is a wealth | + | |
- | In Venus OS it brings all the data available in the GX system, including NMEA 2000 data, to a single data model and programming interface. | + | |
- | === 5.1.3 Considerations on how to install | + | |
- | The type of install described in this document, running Venus OS including SignalK, has these advantages: TODO elaborate. Doing this was born out of a wish to make SignalK more mainstream, less of a rapsberrypi / hobbieists/ | + | |
- | The other common type of SignalK | + | |
- | ==== 5.2 Where to find support? ==== | + | ==== 6.2 Documentation and support |
+ | * [[http:// | ||
- | ==== 5.3 Signal K details ==== | ||
- | ==== 5.4 First use & configuring ==== | + | ==== 6.3 First use & configuring ==== |
Line 264: | Line 417: | ||
Line 277: | Line 429: | ||
Line 282: | Line 435: | ||
- | ==== 5.5 Signal K FAQ ==== | + | ==== 6.4 CAN-bus ports ==== |
+ | === Cerbo GX === | ||
+ | === Cerbo GX MK2 === | ||
+ | === Ekrano GX === | ||
+ | ==== 6.5 Signal K FAQ ==== | ||
Line 308: | Line 486: | ||
- | ===== 6. Remote access via VRM ===== | ||
- | ==== 6.1 Node-RED flow editor and Signal K ==== | ||
- | === Step by step instructions | + | === Q2 - What happens when I updated a pre-installed Plugin? |
- | * **Step 1.** Log into/open the regular VRM ' | + | |
- | * **Step 2.** Modify the URL to include | + | A few plugins are installed by default on Venus OS Large. These include |
- | * **Step 3.** Click on the **Node-RED** or **Signal K** button in the Proxy relay screen; depending on location and the speed of internet connection, there may be a short delay while loading | + | When a newer version of such plugin is available, it is still possible to install |
- | {{ :venus-os: | + | |
- | * **Step 4.** The Node-RED flow editor or Signal K interface screen | + | The newer version of the plugin gets installed onto the data partition. And Signal K server |
- | ==== 6.2 Node-RED Dashboard/ | + | WARNING: above also means that once Venus OS ships with a newer version of the plugin than the version installed manually, Signal K Server will keep using that older one. To get out of such situation, remove the plugin by using the Appstore |
- | It it also possible to access | + | |
- | === Step by step instructions === | + | Note that the same icon is also available for the pre-installed plugins. Pressing it does nothing |
- | * **Step 1.** Install | + | |
- | * **Step 2.** Follow steps #1 to 4 in section 6.1 above in order to ' | + | === Q3 - Can I update signalk-server? |
- | * **Step 3.** The ' | + | Signal K Server comes preinstalled with Venus OS. And except by " |
- | * **Step 4.** The Node-RED dashboard/ | + | The normal |
- | ===== Appendix A - Repartitioning Venus GX flash memory ===== | + | In case you can’t wait, and don’t mind the extra work as well as risks, here is how to update it yourself. |
- | The Venus GX has sufficient flash memory to run the Venus OS Large image. But up until end of 2018 it was produced with a partition layout | + | Be warned, this method might or might not remain working |
- | Perform this procedure only when connected via Ethernet port. | + | Note that all changes made to the rootfs will be overwritten the next time you do a Venus OS update. |
- | Do not use the built-in WiFi AP to performing this procedure. The AP will not work half way the procedure. Similarly, any WiFi (client-) configuration will be wiped after running the installer. Therefore, as said, make sure to be able to connect on the LAN port before starting this procedure. | + | Step 1: Get yourself [[https:// |
- | **WARNING**: this procedure | + | Step 2: Follow |
- | It is impossible to brick the device using this procedure. Its always possible | + | < |
+ | ## Change | ||
- | Venus GX-es with serial number HQ1842xxxxx | + | ## Backup a file you'll need to restore later |
+ | # https:// | ||
+ | cp / | ||
- | === Requirements === | + | ## See version as well as install location for signalk-server |
+ | npm list -g | ||
- | * An SD Card | + | # output will be something like this: |
- | * Computer skills | + | # /usr/lib |
+ | # ├── node-red@3.1.0 | ||
+ | # ├── npm@9.5.1 | ||
- | Note that a USB stick will not work. Installer images can only be ran using an SD Card. | + | ## Stop signalk-server |
+ | svc -d / | ||
- | === Step A. Enable and obtain root access === | + | ## Update to a newer version, here is how to update to last released version: |
- | See [[https://www.victronenergy.com/ | + | # And to update to a more specific version, do something similar to this: |
- | === Step B. Secure factory files === | + | # Output will be something like this: |
- | Copy below four files to your computer. | + | ## Restore that file |
+ | mv / | ||
- | * /data/venus/serial-number | + | ## Install the signalk-venus-plugin in same place where it normally is on Venus OS |
- | | + | cd /usr/lib/ |
- | * /data/venus/part-number | + | npm install signalk-venus-plugin |
- | Below commandline instructions show how to do that on linux from the commandline. For Windows try Mobaxterm, or WinSCP. Putty won't work, its not for transferring files. There is Putty SCP (PSCP), as well, but then you need to know how to handle the commandline in Windows. We recommend using the other two. | + | ## If you want, see updated version: |
- | Procedure on Linux: | + | # output will be similar as above, but then with newer version |
- | < | + | ## start signalk-server again, and see log output: |
- | mkdir my-temp | + | svc -u / |
- | cd my-temp | + | |
- | mkdir conf | + | ## press CTRL-C to stop seeing the log. signalk-server will keep running in the background. |
- | mkdir venus | + | |
- | scp " | + | |
- | scp " | + | |
+ | ===== 7. Remote access via VRM ===== | ||
- | === Background information on the factory files === | + | The three available web interfaces, |
- | The first two are needed for the built-in accesspoint to work. Without | + | After enabling |
- | Third file is not used anywhere (at this moment), but easy enough to recreate by hand as well. | + | {{ : |
- | Fourth file: without it the system won't be able to send data to VRM anymore. Either make sure to keep that file, or after having booted the new version, go to the VRM Portal, Settings -> General. And scroll to the bottom. There will be an option to reset the token. This option is only visible after the portal has received data from the reflashed device. | + | ===== 8. Troubleshooting ===== |
- | === Step C. Run the installer image === | + | ==== 8.1 Disk space issues / data partition full ==== |
- | First, download | + | Using both Signal K Server, as well as Node-RED, it is quite easy to completely fill up the data partition. Which can cause all sorts of issues, like: |
- | Then, write it to an sdcard (tip: use BalenaEtcher, see Google) | + | - Venus OS itself no longer working correctly, |
+ | - and similar. | ||
- | Finally, run the installer by inserting | + | Note that Venus OS itself does **not** show a notification or warning when the data disk is full. And know that the other disks are read-only unless remounted to read/write as per [[https:// |
- | There is a bi-color LED on the other side of the same long green connector, indicating the status: | + | Depending |
- | * green on, done | + | |
- | Side info: see here for more details on installing an image. | + | **Tips and tricks to login a diagnose disk space** |
- | Once done, reboot the device. | + | Require root access: https:// |
- | After the boot (30 to 60 seconds) the LED will be slow blinking green. Indicating that the WiFi access point is off (as expected). More information about the LED operation | + | The '' |
- | Now, re-obtain yourself root access to continue. Note that all settings will be wiped by the installer: | + | |
- | * you'll need to go to Remote Console on LAN, then change access level again, enable ssh, change | + | < |
- | * As warned above, you’ll need to do this on the LAN port. The built-in WiFi access-point will be disabled, and any previously configured WiFi (client-) configuration will be lost as the installer will have wiped all settings. | + | root@einstein:/ |
+ | Filesystem | ||
+ | devtmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | overlay | ||
- | === Step D. Restore | + | The '' |
- | Again, | + | |
- | scp ./ | + | root@Cerbo:/ |
- | scp ./venus/* " | + | 1103640 / |
+ | 1099352 / | ||
+ | 1099276 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 /data/ | ||
+ | 3920 /data/log | ||
+ | 744 / | ||
+ | 164 / | ||
+ | 160 / | ||
+ | 116 / | ||
+ | 116 / | ||
+ | </code> | ||
- | # reboot | + | This is a view of a more healthy tree: |
- | ssh 192.168.178.122 reboot | + | < |
+ | root@Cerbo:/ | ||
+ | 164608 / | ||
+ | 160312 / | ||
+ | 160240 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3924 / | ||
+ | 744 / | ||
- | Once completed, the WiFi access point will be operational again. | + | ==== 8.2 Backup / Reset to factory defaults |
+ | There are scenarios where you want to make a backup of your data or when you want to clear logging or even start all over and go back to factory defaults. In order to make this process easy, you can put one (or more) of the following files on an USB stick and reboot your device. The files will be unpacked and the scripts within will execute. | ||
- | === Step E. Install Venus OS Large === | + | * [[https:// |
- | Now, the Venus GX has been repartitioned, | + | See [[https:// |
venus-os/large.txt · Last modified: 2024-04-03 19:07 by mvader
