vedirect_lorawan
vedirect_lorawan [2021-10-04 09:24] – dvdgiessenvedirect_lorawan [2023-10-10 09:54] (current) – [Details] sloges
Line 9: Line 9:
 ===== Introduction ===== ===== Introduction =====
-Thank you for purchasing a VE.Direct LoRaWAN module. It allows you to connect other Victron equipment, such as your Battery Monitor (BMV); Solar Charger; or Phoenix Inverter, to the Victron Remote Management (VRM) portal. The portal is available to use free of charge, and from it you can view the status of your installation from anywhere in the world using your desktop device or mobile phone. +Thank you for purchasing a VE.Direct LoRaWAN module. It allows you to connect other Victron equipment, such as your Battery Monitor (BMV); Solar Charger; or Inverter VE.Direct, to the Victron Remote Management (VRM) portal. The portal is available to use free of charge, and from it, you can view the status of your installation from anywhere in the world using your desktop device or mobile phone.
 ===== LoRaWAN radio frequencies and coverage ===== ===== LoRaWAN radio frequencies and coverage =====
Line 53: Line 53:
   * BMV Battery Monitor 700 series     * BMV Battery Monitor 700 series
   * BMV Battery Monitor 712 Smart series     * BMV Battery Monitor 712 Smart series
-  * Phoenix Inverter VE.Direct models  +  * Inverter VE.Direct models
 The module is not compatible with our Peak Power Packs - even though they have a VE.Direct Port. The module is not compatible with our Peak Power Packs - even though they have a VE.Direct Port.
 +The LoRaWAN module is not compatible with the SmartShunt series.
 More information is also available on our website: https://www.victronenergy.com/panel-systems-remote-monitoring/ve-direct-lorawan More information is also available on our website: https://www.victronenergy.com/panel-systems-remote-monitoring/ve-direct-lorawan
Line 100: Line 102:
   * Charge state (Off, Bulk, Absorption, Equalize, Float)   * Charge state (Off, Bulk, Absorption, Equalize, Float)
-**Phoenix VE.Direct Inverters**+**Inverter VE.Direct**
   * Battery Voltage   * Battery Voltage
vedirect_lorawan.1633339445.txt.gz · Last modified: by dvdgiessen
