venus-gx:start
venus-gx:start [2019-12-16 16:04] – [5. How does the Venus GX compare with the CCGX?] mvader | venus-gx:start [2020-04-29 11:34] – [3.2 Small button located to the right of the green 14-Terminal Connector Block] mvader | ||
====== Venus GX (VGX) manual ====== | ====== Venus GX (VGX) manual ====== | ||
+ | ==== 1.1 Description ==== | ||
In many ways the **Venus GX (VGX)** and the **Color Control GX (CCGX)** are the same device. They share a lot of hardware, and they run on identical software - our 'Venus OS' - therefore firmware numbering is the same; and new version releases always apply to both devices at the same time. | In many ways the **Venus GX (VGX)** and the **Color Control GX (CCGX)** are the same device. They share a lot of hardware, and they run on identical software - our 'Venus OS' - therefore firmware numbering is the same; and new version releases always apply to both devices at the same time. | ||
Line 10: | Line 13: | ||
== Venus GX/CCGX comparison table == | == Venus GX/CCGX comparison table == | ||
- | See [[venus-os: | + | See the [[venus-os: |
- | ===== 1. What's in the Box? | + | ==== 1.2 What's in the Box? ==== |
* Venus GX (VGX) | * Venus GX (VGX) | ||
Line 22: | Line 25: | ||
{{venus-gx_left.png? | {{venus-gx_left.png? | ||
- | ==== 1.1 Overview of connections ==== | + | ==== 1.3 Overview of connections ==== |
===== 2. Accessing the device ===== | ===== 2. Accessing the device ===== | ||
- | Because the Venus GX has no visual display or buttons, | + | Because the Venus GX has no visual display or buttons, |
- | ==== 2.1 Accessing 'Remote Console' via VRM ==== | + | This access is called |
- | Connect the Venus GX to the internet by plugging it into a working Ethernet network which as a DHCP server (most networks do). It will immediately connect to VRM. | + | |
- | Go to https://vrm.victronenergy.com/ and follow the instructions to add the device. More information about this is available in the [[vrm_portal: | + | - Through the online VRM Portal, which requires internet, see chapter 2.1; |
+ | - By using the built-in WiFi Access Point, see chapter 2.2; | ||
+ | - Or, via the local LAN/WiFi network; see chapter 2.3. | ||
- | When you've done that, click the ' | + | ==== 2.1 Accessing via VRM ==== |
+ | This method requires a working internet connection, both on your phone/ | ||
+ | Step by step instructions: | ||
+ | First, connect the Venus GX to the internet by plugging it into a working Ethernet network which has a DHCP server, as most networks do, and which is connected to the internet. The Venus GX will immediately connect to VRM. | ||
+ | Now, go to the VRM Portal, https:// | ||
+ | Then once visible on VRM, click the ' | ||
+ | More information about ' | ||
- | More information about ' | ||
- | ==== 2.2 Accessing | + | ==== 2.2 Accessing via the built-in WiFi Access Point ==== |
+ | This method requires the [[https:// | ||
Steps: | Steps: | ||
Line 46: | Line 64: | ||
- Make sure you are no further than a few metres away from the Venus GX | - Make sure you are no further than a few metres away from the Venus GX | ||
- Go to the WiFi settings on your phone / tablet / laptop. | - Go to the WiFi settings on your phone / tablet / laptop. | ||
- | - After searching, | + | - After searching, |
- | - Connect to WiFi using the 'WiFi key' which you will find printed on the side of the box ...and also on a card in the plastic bag - which you should keep in a safe place. | + | - Connect to WiFi using the 'WiFi key' which you will find printed on the side of the box ...and also on a card in the plastic bag. Keep that in a safe place. |
- | - Open VictronConnect, | + | - Open VictronConnect, |
- | - Select | + | - Once found, |
+ | - Open the Remote Console | ||
- | [[https://www.youtube.com/ | + | Notes: |
+ | * If you cannot use VictronConnect, | ||
+ | * For added security it is possible to disable the WiFi Access Point. See Settings | ||
- | - If you cannot use VictronConnect, | + | === Instruction |
- | [[https:// | + | Step by step instruction video on how to connect to a GX device using the [[https:// |
- | Note that for added security it is possible to disable the WiFi Access Point. See Settings -> Wi-Fi -> Create access point. | + | {{youtube>aKJMXxRIkG0}} |
- | **Caution**: | + | === Detailed instruction video === |
- | ==== 2.3 Finding the IP address ==== | + | |
- | If you've accidentally disabled Remote Console | + | This second video was made before VictronConnect got the feature to find a device |
+ | {{youtube> | ||
+ | ==== 2.3 Accessing via the local LAN/WiFi Network ==== | ||
+ | === 2.3.1 Introduction and common installations === | ||
+ | This section explains how to connected | ||
+ | This method does not require an internet connection. Just a local computer network is sufficient. | ||
+ | Once connected, connect | ||
+ | This video shows how its done: | ||
+ | {{youtube> | ||
+ | === 2.3.2 Alternative methods | ||
+ | In case VictronConnect can't be used, here are a few other methods to find the Venus GX, ie. its IP Address. | ||
__IP Address on VRM__ | __IP Address on VRM__ | ||
- | On VRM, you'll find the IP address on the Device List page of the installation. Note that this does require the Venus GX to be connected to the internet. | + | On the VRM Portal, you'll find the IP address on the Device List page of the installation. Note that this does require the Venus GX to be connected to the internet. |
Line 112: | Line 153: | ||
=== Long press: reset all network settings to factory defaults === | === Long press: reset all network settings to factory defaults === | ||
- | Press and hold the small button for a minimum of four seconds. The LED will stay on for 2 seconds to indicate that the log press has been recognised; then release the button again. | + | Press and hold the small button for a minimum of four seconds. The LED will stay on for 2 seconds to indicate that the long press has been recognised; then release the button again. |
* Ethernet is set back to DHCP | * Ethernet is set back to DHCP | ||
Line 178: | Line 219: | ||
The values/ | The values/ | ||
- | ===== 5. How does the Venus GX compare with the CCGX? | + | ===== 5. Factory reset ===== |
- | See [[: | + | |
- | ===== 6. Factory reset ===== | + | |
See above chapter 3.2 on the push button. | See above chapter 3.2 on the push button. | ||
- | ===== 7. More information ===== | + | |
+ | ===== 6. More information ===== | ||
