venus-gx:start
| venus-gx:start [2020-01-06 21:26] – [1.1 Description] mvader | venus-gx:start [2021-02-05 07:41] (current) – [6. More information] mvader | ||
| Line 1: | Line 1: | ||
| ====== Venus GX (VGX) manual ====== | ====== Venus GX (VGX) manual ====== | ||
| - | ===== 1. Introduction ===== | + | The Venus GX manual has moved; please find the new version on the [[https:// |
| - | ==== 1.1 Description ==== | ||
| - | In many ways the **Venus GX (VGX)** and the **Color Control GX (CCGX)** are the same device. They share a lot of hardware, and they run on identical software - our 'Venus OS' - therefore firmware numbering is the same; and new version releases always apply to both devices at the same time. | ||
| - | As many of the functions of the two devices are identical, the [[ccgx: | ||
| - | This manual refers to the latest firmware version. A device connected to the internet will perform new-version updates automatically. Check the latest firmware version [[https:// | ||
| - | == Venus GX/CCGX comparison table == | ||
| - | See the [[venus-os: | ||
| - | ==== 1.2 What's in the Box? ==== | ||
| - | * Venus GX (VGX) | ||
| - | * VE.Can terminator (2 pcs). | ||
| - | * Power cable with inline fuse and M8 terminal eyes for battery- or DC busbar-attachment. | ||
| - | * Terminal Blocks for all the connectors on each side. | ||
| - | * Label showing WiFi key and product details. | ||
| - | {{venus-gx_left.png? | ||
| - | ==== 1.3 Overview of connections ==== | ||
| - | ===== 2. Accessing the device ===== | ||
| - | Because the Venus GX has no visual display or buttons, you need either a smartphone, tablet or laptop to access it. | ||
| - | This access is called Remote Console. There are three ways to access the Remote Console: | ||
| - | - Through the online VRM Portal, which requires internet, see chapter 2.1; | ||
| - | - By using the built-in WiFi Access Point, see chapter 2.2; | ||
| - | - Or, via the local LAN/WiFi network; see chapter 2.3. | ||
| - | ==== 2.1 Accessing via VRM ==== | ||
| - | This method requires a working internet connection, both on your phone/ | ||
| - | Step by step instructions: | ||
| - | First, connect the Venus GX to the internet by plugging it into a working Ethernet network which has a DHCP server, as most networks do, and which is connected to the internet. The Venus GX will immediately connect to VRM. | ||
| - | Now, go to the VRM Portal, https:// | ||
| - | Then once visible on VRM, click the ' | ||
| - | More information about ' | ||
| - | ==== 2.2 Accessing via the built-in WiFi Access Point ==== | ||
| - | This method requires the [[https:// | ||
| - | Steps: | ||
| - | - Make sure you are no further than a few metres away from the Venus GX | ||
| - | - Go to the WiFi settings on your phone / tablet / laptop. | ||
| - | - After searching, the Venus GX will show up in the list, as '' | ||
| - | - Connect to WiFi using the 'WiFi key' which you will find printed on the side of the box ...and also on a card in the plastic bag. Keep that in a safe place. | ||
| - | - Open VictronConnect, | ||
| - | - Once found, select the GX device from the list. | ||
| - | - Open the Remote Console | ||
| - | Notes: | ||
| - | * If you cannot use VictronConnect, | ||
| - | * For added security it is possible to disable the WiFi Access Point. See Settings -> Wi-Fi -> Create access point. See below chapter explaining the Push button for how to restore access in case ever necessary. | ||
| - | === Instruction video === | ||
| - | Step by step instruction video on how to connect to a GX device using the [[https:// | ||
| - | {{youtube> | ||
| - | === Detailed instruction video === | ||
| - | This second video was made before VictronConnect got the feature to find a device on a network. All the explanations in the video regarding IP Addressing can be ignored, and use VictronConnect as in above video instead. | ||
| - | {{youtube> | ||
| - | ==== 2.3 Accessing via the local LAN/WiFi Network ==== | ||
| - | === 2.3.1 Introduction and common installations === | ||
| - | This section explains how to connected to Remote Console when the Venus GX is connected to the local computer network, with either an Ethernet cable, or having it configured to connect to a local WiFi network. | ||
| - | This method does not require an internet connection. Just a local computer network is sufficient. | ||
| - | Once connected, connect to the GX Device by running the [[https:// | ||
| - | This video shows how its done: | ||
| - | {{youtube> | ||
| - | === 2.3.2 Alternative methods to find the IP Address === | ||
| - | In case VictronConnect can't be used, here are a few other methods to find the Venus GX, ie. its IP Address. | ||
| - | __IP Address on VRM__ | ||
| - | On the VRM Portal, you'll find the IP address on the Device List page of the installation. Note that this does require the Venus GX to be connected to the internet. | ||
| - | __Network (on Microsoft Windows)__ | ||
| - | In a local network, for example at home, you can also find the Venus GX in the Windows ' | ||
| - | Double-clicking the icon will open up Remote Console on LAN. | ||
| - | Open the ' | ||
| - | This uses Universal plug-and-play broadcast technology. | ||
| - | ===== 3. LEDs and Push-button ===== | ||
| - | ==== 3.1 LEDs ==== | ||
| - | === Boot-up === | ||
| - | On the side of the Venus GX, there is a LED. During power-up it it goes through these states: | ||
| - | * Stage 1: Both green and red illuminate briefly and faintly (it's hard to see the green) for approximately 1 second. | ||
| - | * Stage 2: Red illuminates for approximately 1 second. | ||
| - | * Stage 3: Green illuminates for approximately 0.5 seconds. | ||
| - | * Stage 4: Both green and red illuminate briefly and faintly (it's hard to see the green) for approximately 1 second. | ||
| - | === During operation === | ||
| - | * Slow blinking: built-in WiFi access point disabled | ||
| - | * Fast blinking: built-in WiFi access point enabled (default) | ||
| - | Slow blinking is once per second. Fast blinking is twice per second. | ||
| - | ==== 3.2 Small button located to the right of the green 14-Terminal Connector Block ==== | ||
| - | === Short press: WiFi Access point on/off === | ||
| - | A single short press toggles the internal WiFi access point on and off. The LED indicates its state: when the LED blinks green slow, then the built-in Access Point is disabled. when the LED is green and blinking fast, then the built-in Access Point is enabled. | ||
| - | === Long press: reset all network settings to factory defaults === | ||
| - | Press and hold the small button for a minimum of four seconds. The LED will stay on for 2 seconds to indicate that the log press has been recognised; then release the button again. | ||
| - | * Ethernet is set back to DHCP | ||
| - | * WiFi Access Point is enabled | ||
| - | * Remote Console password is disabled | ||
| - | * Remote Console on LAN and on VRM is enabled | ||
| - | The same button is available on the Octo GX, button is marked SD_BOOT and available under the lid at the top. | ||
| - | ===== 4. Digital Inputs ===== | ||
| - | The Venus GX has five digital inputs. The channels are accessible via the RJ-12 socket on the side. This is available for self-wiring by the user/ | ||
| - | ==== 4.1. Wiring details ==== | ||
| - | The inputs are non-isolated. They operate at 3V3 levels, and can withstand up to 5V input. Each input has an internal 10k pull-up resistor to 3V3. We recommend wiring it to a potential free relay or otherwise open collector/ | ||
| - | ^ RJ12 pinout ^ Input ^ | ||
| - | | pin1 | input1 | | ||
| - | | pin2 | input2 | | ||
| - | | pin3 | input3 | | ||
| - | | pin4 | input4 | | ||
| - | | pin5 | gnd | | ||
| - | | pin6 | input5 | | ||
| - | ==== 4.2. Configuration ==== | ||
| - | Each of the digital inputs can be configured as a pulse meter, or as one of a number of predefined sensors that can also be configured as alarms. | ||
| - | The possible configurable functions are: | ||
| - | ^ Function | ||
| - | | Pulse meter | N/A | | ||
| - | | Door alarm | Open/ | ||
| - | | Bilge pump | On/ | ||
| - | | Bilge alarm | Ok/ | ||
| - | | Burglar alarm | Ok/ | ||
| - | | Smoke alarm | Ok/ | ||
| - | | Fire alarm | Ok/ | ||
| - | | CO2 alarm | Ok/ | ||
| - | | Generator | ||
| - | The function of each input can be configured in the GUI under Settings -> I/O -> Digital Inputs. | ||
| - | Once the input is configured for its intended purpose, it will show up with other devices. | ||
| - | Other parameters related to that function can be configured by entering the device menu and selecting Setup. For pulse meters, you can configure the unit, the multiplier (the volume represented by each pulse) and reset the counter. | ||
| - | For other sensors and alarms, you can decide whether the input should be treated as an alarm condition, whether the labels should be inverted, and whether the logical levels should be inverted. | ||
| - | * To swap the labels attached to the alarm, set // | ||
| - | * If a logical low input (0V) should be considered a positive condition, set //Inverted alarm logic// to on. | ||
| - | ==== 4.3. Read-out of digital inputs via Modbus-TCP ==== | ||
| - | The values/ | ||
| - | ===== 5. Factory reset ===== | ||
| - | See above chapter 3.2 on the push button. | ||
| - | ===== 6. More information ===== | ||
| - | * [[open_source: | ||
| - | ===== DISQUS ===== | ||
| - | ~~DISQUS~~ | ||
venus-gx/start.1578345998.txt.gz · Last modified: by mvader
