venus-gx:start
venus-gx:start [2019-06-03 11:12] – [6. Factory reset] mvader | venus-gx:start [2019-06-03 11:46] – [6. Factory reset] guy_stewart | ||
Line 172: | Line 172: | ||
With above functionality in mind, the only real way to lock one self out completely is by changing the password of the Remote Console function, and then forgetting that. As long as that is not the case, its always possible to connect the device to an Ethernet network. In the (most common situation) that the Ethernet settings have been left at DHCP; then use VictronConnect to find the GX Device on the network. | With above functionality in mind, the only real way to lock one self out completely is by changing the password of the Remote Console function, and then forgetting that. As long as that is not the case, its always possible to connect the device to an Ethernet network. In the (most common situation) that the Ethernet settings have been left at DHCP; then use VictronConnect to find the GX Device on the network. | ||
=== Reconnect via Ethernet - unknown manually configured IP Address === | === Reconnect via Ethernet - unknown manually configured IP Address === |
