venus-os:large
venus-os:large [2024-02-09 16:54] – [8.1 Disk space issues / data partition full] dfaber | venus-os:large [2024-04-03 19:07] – [5.1 Introduction] mvader | ||
Line 129: | Line 129: | ||
A good tutorial on how to work with Node-RED is here: https:// | A good tutorial on how to work with Node-RED is here: https:// | ||
- | There is also a 3 part introductory webinar on Node-RED and Venus available at the Victron Tech YouTube channel: | + | ==== 5.2 Three part introductory webinar ==== |
[[https:// | [[https:// | ||
Line 142: | Line 144: | ||
The Node-RED editor can be accessed from your LAN at https:// | The Node-RED editor can be accessed from your LAN at https:// | ||
- | __Standard nodes + Victron nodes__ | + | ==== 5.3 Node specifications ==== |
Node-RED comes with a core set of useful nodes, and within the Venus OS large install there is a set of Victron nodes added to that: the Victron Pallet. All of the different nodes are described [[https:// | Node-RED comes with a core set of useful nodes, and within the Venus OS large install there is a set of Victron nodes added to that: the Victron Pallet. All of the different nodes are described [[https:// | ||
Line 396: | Line 399: | ||
Line 414: | Line 417: | ||
Line 427: | Line 429: | ||
Line 432: | Line 435: | ||
+ | === Cerbo GX === | ||
+ | === Cerbo GX MK2 === | ||
+ | === Ekrano GX === | ||
Line 562: | Line 590: | ||
Note that Venus OS itself does **not** show a notification or warning when the data disk is full. And know that the other disks are read-only unless remounted to read/write as per [[https:// | Note that Venus OS itself does **not** show a notification or warning when the data disk is full. And know that the other disks are read-only unless remounted to read/write as per [[https:// | ||
- | The easy solution | + | Depending on what the issue is, there are a few things you can do: |
+ | - Do full GX factory reset, as per the instructions in the GX user manuals. This includes downloading a file called venus-data.tgz; see GX manual for details. Disadvantage is that you'll need to reconfigure the GX. | ||
- | A more detailed approach is logging in on SSH, and checking for disk space. Here are a few useful commands. | + | Require root access: https://www.victronenergy.com/ |
The '' | The '' |
venus-os/large.txt · Last modified: 2024-06-11 07:40 by dfaber
