venus-os:large
venus-os:large [2022-09-11 20:05] – [7.1 Node-RED flow editor and Signal K] dfaber | venus-os:large [2024-04-03 19:07] – [5.1 Introduction] mvader | ||
Line 2: | Line 2: | ||
+ | **Node-RED** | ||
- | From VRM, a connection to Node-RED, the Node-RED dashboard and Signal K can be made. | + | |
- | Note that only the services that are enabled are shown in the VRM menu. | + | |
- | ==== 1.2 Status and where this development is going ==== | + | |
- | Currently, these images are available as beta versions. They work well, several users are using this without any issues; and are super happy with the provided functionality. | + | |
- | The remaining work are mostly small improvements, clean ups and testing. | + | - WiFi navigation and AIS data server to charting apps such as iSailor, Navionics, iNavX, Aqua Map. |
+ | - Automatic log book | ||
- | There will be two flavours | + | The [[https:// |
- | - the normal one as we've been building for years now. With all normal & supported functionality. | + | For more information on Signal K on Venus OS, see below chapter. |
- | - the large flavour. All the same as the normal one, but with addition of Signal K & Node-RED. | + | |
- | Switching between them is easy: a simple switch in the gui, see Settings -> Firmware -> Online updates -> Image type. | ||
- | Why are there two images, instead of just one? That is to save download and install time for the (vast majority) of users that will not use these features. SignalK and Node-RED increase the download (& installed) size enormously, and also they are really cool; but do not fall within normal Victron support. Which is why we want to keep them separate. | ||
===== 2. Where to find support ===== | ===== 2. Where to find support ===== | ||
- | There is and will be **no official support** on the functionalities | + | There is and will be no official support on the functionalities |
- | For support, turn to the [[https:// | + | For support, turn to the [[https:// |
- | There, first search if someone else had a similar question already. And if you can’t find such, then create a new question. | + | There, first search if someone else had a similar question already. And if you can’t find such, then create a new question. Make sure you add Node-RED to the topic. |
Line 46: | Line 39: | ||
+ | * Ekrano GX | ||
* Cerbo GX | * Cerbo GX | ||
+ | * Cerbo-S GX | ||
* Venus GX | * Venus GX | ||
* Octo GX | * Octo GX | ||
Line 53: | Line 48: | ||
Line 59: | Line 54: | ||
Line 67: | Line 62: | ||
Line 75: | Line 70: | ||
- | === Step 2. Update to the latest v2.90 beta file === | + | === Step 2. Update to the latest |
- | (And once v2.90 is released officially, its no longer needed | + | See Settings -> Firmware -> Online updates. For more information, refer to the user the manual of your GX device. |
- | Instructions and details on installing | + | === Step 3. Set the image type Venus OS Large === |
- | === Step 3. Switch | + | Go to Settings -> Firmware -> Online updates -> Image type: |
- | Go to Settings | + | {{ :venus-os: |
- | There select | + | Now, change |
- | The change-log is embedded in the (rather long) [[https:// | + | |
=== Step 3. Verify and enable === | === Step 3. Verify and enable === | ||
- | v2.8x: updates can only be done using the offline update | + | Both online and offline update |
- | v2.90 and later: | + | After installing |
+ | To access the Node-RED flow editor, type https:// | ||
+ | See [[https:// | ||
===== 5. Node-RED ===== | ===== 5. Node-RED ===== | ||
Line 117: | Line 127: | ||
The Node-RED editor can be accessed from your LAN at https:// | The Node-RED editor can be accessed from your LAN at https:// | ||
- | __Standard nodes + Victron nodes__ | + | ==== 5.3 Node specifications ==== |
Node-RED comes with a core set of useful nodes, and within the Venus OS large install there is a set of Victron nodes added to that: the Victron Pallet. All of the different nodes are described [[https:// | Node-RED comes with a core set of useful nodes, and within the Venus OS large install there is a set of Victron nodes added to that: the Victron Pallet. All of the different nodes are described [[https:// | ||
For developers: source code for the node-red-contrib-victron modules is [[https:// | For developers: source code for the node-red-contrib-victron modules is [[https:// | ||
==== 5.2 Back-up and restore ==== | ==== 5.2 Back-up and restore ==== | ||
Line 186: | Line 211: | ||
=== Charger relays === | === Charger relays === | ||
- | The only charger which has a relay that is controllable is the Phoenix | + | The only charger which has a relay that is controllable is the Smart IP43 Charger. To use that for remote control, set its mode, using the VictronConnect app, to be remote controllable. Note that its use is limited: the relay is only powered (and thus only controllable) when the charger is switched on. It doesn' |
==== 5.5 Node-RED Dashboard ==== | ==== 5.5 Node-RED Dashboard ==== | ||
Line 193: | Line 218: | ||
- | ==== 5.6. Node-RED FAQ ==== | + | ==== 5.6 Configuration files ==== |
- | === Q: Write/read file gives " | + | WARNING: the vast majority of systems using Node-RED will not, and should not (!), have to modify any of the files here described. Venus OS itself, including Venus OS large and Node-RED, is made such that its not necessary to dive into the command line. |
+ | * [[https:// | ||
+ | The [[https:// | ||
Since Venus OS 2.90 and on wards, Node-RED no longer runs as user '' | Since Venus OS 2.90 and on wards, Node-RED no longer runs as user '' | ||
Line 212: | Line 287: | ||
- | === Q: How do I restart Node-RED from the Venus GUI? === | + | === Q4: How do I restart Node-RED from the Venus GUI? === |
In order to restart Node-RED you need to disable and enable it from the menu. You can find this under //Venus OS Large Features -> Node-RED//. | In order to restart Node-RED you need to disable and enable it from the menu. You can find this under //Venus OS Large Features -> Node-RED//. | ||
- | === Q: How does safe mode work and what is it? === | + | === Q5: How does safe mode work and what is it? === |
From the Venus GUI you can select Node-RED to be enabled in "safe mode". This means that Node-RED will start without starting the flows. This allows you to open the flows in the editor and make changes without the flows running. When you deploy your changes, the flows are then started. The safe mode can be handy if one of the flows has an error that causes high CPU loads on the Venus device or other issues. | From the Venus GUI you can select Node-RED to be enabled in "safe mode". This means that Node-RED will start without starting the flows. This allows you to open the flows in the editor and make changes without the flows running. When you deploy your changes, the flows are then started. The safe mode can be handy if one of the flows has an error that causes high CPU loads on the Venus device or other issues. | ||
- | === Q: Can I install the @signalk/ | + | === Q6: Can I install the @signalk/ |
No, at least not into the node-red instance which comes as part of Venus OS Large. To @signalk/ | No, at least not into the node-red instance which comes as part of Venus OS Large. To @signalk/ | ||
Line 232: | Line 307: | ||
- install the Victron pallette into the Node-RED thats part of SignalK server | - install the Victron pallette into the Node-RED thats part of SignalK server | ||
- | === Q: I get the error: Failed to remove, unrecognised module === | + | === Q7: I get the error: Failed to remove, unrecognised module === |
This is seen when trying to remove a module that has been previously uninstalled, | This is seen when trying to remove a module that has been previously uninstalled, | ||
Line 244: | Line 319: | ||
After following these steps Node-RED should know about the module again and you should be able to remove or upgrade it. | After following these steps Node-RED should know about the module again and you should be able to remove or upgrade it. | ||
- | === Q: The browser complains about non private connection === | + | === Q8: The browser complains about non private connection === |
Node-RED on Venus now uses SSL for its connection. As the certificate is signed by a "self signed certificate", | Node-RED on Venus now uses SSL for its connection. As the certificate is signed by a "self signed certificate", | ||
Another implication might be that you need to prepend the connection with '' | Another implication might be that you need to prepend the connection with '' | ||
+ | module.exports = { | ||
Line 255: | Line 349: | ||
Line 261: | Line 355: | ||
+ | * Auqua Map | ||
+ | * iNavX | ||
+ | * iSailor | ||
+ | * Navionics | ||
Line 278: | Line 376: | ||
+ | * [[http:// | ||
- | TODO: remove these versions, and replace by a link to the change-log. | + | ==== 6.3 First use & configuring ==== |
- | And instead add information on what specifics we do in the Signal K install. | + | |
- | - Signalk-node version is 1.37.5 | + | |
- | - Victron Venus Plugin, v1.22.0 | + | |
- | ==== 6.4 First use & configuring ==== | + | |
Line 342: | Line 417: | ||
Line 355: | Line 429: | ||
Line 360: | Line 435: | ||
+ | === Cerbo GX === | ||
+ | === Cerbo GX MK2 === | ||
+ | === Ekrano GX === | ||
Line 386: | Line 486: | ||
+ | # https:// | ||
+ | cp / | ||
+ | npm list -g | ||
+ | # /usr/lib | ||
+ | # ├── node-red@3.1.0 | ||
+ | # ├── npm@9.5.1 | ||
+ | svc -d / | ||
+ | ## Restore that file | ||
+ | mv / | ||
+ | cd / | ||
+ | svc -u / | ||
- | It it possible to access Node-RED flow editor and Signal K remotely via VRM - the interface and functionality is identical to access via LAN (ie. via **https:// | ||
- | {{ :venus-os: | + | |
+ | - and similar. | ||
+ | The '' | ||
+ | root@einstein:/ | ||
+ | Filesystem | ||
+ | devtmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | tmpfs | ||
+ | overlay | ||
+ | The '' | ||
+ | root@Cerbo:/ | ||
+ | 1103640 / | ||
+ | 1099352 / | ||
+ | 1099276 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3920 / | ||
+ | 744 / | ||
+ | 164 / | ||
+ | 160 / | ||
+ | 116 / | ||
+ | 116 / | ||
+ | 164608 / | ||
+ | 160312 / | ||
+ | 160240 / | ||
+ | 87048 / | ||
+ | 65732 / | ||
+ | 7188 / | ||
+ | 3924 / | ||
+ | 744 / | ||
venus-os/large.txt · Last modified: 2024-06-11 07:40 by dfaber
