vedirect_lorawan
vedirect_lorawan [2017-08-02 12:03] – [4. Installation] mvader | vedirect_lorawan [2023-10-10 11:54] (current) – [Details] sloges | ||
- | * [[https:// | + | |
- | The VE.Direct | + | Thank you for purchasing a VE.Direct |
- | You can even expand the IoT infrastructure to your area by establishing a new gateway, the hardware cost would be a few hundred Euro' | + | ===== LoRaWAN radio frequencies |
- | Note that whilst | + | **Warning: LoRaWAN Coverage** |
+ | The VE.Direct LoRaWAN (Long Range Wide Area Network) module is essentially a radio transmitter which broadcasts data (in this instance information about the status of your Victron installation) to a nearby LoRaWAN gateway. Typical range of a gateway is about 2km if you live in a town, but could be as far away as 15km if you live in a rural location. The VE.Direct LoRaWAN module uses the gateway infrastructure of 'The Things Network' | ||
+ | You can even expand the TTN infrastructure to your area by establishing a new gateway. The hardware cost would be a few hundred euro' | ||
+ | ==== Recommended LoRaWAN gateways ==== | ||
+ | https:// | ||
+ | https:// | ||
+ | We do not support the TTN AS923 frequency for Australia, only AU915. Please make sure your gateways are on the correct frequency. | ||
+ | Whilst | ||
- | The used LoRaWAN frequencies differ per region and country. We stock two different versions: | ||
- | * ASS030?????? | + | * ASS030540010 |
+ | * ASS030542010 - VE.Direct LoRaWAN AU915-928 module* | ||
+ | The EU version can be used in most of Europe and certain countries in Africa. The US model can be used in the Americas. | ||
- | The EU version can be used in most of Europe and certain countries in Africa. The US model in the Americas. See [[https:// | + | ===== Product compatibility |
- | ===== 3. Compatibility | + | |
- | * [[https:// | + | * Inverter VE.Direct models |
- | * 1.5m power cable with 3A inline fuse and M8 eyelets. | + | * 1.5m power cable with 3A inline fuse and M10 eyelets. |
Line 68: | Line 93: | ||
- | __MPPT | + | **MPPT |
Line 74: | Line 99: | ||
- | __Phoenix | + | **Inverter |
Line 84: | Line 109: | ||
+ | **Step 2:** LoRaWAN connection: Verify that the LED is blinking either green or yellow. After powerup, the LED will first blink blue. Which indicates that it is establishing communication with the LoRaWAN gateway and the TTN Network. Once connected to both, it will start blinking green (when there is a VE.Direct device) or yellow (when there is no VE.Direct device). In case it keeps blinking blue, check that the LoRaWAN gateway is in range, and check that the region and frequencies of the Gateway and the module match. See above for details. | ||
+ | ===== FAQ ===== | ||
+ | No. | ||
+ | No. | ||
+ | You can' | ||
+ | No you can' | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
- | ===== 6. FAQ ===== | + | - Change the parameters in the VE.Direct LoRaWAN module - which is currently not possible as there is no user interface nor communications port and or protocol to change its settings. |
- | //Will the module store data and send it out later when the gateway | + | The -unfortunate- conclusion |
- | *No. | + | |
- | *No. | + | |
- | //How can I connect multiple | + | |
- | *You can't. | + | |
- | *No you can' | + | |
- | //Can the module | + | |
- | *No. | + | |
- | *No. | + | |
- | //Can the module be used to remotely change the configuration | + | |
- | *No. | + | |
- | *No. | + | |
- | *No. | + | |
+ | **Q14 How about the TTN new v3 infrastructure? | ||
+ | The Things Network (TTN) has rolled out a new version of their infrastructure called V3. We migrated to this new V3 version of TTN in September 2021. For most users no action will be required, as | ||
- | ===== 7. DISQUS ===== | + | Note: If you are running your own gateway, please make sure you update it to work with the latest version of TTN and connect it to the appropriate cluster for your region, as they are taking their old infrastructure offline in December 2021 and all gateways still using this old version will cease to work. If you have an TTN account you will already have received an email about this change. Some users running their own gateways reported some problems with connectivity which was resolved by power cycling their gateways and VE.Direct LoRaWAN modules. |
vedirect_lorawan.1501668198.txt.gz · Last modified: 2017-08-02 12:03 by mvader
