venus-gx:start
venus-gx:start [2019-01-22 10:16] – external edit 127.0.0.1 | venus-gx:start [2019-03-22 11:25] – [Venus GX (VGX) manual] guy_stewart | ||
Line 2: | Line 2: | ||
- | In many ways the **Venus GX (VGX)** and the **Color Control GX (CCGX)** are the same device. They share a lot of hardware, and they run on identical software - our 'Venus OS' - therefore firmware numbering is the same; and new version releases always apply to both devices at the same time. | + | In many ways the **Venus GX (VGX)** and the **Color Control GX (CCGX)** are the same device. They share a lot of hardware, and they run on identical software - our 'Venus OS' - therefore firmware numbering is the same; and new version releases always apply to both devices at the same time. |
+ | As many of the functions of the two devices are identical, the [[ccgx: | ||
This manual refers to the latest firmware version. A device connected to the internet will perform new-version updates automatically. Check the latest firmware version [[https:// | This manual refers to the latest firmware version. A device connected to the internet will perform new-version updates automatically. Check the latest firmware version [[https:// | ||
Line 112: | Line 114: | ||
==== 4.1. Wiring details ==== | ==== 4.1. Wiring details ==== | ||
The inputs are non-isolated. They operate at 3V3 levels, and can withstand up to 5V input. Each input has an internal 10k pull-up resistor to 3V3. We recommend wiring it to a potential free relay or otherwise open collector/ | The inputs are non-isolated. They operate at 3V3 levels, and can withstand up to 5V input. Each input has an internal 10k pull-up resistor to 3V3. We recommend wiring it to a potential free relay or otherwise open collector/ | ||
^ RJ12 pinout ^ Input ^ | ^ RJ12 pinout ^ Input ^ |
