venus-os:large
venus-os:large [2021-01-18 18:05] – [4.3 Controlling relays] mvader | venus-os:large [2024-02-18 17:52] – [6.4 First use & configuring] mvader | ||
====== Venus OS Large image: Signal K and Node-RED ====== | ====== Venus OS Large image: Signal K and Node-RED ====== | ||
- | (DRAFT - THIS DOCUMENT IS ABOUT NOT YET COMPLETELY FINISHED FUNCTIONALITY) | ||
- | ===== 1. Introduction ===== | + | This manual documents Venus OS Large. Venus OS is the the software running on our [[https:// |
- | ==== 1.1 Venus OS Large, Node-RED and Signal K server? ==== | + | **Node-RED** |
- | This manual documents Venus OS Large, an extended build of Venus OS, that adds [[https:// | + | |
- | **Node-RED** | + | |
+ | - Automatic log book | ||
- | * https://github.com/victronenergy/venus/issues/378 | + | |
+ | For support on SignalK, there is a #victron channel in [[http:// | ||
===== 3. Requirements ===== | ===== 3. Requirements ===== | ||
==== 3.1 GX Device compatibility ==== | ==== 3.1 GX Device compatibility ==== | ||
- | A compatible GX device: | + | The compatible GX devices are: |
+ | * Ekrano GX | ||
* Cerbo GX | * Cerbo GX | ||
- | * Venus GX (serial number HQ1842 or later, or upgraded to the large partition layout - more information in Appendix A) | + | |
* Octo GX | * Octo GX | ||
* MultiPlus-II GX | * MultiPlus-II GX | ||
* EasySolar-II GX | * EasySolar-II GX | ||
- | The CCGX and CanVU GX are unfortunately not able to run Venus OS Large. | + | |
+ | The Color Control GX (CCGX) as well as the CanVU GX are unfortunately not able to run Venus OS Large. | ||
Line 58: | Line 54: | ||
- | From a GX device point of view, from the support models the Venus GX is the one with the least resources. Running both SignalK and Node-RED at the same time will be " | + | From a GX device point of view, from the support models the Venus GX is the one with the least resources. Running both SignalK and Node-RED at the same time will be " |
- | Cerbo GX is already much faster, as it has a dual core CPU as well as much more RAM. | + | When running out of RAM or CPU, the device will slow down. And eventually also reboot by itself due to the watchdog. |
- | More details about CPU & RAM differences are in this document: https:// | + | ===== 3. How to install and update ===== |
- | When running out of RAM or CPU, the device will slow down. And eventually also reboot by itself due to the watchdog. | + | === Step 1. Preparations === |
- | ===== 3. How to install | + | * __Cerbo GX__ - No preparations required. |
+ | * __Venus GX__ - First install | ||
+ | * __MultiPlus-II GX__ - No preparations required. | ||
+ | * __EasySolar-II GX__ - No preparations required. | ||
+ | * __RaspberryPi 3__ - No preparations required. | ||
+ | * __RaspberryPi 4__ - No preparations required. | ||
- | === Step by step instructions === | + | Note, when installing on a RaspberryPi, |
- | * **Step 1.** (For Venus GX-es with a serial number below HQ1842 only) - first perform the procedure as explained in Appendix A below. Warning, that procedure can only be carried | + | === Step 2. Update to the latest |
- | * **Step 2.** Disable Auto updates. See Settings -> Firmware -> Online updates in Remote Console. | + | |
- | * **Step 3.** Download | + | |
- | * **Step 4.** Install that file using the [[ccgx: | + | |
- | * **Step 5.** Verify that the image was successfully installed: go to Settings -> Services, and check that Signal K and Node-RED are now available to enable. | + | |
- | * **Step 6.** Enable either Signal K or Node-RED. Note that though its possible to enable both, doing so on a Venus GX is " | + | |
- | * **Finished**. The Venus OS Large image has now been installed successfully. Continue in either the Node-RED or the Signal K chapter below. | + | |
- | Venus OS Large menu: | + | See Settings |
- | {{ :venus-os: | + | |
- | === Special note for the RaspberryPi | + | === Step 3. Set the image type Venus OS Large === |
- | Unfortunately, | + | Go to Settings -> Firmware -> Online |
- | ===== 4. Node-RED ===== | + | |
- | ==== 4.1 Introduction ==== | + | Now, change the Image type to Large. Then go one menu up, and Check for a new version and install that. |
+ | === Step 3. Verify and enable === | ||
+ | - Verify that the image was successfully installed: go to the Settings menu, and check that the Venus OS Large menu is available. | ||
+ | - Enable either Signal K or Node-RED. Note that though its possible to enable both, doing that on a Venus GX is " | ||
+ | Visible once successfully installed, the Venus OS Large menu: | ||
+ | === How to update === | ||
+ | Both online and offline update methods can be used. The Image type setting, see the How to install chapter, defines what image type is being updated. See the GX manual for more details. | ||
+ | After installing and then enabling either one or both of the features, they need to be configured through a website in your browser. | ||
+ | To access the Node-RED flow editor, type https:// | ||
+ | See [[https:// | ||
+ | ==== 5.1 Introduction ==== | ||
Node-RED is a tool for connecting hardware devices, APIs and online services in new and interesting ways. It provides a browser-based editor that makes it easy to wire together flows. With it, one can for example program a functionality such as activating a relay based on a temperature measurement. Or make far more complex algorithms, tying relays, measurements, | Node-RED is a tool for connecting hardware devices, APIs and online services in new and interesting ways. It provides a browser-based editor that makes it easy to wire together flows. With it, one can for example program a functionality such as activating a relay based on a temperature measurement. Or make far more complex algorithms, tying relays, measurements, | ||
Line 97: | Line 127: | ||
+ | There is also a 3 part introductory webinar on Node-RED and Venus available at the Victron Tech YouTube channel: | ||
+ | __Standard nodes + Victron nodes__ | ||
+ | It is always wise to create an extra backup before performing an update of the firmware. | ||
- | The Node-RED | + | Do note that the above instruction only makes a backup of your flows, not of the Node-RED |
- | The username is " | + | ==== 5.3 Installing extra nodes ==== |
- | ==== 4.2 Installing extra nodes ==== | + | |
- | The Victron | + | The Victron |
- | Read the [[https:// | + | Read the [[https:// |
- | To install new nodes/pallettes | + | To install new nodes/palettes |
Palettes will be installed on the data partition on the GX Device. Which means that they will remain installed when updating Venus OS to a new version. | Palettes will be installed on the data partition on the GX Device. Which means that they will remain installed when updating Venus OS to a new version. | ||
- | it is possible | + | Refer to the remove button in the palette manager |
- | its not possible to remove | + | When installing a newer version of a palette than what is pre-installed |
- | When installing a newer version of a palette than what is pre-installed in Venus OS, node-red | + | Make sure that there is always 30MB of free space remaining on the data partition. One of the [[https:// |
- | Todo add what happens if user has a palette self installed and Venus OS then comes with a newer version pre-installed. | + | ==== 5.4 Controlling relays ==== |
- | Make sure that there is always 30MB of free space remaining on the data partition. TODO: how can a user see that? Also mem usage / mem free & some cpu stats would be nice to see. Maybe with a dashboard & flow? ;o) | + | |
- | ==== 4.3 Controlling relays ==== | + | |
Line 137: | Line 189: | ||
- | The relay in a BMV can be controlled. Make sure to set its option in the BMV configuration to REM fore Remote Controlled. | + | The relay in a BMV can be controlled. Make sure to set, using VictronConnect, |
+ | === SolarCharger | ||
- | ===== 5. Signal K ===== | + | === (VE.Bus connected-) Multi, Quattro and similar product relays |
- | ==== 5.1 Introduction ==== | + | === RS series (inverter, multi) relays |
- | === 5.1.1 Why have Signal K on your GX Device? | + | === Charger relays === |
+ | The only charger which has a relay that is controllable is the Smart IP43 Charger. To use that for remote control, set its mode, using the VictronConnect app, to be remote controllable. Note that its use is limited: the relay is only powered (and thus only controllable) when the charger is switched | ||
- | By adding Signal K, the GX device becomes a data hub for all marine electronics on your yacht. For example | + | Besides the flow and automation functionally, |
+ | It is viewable in a web browser - both locally as well as remote, via the VRM Servers. See chapter 6.2 for how to see it remotely. | ||
+ | The [[https:// | ||
+ | Once that is done, you can find the nodes in the palettes on the left. Once the dashboard has been configured and deployed, an extra tile will appear in the //Venus OS Large// menu on VRM, allowing to connect to the dashboard via VRM. | ||
+ | Example dashboard: | ||
+ | ==== 5.6 Configuration files ==== | ||
+ | * [[https:// | ||
+ | === Q2: How can I update the Victron node pallette === | ||
+ | As that pallette is part of the total Venus OS large package, it can only be updated by installing a newer Venus OS large version. | ||
+ | In case you see that there is a newer version Victron pallette available online, and thats not yet shipping in a Venus OS Large version, then the only option is to wait: a new Venus OS Large version is usually made available shortly after updating that pallette. | ||
+ | === Q3: How can I password protect Node-RED === | ||
+ | Password protection of Node-Red is linked to the remote console. If a password is set for the remote console, this password is also used for securing Node-Red. The username is '' | ||
+ | In order to restart Node-RED you need to disable and enable it from the menu. You can find this under //Venus OS Large Features -> Node-RED// | ||
+ | - Edit the ''/ | ||
+ | - Start Node-RED | ||
+ | module.exports = { | ||
+ | ===== 6. Signal K ===== | ||
+ | ==== 6.1 Introduction ==== | ||
+ | === 6.1.1 Why have Signal K on your GX Device? === | ||
+ | By adding Signal K, the GX device becomes a data hub for all marine electronics on your yacht. For example | ||
Line 159: | Line 352: | ||
+ | * Auqua Map | ||
+ | * iNavX | ||
+ | * iSailor | ||
+ | * Navionics | ||
- | === 5.1.2 Instruments compatible with Signal K === | + | === 6.1.2 Instruments compatible with Signal K === |
* All Victron products that can be connected to a GX device | * All Victron products that can be connected to a GX device | ||
Line 172: | Line 369: | ||
- | === 5.1.3 What is Signal K ? === | + | === 6.1.3 What is Signal K ? === |
- | For more information on Signal K, read [[http://signalk.org/overview.html|the Signal K website]]. And our blog post of a while ago. | + | For more information on Signal K, read the [[https://github.com/SignalK/signalk-server/ |
- | Note that Signal K is not a Victron project. At Victron, we a great fans of sailing, open source as well as community driven projects. And Signal K is a perfect example of such project. And when running on a GX Device its a perfect marriage. | + | |
- | === 5.1.4 Signal K - the data format === | + | |
- | Strictly speaking, Signal K is not software but a data format. And Signalk-server is the name of the software. | + | |
- | This section explains the rationale behind the data format. | + | |
- | Signal K is a modern and open data format for marine use. Its goal is to | + | Note that Signal K is not a Victron project. At Victron, we are great fans of sailing, |
- | - create a shared data model for marine related data | + | === 6.1.3 Considerations |
- | - make marine related data easy to access, handle and build applications | + | |
- | The shared data model allows you to handle the data in a uniform way independent | + | The type of install described in this document, running Venus OS including SignalK, has these advantages: no need to use a rapsberrypi, all ready in one box; no special firmware updates |
- | Easy access means that you can use modern standards like HTTP, WebSockets and JSON that are in widespread. There is a wealth of knowledge and skilled people are easy to find, with no special marine related knowledge needed to get started. | + | The other common type of Signal K Server |
- | In Venus OS it brings all the data available in the GX system, including NMEA 2000 data, to a single data model and programming interface. | + | |
- | === 5.1.3 Considerations on how to install Signal K === | + | |
- | The type of install described in this document, running Venus OS including SignalK, has these advantages: TODO elaborate. Doing this was born out of a wish to make SignalK more mainstream, less of a rapsberrypi / hobbieists/ | + | |
- | The other common type of SignalK | + | |
- | ==== 5.2 Where to find support? ==== | + | ==== 6.2 Documentation and support |
+ | * [[http:// | ||
- | ==== 5.3 Signal K details ==== | ||
- | - Signalk-node version is 1.18.0 | ||
- | - Victron Venus Plugin, v1.10.0 | ||
- | ==== 5.4 First use & configuring ==== | + | ==== 6.3 First use & configuring ==== |
Line 234: | Line 408: | ||
Use this to, for example, configure a USB-connected NMEA0183 connection in SignalK. To do so, go to the dashboard (http:// | Use this to, for example, configure a USB-connected NMEA0183 connection in SignalK. To do so, go to the dashboard (http:// | ||
- | Make sure to not add a connecting | + | Make sure to not add a connection |
Note that once configured in SignalK, for example a USB-serial port, that port is no longer normally available in Venus OS. For example, when plugging in a USB-GPS; and then adding a connection for its corresponding tty in the SignalK, makes for that GPS to be no longer be recognised and available in Venus OS. | Note that once configured in SignalK, for example a USB-serial port, that port is no longer normally available in Venus OS. For example, when plugging in a USB-GPS; and then adding a connection for its corresponding tty in the SignalK, makes for that GPS to be no longer be recognised and available in Venus OS. | ||
Line 240: | Line 414: | ||
Line 253: | Line 426: | ||
Line 258: | Line 432: | ||
- | ==== 5.5 Signal K FAQ ==== | + | ==== 6.4 CAN-bus ports ==== |
+ | === Cerbo GX === | ||
+ | === Cerbo GX MK2 === | ||
+ | === Ekrano GX === | ||
+ | ==== 6.5 Signal K FAQ ==== | ||
Line 284: | Line 483: | ||
- | ===== 6. Remote access via VRM ===== | ||
- | ==== 6.1 Node-RED flow editor and Signal K ==== | ||
- | === Step by step instructions | + | === Q2 - What happens when I updated a pre-installed Plugin? |
- | * **Step 1.** Log into/open the regular VRM ' | + | |
- | * **Step 2.** Modify the URL to include | + | A few plugins are installed by default on Venus OS Large. These include |
- | * **Step 3.** Click on the **Node-RED** or **Signal K** button in the Proxy relay screen; depending on location and the speed of internet connection, there may be a short delay while loading | + | When a newer version of such plugin is available, it is still possible to install |
- | * **Step 4.** The Node-RED flow editor or Signal K interface screen | + | The newer version of the plugin gets installed onto the data partition. And Signal K server |
- | ==== 6.2 Node-RED Dashboard/ | + | |
- | It it also possible to access | + | |
- | === Step by step instructions === | + | WARNING: |
- | * **Step 1.** Follow steps #1 to 4 in section 6.1 above in order to ' | + | |
- | * **Step 2.** The ' | + | Note that the same icon is also available for the pre-installed plugins. Pressing it does nothing |
- | * **Step 3.** The Node-RED dashboard/ | + | === Q3 - Can I update signalk-server? === |
- | ===== Appendix A - Repartitioning | + | Signal K Server comes preinstalled with Venus OS. And except by " |
- | The Venus GX has sufficient flash memory | + | The normal -and recommended- method |
- | Perform this procedure only when connected via Ethernet port. | + | In case you can’t wait, and don’t mind the extra work as well as risks, here is how to update it yourself. |
- | Do not use the built-in WiFi AP to performing | + | Be warned, |
- | **WARNING**: | + | Note that all changes made to the rootfs will be overwritten the next time you do a Venus OS update. |
- | It is impossible to brick the device using this procedure. Its always possible to run the installer again. But, to make the device operational again, also the files must be restored, if anything then with other contents. | + | Step 1: Get yourself [[https:// |
- | Venus GX-es with serial number HQ1842xxxxx and later already have the new partition layout from the factory. | + | Step 2: Follow this procedure: |
- | === Requirements === | + | < |
- | * An SD Card | + | ## Backup a file you'll need to restore later |
- | * Computer skills | + | # dev-tip: a list of especially installed files on a Victron install is here: |
+ | # https:// | ||
+ | cp / | ||
- | Note that a USB stick will not work. Installer images can only be ran using an SD Card. | + | ## See version as well as install location for signalk-server |
+ | npm list -g | ||
- | === Step A. Enable and obtain root access === | + | # output will be something like this: |
+ | # /usr/lib | ||
+ | # ├── node-red@3.1.0 | ||
+ | # ├── npm@9.5.1 | ||
- | See [[https://www.victronenergy.com/ | + | ## Stop signalk-server |
+ | svc -d /service/signalk-server | ||
- | === Step B. Secure factory files === | + | ## Update to a newer version, here is how to update to last released version: |
- | Copy below four files to your computer. | + | # And to update to a more specific version, do something similar to this: |
- | * / | + | # Output will be something like this: |
- | * / | + | # added 120 packages, removed 179 packages, and changed 586 packages in 6m |
- | | + | # 57 packages are looking for funding |
- | Below commandline instructions show how to do that on linux from the commandline. For Windows try Mobaxterm, or WinSCP. Putty won't work, its not for transferring files. There is Putty SCP (PSCP), as well, but then you need to know how to handle the commandline in Windows. We recommend using the other two. | + | ## Restore |
+ | mv / | ||
- | Procedure | + | ## Install the signalk-venus-plugin in same place where it normally is on Venus OS |
+ | cd / | ||
- | < | + | ## If you want, see updated version: |
- | mkdir my-temp | + | npm list -g |
- | cd my-temp | + | |
- | mkdir conf | + | |
- | mkdir venus | + | |
- | scp " | + | |
- | scp " | + | |
- | === Background information on the factory files === | + | # output will be similar as above, but then with newer version |
- | The first two are needed for the built-in accesspoint to work. Without them, the script that should start it is in an endless loop. | + | ## start signalk-server again, and see log output: |
+ | svc -u / | ||
- | Third file is not used anywhere (at this moment), but easy enough | + | ## press CTRL-C |
+ | ===== 7. Remote access via VRM ===== | ||
- | Fourth file: without it the system won't be able to send data to VRM anymore. Either make sure to keep that file, or after having booted | + | The three available web interfaces, the Node-RED flow editor, Node-RED dashboard and the Signal K admin panel can also be accessed remotely, via VRM. |
- | === Step C. Run the installer image === | + | After enabling them, to the VRM, and there click the Venus OS Large menu. Note that this might be slow, depending on the quality of the connection. |
- | First, download the [[https:// | + | {{ :venus-os: |
- | Then, write it to an sdcard (tip: use BalenaEtcher, | + | ===== 8. Troubleshooting ===== |
- | Finally, run the installer by inserting the sdcard containing the installer, and then power up while pressing the small recessed button on the right of the long green connector with, for example, a paperclip. | + | ==== 8.1 Disk space issues / data partition full ==== |
- | There is a bi-color LED on the other side of the same long green connector, indicating the status: | + | Using both Signal K Server, as well as Node-RED, it is quite easy to completely fill up the data partition. Which can cause all sorts of issues, like: |
- | Side info: see here for more details on installing an image. | + | Note that Venus OS itself does **not** show a notification or warning when the data disk is full. And know that the other disks are read-only unless remounted to read/write as per [[https:// |
- | Once done, reboot | + | The easy solution is to do full GX factory reset, as per the instructions in the GX user manuals. This includes downloading a file called venus-data.tgz. |
- | After the boot (30 to 60 seconds) the LED will be slow blinking green. Indicating that the WiFi access point is off (as expected). More information about the LED operation | + | A more detailed approach |
- | Now, re-obtain yourself root access to continue. Note that all settings will be wiped by the installer: | + | |
- | * you'll need to go to Remote Console on LAN, then change access level again, enable ssh, change root password, and then login. | + | The '' |
- | * As warned above, you’ll need to do this on the LAN port. The built-in WiFi access-point will be disabled, and any previously configured WiFi (client-) configuration will be lost as the installer will have wiped all settings. | + | |
- | === Step D. Restore the files === | + | < |
+ | root@einstein:/ | ||
+ | Filesystem | ||
+ | devtmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | overlay | ||
- | Again, this is how to do it on Linux: | + | The '' |
- | scp ./ | + | root@Cerbo:/ |
- | scp ./venus/* " | + | 1103640 / |
+ | 1099352 / | ||
+ | 1099276 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 /data/ | ||
+ | 3920 /data/log | ||
+ | 744 / | ||
+ | 164 / | ||
+ | 160 / | ||
+ | 116 / | ||
+ | 116 / | ||
+ | </code> | ||
- | # reboot | + | This is a view of a more healthy tree: |
- | ssh 192.168.178.122 reboot | + | < |
+ | root@Cerbo:/ | ||
+ | 164608 / | ||
+ | 160312 / | ||
+ | 160240 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3924 / | ||
+ | 744 / | ||
- | Once completed, the WiFi access point will be operational again. | + | ==== 8.2 Backup / Reset to factory defaults |
+ | There are scenarios where you want to make a backup of your data or when you want to clear logging or even start all over and go back to factory defaults. In order to make this process easy, you can put one (or more) of the following files on an USB stick and reboot your device. The files will be unpacked and the scripts within will execute. | ||
- | === Step E. Install Venus OS Large === | + | * [[https:// |
- | Now, the Venus GX has been repartitioned, | + | See [[https:// |
