venus-os:canvu-gx
venus-os:canvu-gx [2019-01-22 11:16] – martijncoster | venus-os:canvu-gx [2019-05-10 14:06] – lucian | ||
- | The CANvu GX is a forthcoming | + | The CANvu GX is a product in the Victron [[venus-os: |
+ | The CANvu GX is a device similar to the Color Control GX, and most of it's functionality and features are explained in the Color Control Manual here : https:// | ||
Line 13: | Line 15: | ||
**CANvu GX IO Extender and wiring kit:** | **CANvu GX IO Extender and wiring kit:** | ||
- | What' | + | Note; this kit needs to be purchased separately and is always needed. Included |
- | * CANVU GX IO extender | + | |
- | * Power cable | + | * CANvu GX IO extender |
+ | * Power cable (supply voltage 8 - 32 VDC, **if used on a 48V system, a DC-DC converter must be used to reduce the voltage below 32VDC**) | ||
* VE.Can cable | * VE.Can cable | ||
* Ethernet cable | * Ethernet cable | ||
Line 31: | Line 34: | ||
Overview of connections | Overview of connections | ||
venus-os/canvu-gx.txt · Last modified: 2020-05-13 11:20 by mvader
