vedirect_lorawan
| Both sides previous revisionPrevious revision | |||
| vedirect_lorawan [2022-04-25 07:59] – [Product compatibility] guystewart | vedirect_lorawan [2023-10-10 09:54] (current) – [Details] sloges | ||
| Line 9: | Line 9: | ||
| ===== Introduction ===== | ===== Introduction ===== | ||
| - | Thank you for purchasing a VE.Direct LoRaWAN module. It allows you to connect other Victron equipment, such as your Battery Monitor (BMV); Solar Charger; or Phoenix | + | Thank you for purchasing a VE.Direct LoRaWAN module. It allows you to connect other Victron equipment, such as your Battery Monitor (BMV); Solar Charger; or Inverter |
| ===== LoRaWAN radio frequencies and coverage ===== | ===== LoRaWAN radio frequencies and coverage ===== | ||
| Line 53: | Line 53: | ||
| * BMV Battery Monitor 700 series | * BMV Battery Monitor 700 series | ||
| * BMV Battery Monitor 712 Smart series | * BMV Battery Monitor 712 Smart series | ||
| - | * Phoenix | + | * Inverter VE.Direct models |
| The module is not compatible with our Peak Power Packs - even though they have a VE.Direct Port. | The module is not compatible with our Peak Power Packs - even though they have a VE.Direct Port. | ||
| Line 102: | Line 102: | ||
| * Charge state (Off, Bulk, Absorption, Equalize, Float) | * Charge state (Off, Bulk, Absorption, Equalize, Float) | ||
| - | **Phoenix | + | **Inverter |
| * Battery Voltage | * Battery Voltage | ||
vedirect_lorawan.1650873563.txt.gz · Last modified: by guystewart
