vedirect_lorawan
vedirect_lorawan [2021-01-12 16:19] – [LoRaWAN radio frequencies and coverage] mvader | vedirect_lorawan [2022-04-25 09:59] – [Product compatibility] guystewart | ||
Line 11: | Line 9: | ||
- | + | Thank you for purchasing a VE.Direct LoRaWAN module. It allows you to connect other Victron equipment, such as your Battery Monitor (BMV); Solar Charger; or Phoenix Inverter, to the Victron Remote Management (VRM) portal. The portal is available to use free of charge, and from it you can view the status of your installation from anywhere in the world using your desktop device or mobile phone. | |
- | Thank you for purchasing a VE.Direct LoRaWAN module. It allows you to connect other Victron equipment, such as your Battery Monitor (BMV); Solar Charger; or Phoenix Inverter, to the Victron Remote Management (VRM Portal) portal. The portal is available to use free of charge, and from it you can view the status of your installation from anywhere in the world using your desktop device or mobile phone. | + | |
===== LoRaWAN radio frequencies and coverage ===== | ===== LoRaWAN radio frequencies and coverage ===== | ||
- | **warning: LoRaWAN Coverage** | + | **Warning: LoRaWAN Coverage** |
The "The Things Network" | The "The Things Network" | ||
- | The VE.Direct LoRaWAN (Long Range wide area network) module is essentially a radio transmitter which broadcasts data (in this instance information about the status of your Victron installation) to a nearby | + | The VE.Direct LoRaWAN (Long Range Wide Area Network) module is essentially a radio transmitter which broadcasts data (in this instance information about the status of your Victron installation) to a nearby |
**tip: Add your own gateway** | **tip: Add your own gateway** | ||
- | You can even expand the TTN IoT infrastructure to your area by establishing a new gateway. The hardware cost would be a few hundred | + | You can even expand the TTN infrastructure to your area by establishing a new gateway. The hardware cost would be a few hundred |
==== Recommended LoRaWAN gateways ==== | ==== Recommended LoRaWAN gateways ==== | ||
Line 34: | Line 30: | ||
==== Bandwidth and frequencies ==== | ==== Bandwidth and frequencies ==== | ||
- | **warning: Unsupported Frequencies** | + | We do not support the TTN AS923 frequency |
- | We do not support the TTN AU923 Frequency | + | |
- | Whilst it's free to use, and long range, LoRaWAN is not high bandwidth. Therefore data is only sent once an hour …some less important data is only sent once every 24 hours. (See below for more information.) | + | Whilst it's free to use, and long range, LoRaWAN is not high bandwidth. Therefore |
Frequencies used by the LoRaWAN module differ by region and country. We stock three different versions: | Frequencies used by the LoRaWAN module differ by region and country. We stock three different versions: | ||
Line 46: | Line 42: | ||
* ASS030542010 - VE.Direct LoRaWAN AU915-928 module* | * ASS030542010 - VE.Direct LoRaWAN AU915-928 module* | ||
- | The EU version can be used in most of Europe and certain countries in Africa. The US model can be used in the Americas. | + | The EU version can be used in most of Europe and certain countries in Africa. The US model can be used in the Americas. |
Line 58: | Line 56: | ||
The module is not compatible with our Peak Power Packs - even though they have a VE.Direct Port. | The module is not compatible with our Peak Power Packs - even though they have a VE.Direct Port. | ||
Line 116: | Line 116: | ||
Line 137: | Line 137: | ||
Note that adding the installation on VRM can only be done when the result of the previous steps is OK: the LoRaWAN connections needs be ok and the VE.Direct cable needs to be connected to a product & communication properly. In short, the LED needs to blink green. If there is no VE.Direct data, the module will not send any data to VRM; and then will not be possible to register the installation on VRM. | Note that adding the installation on VRM can only be done when the result of the previous steps is OK: the LoRaWAN connections needs be ok and the VE.Direct cable needs to be connected to a product & communication properly. In short, the LED needs to blink green. If there is no VE.Direct data, the module will not send any data to VRM; and then will not be possible to register the installation on VRM. | ||
- | Note that there is one situation where the LED on the GlobalLink | + | Note that there is one situation where the LED on the VE.Direct LoRaWAN |
**Step 5:** Check LoRaWAN signal strength On VRM, go to the Device list entry and unfold the Gateway entry. In the list you will find the RSSI and SNR parameters, whom together indicate the quality of the wireless connection. | **Step 5:** Check LoRaWAN signal strength On VRM, go to the Device list entry and unfold the Gateway entry. In the list you will find the RSSI and SNR parameters, whom together indicate the quality of the wireless connection. | ||
Line 148: | Line 148: | ||
**Step 6:** Verify completeness of data on VRM The LoRaWAN network needs to receive three messages before making all the device data available on the VRM Portal. As the LoRaWAN network is a lossy network it is possible that not all of those messages are received the first time. These messages are only sent once every 24 hours by the VE.Direct LoRAWAN device. To solve without waiting 24 hours, power cycle the module and try again. | **Step 6:** Verify completeness of data on VRM The LoRaWAN network needs to receive three messages before making all the device data available on the VRM Portal. As the LoRaWAN network is a lossy network it is possible that not all of those messages are received the first time. These messages are only sent once every 24 hours by the VE.Direct LoRAWAN device. To solve without waiting 24 hours, power cycle the module and try again. | ||
===== FAQ ===== | ===== FAQ ===== | ||
Line 206: | Line 209: | ||
- Connect our VRM back-end to the other network. For which there is no standard API, and therefore requires Victron development resources. | - Connect our VRM back-end to the other network. For which there is no standard API, and therefore requires Victron development resources. | ||
- | The -unfortunate- conclusion is that the VE.Direct LoRaWAN module can only be used with the TTN network, and that we cannot help with with or support other networks. End of 2020 we'll launch | + | The -unfortunate- conclusion is that the VE.Direct LoRaWAN module can only be used with the TTN network, and that we cannot help with with or support other networks. End of 2020 we launched |
+ | **Q14 How about the TTN new v3 infrastructure? | ||
+ | The Things Network (TTN) has rolled out a new version of their infrastructure called V3. We migrated to this new V3 version of TTN in September 2021. For most users no action will be required, as | ||
+ | Note: If you are running your own gateway, please make sure you update it to work with the latest version of TTN and connect it to the appropriate cluster for your region, as they are taking their old infrastructure offline in December 2021 and all gateways still using this old version will cease to work. If you have an TTN account you will already have received an email about this change. Some users running their own gateways reported some problems with connectivity which was resolved by power cycling their gateways and VE.Direct LoRaWAN modules. |
