venus-os:gx_solaredge
venus-os:gx_solaredge [2019-05-26 19:52] – [2. How to configure] mvader | venus-os:gx_solaredge [2020-10-29 17:02] – [1. Introduction] fjlacock | ||
+ | In 2019 SolarEdge has introduced a new feature that allows AC-coupling with alternative power sources (or non-grid power sources) such as the Victron Energy Inverter/ | ||
- | You can connect your [[venus-os: | + | When a solar inverter is operating concurrently |
- | * Zero Feed-in for SolarEdge is not available | + | With this feature you can now build custom size AC Coupled Hybrid single-phase and three-phase systems with the capability to enable zero feed-in to the grid when in On-Grid mode and frequency shifting |
- | * Frequency shift power control, as required | + | |
- | With those limitations, | + | For more information: |
- | In other sorts of systems, for example Off-grid systems, or ESS systems in areas where grid feed-in is not allowed, using a SolarEdge PV solution is not supported by Victron. | + | |
- | Note that its not possible | + | The AC coupled system sizing guideline, Factor 1.0 rule, from Victron Energy for AC coupled system must be adhered to. |
- | ===== 2. How to configure ===== | + | |
+ | **Note** | ||
+ | This APS feature is only available for 3phase and 1phase HDwave inverters. | ||
+ | ===== 2. How to configure APS mode ===== | ||
+ | Requirements: | ||
+ | * For SetApp (screenless) inverters: Firmware 4.8.24 or higher (US models currently lack Frequency Control, and are therefore not compatible) | ||
+ | * For LCD inverters: Firmware 3.25xx or higher | ||
+ | * Dry-contact for sensing | ||
+ | * SolarEdge | ||
+ | Configuration example 1: Use of external relay and dry contact, Single-phase configuration, | ||
+ | Figure 1 | ||
+ | Three Phase configuration, Figure 2 | ||
+ | Figure 2 | ||
+ | Configuration example 2: Use of Internal programmable relay K1, | ||
+ | Single-phase configuration, | ||
+ | Figure 3 | ||
+ | Three-phase configuration, | ||
+ | Figure 4 | ||
+ | Programmable Aux relay Set up, single-phase configuration, | ||
+ | Figure 5 | ||
+ | Programmable Aux relay Set up, three-phase configuration, | ||
+ | Figure 6 | ||
+ | __1. Dry contact installation__ | ||
+ | Install a dry contact, sensing the grid availability. Connect twisted pair wires from the dry contact terminals | ||
+ | Figure 4 | ||
+ | __2. Alternative Power Source mode__ | ||
+ | Alternative Power Source mode should be configured | ||
+ | To Configure Alternative Power Source mode: | ||
+ | * Commissioning -> Communication -> GPIO -> Power Reduction Interface (RRCR) Mode -> Alternative Power Source. | ||
+ | Inverters with LCD | ||
+ | * Enter the inverter’s setup menu using the SolarEdge Password. | ||
+ | * Communication -> GPIO Conf -> Device Type -> Alternative Power Src. | ||
+ | ===== 3. How to configure Frequency Shifting ===== | ||
+ | Important note: Please ensure the SolarEdge inverter and your VE.Bus Config is set up for the same frequency bandwidth. | ||
+ | __1. Configure P(f) for APS__ | ||
+ | * Power Control -> Alternative Power Source -> P(f) | ||
+ | * Edit P0: 50.2Hz, 100% Power | ||
+ | * and P1: 51.2Hz, 0% Power | ||
+ | * Power Control -> Alt Power Src-> P(f) | ||
+ | **__Note: | ||
+ | In addition | ||
+ | ===== 4. Set ESS assistance ===== | ||
+ | The same bandwidth needs to be configured on VE.Bus Config for Victron | ||
+ | Start ESS assistance and set: | ||
+ | - The solar converter will start reducing its output | ||
+ | - Output power will be reduced to a minimum when the frequency is 51.2Hz | ||
+ | - The converter will disconnect when the frequency is higher than 51.5Hz | ||
+ | ===== 5 How to configure | ||
- Ensure that the GX Device and the SolarEdge system are both on the same LAN or WiFi network. | - Ensure that the GX Device and the SolarEdge system are both on the same LAN or WiFi network. | ||
- | - Enable ModbusTCP | + | - Enable ModbusTCP |
- | - The Modbus | + | |
- | - On the GX Device, navigate to Settings | + | * Communication -> Modbus TCP port -> Modbus TCP -> Edit port to 502. |
+ | 3. Enable SunSpec | ||
+ | * Communication -> RS481 -> Protocol -> SunSpec (Non-SE Logger) | ||
+ | Once you are done with the SunSpec setup you can re-configure RS485-1 | ||
- | RS485-1 menu on the Solar Edge, showing | + | **Note:** |
- | {{ : | + | It also advised editing |
- | Details: | ||
- | - The SE2200H - SE6000H range (HD-wave) was specifically tested, though several others are reported to work too. | ||
- | - During testing, we found that the SolarEdge PV Inverter accepts just one concurrent TCP connection. Additional connections are rejected. |
venus-os/gx_solaredge.txt · Last modified: 2021-09-21 16:22 by fjlacock
