venus-os:large
venus-os:large [2021-02-01 10:30] – stefanie | venus-os:large [2021-03-17 11:21] – stefanie | ||
====== Venus OS Large image: Signal K and Node-RED ====== | ====== Venus OS Large image: Signal K and Node-RED ====== | ||
- | (DRAFT - THIS DOCUMENT IS ABOUT NOT YET COMPLETELY FINISHED FUNCTIONALITY) | ||
Line 41: | Line 38: | ||
There is and will be **no official support** on the functionalities included in this image. For support, turn to the [[https:// | There is and will be **no official support** on the functionalities included in this image. For support, turn to the [[https:// | ||
+ | For support on SignalK, there is a #victron channel in [[http:// | ||
===== 3. Requirements ===== | ===== 3. Requirements ===== | ||
Line 166: | Line 164: | ||
- | The dashboard needs to be installed, just like other extra palettes, using the Manage Palette feature. | + | The dashboard needs to be installed, just like other extra palettes, using the Manage Palette feature, on the right of the screen in the menus. |
+ | Once that is done, you can find the nods in the palettes on the left. | ||
Line 317: | Line 317: | ||
* **Step 2.** Modify the URL to include **/proxy/** after the site URL ID number (note that the last **/** is required) | * **Step 2.** Modify the URL to include **/proxy/** after the site URL ID number (note that the last **/** is required) | ||
- | As an example: **https:// | + | As an example: **https:// |
