venus-gx:start
venus-gx:start [2019-06-09 07:47] – [6. Factory reset] mvader | venus-gx:start [2019-07-04 09:50] – [2.2 Accessing 'Remote Console' via the built-in WiFi Access Point] guy_stewart | ||
Line 48: | Line 48: | ||
- After searching, it will show up in the list: | - After searching, it will show up in the list: | ||
- Connect to WiFi using the 'WiFi key' which you will find printed on the side of the box ...and also on a card in the plastic bag - which you should keep in a safe place. | - Connect to WiFi using the 'WiFi key' which you will find printed on the side of the box ...and also on a card in the plastic bag - which you should keep in a safe place. | ||
- | - Once connected, navigate to 172.24.24.1 | + | - Open VictronConnect, and select the GX device from the Device list |
+ | - Select Remote Console - [[https:// | ||
+ | - If you cannot use VictronConnect, | ||
Note that for added security it is possible to disable the WiFi Access Point. See Settings -> Wi-Fi -> Create access point. | Note that for added security it is possible to disable the WiFi Access Point. See Settings -> Wi-Fi -> Create access point. | ||
**Caution**: | **Caution**: | ||
==== 2.3 Finding the IP address ==== | ==== 2.3 Finding the IP address ==== | ||
