vedirect_lorawan
vedirect_lorawan [2020-05-28 07:16] – [Introduction] guy_stewart | vedirect_lorawan [2020-11-23 15:48] – [Product compatibility] lasse | ||
- | **tip: Software Update** | + | |
+ | ====== VE.Direct LoRaWAN module manual ====== | ||
+ | **NOTICE: Software Update** | ||
All units with versions earlier than v1.05 have been recalled for a free software update; due to the issue that they stop transmitting after a while. How long it takes before they stop transmitting varies; and is typically between 12 and 60 days. | All units with versions earlier than v1.05 have been recalled for a free software update; due to the issue that they stop transmitting after a while. How long it takes before they stop transmitting varies; and is typically between 12 and 60 days. | ||
You can find your version number in the VRM portal. Go to your installation -> open device list in the left menu -> unfold the gateway tab and find the firmware version. | You can find your version number in the VRM portal. Go to your installation -> open device list in the left menu -> unfold the gateway tab and find the firmware version. | ||
- | ====== VE.Direct LoRaWAN module manual ====== | ||
Line 16: | Line 18: | ||
**warning: LoRaWAN Coverage** | **warning: LoRaWAN Coverage** | ||
- | The LoRaWAN network is not a commercial network. Public gateways are maintained by the community and coverage can not be guaranteed. | + | The "The Things Network" |
The VE.Direct LoRaWAN (Long Range wide area network) module is essentially a radio transmitter which broadcasts data (in this instance information about the status of your Victron installation) to a nearby Internet of Things (IoT) gateway. The gateway should be within about 2km of your location if you live in a town, but could be as far away as 15km if you live in a rural location. This device uses infrastructure provided by 'The Things Network' | The VE.Direct LoRaWAN (Long Range wide area network) module is essentially a radio transmitter which broadcasts data (in this instance information about the status of your Victron installation) to a nearby Internet of Things (IoT) gateway. The gateway should be within about 2km of your location if you live in a town, but could be as far away as 15km if you live in a rural location. This device uses infrastructure provided by 'The Things Network' | ||
**tip: Add your own gateway** | **tip: Add your own gateway** | ||
- | You can even expand the IoT infrastructure to your area by establishing a new gateway. The hardware cost would be a few hundred Euro' | + | You can even expand the TTN IoT infrastructure to your area by establishing a new gateway. The hardware cost would be a few hundred Euro' |
==== Recommended LoRaWAN gateways ==== | ==== Recommended LoRaWAN gateways ==== | ||
Line 53: | Line 55: | ||
* BMV Battery Monitor 700 series | * BMV Battery Monitor 700 series | ||
* BMV Battery Monitor 712 Smart series | * BMV Battery Monitor 712 Smart series | ||
- | * [[https:// | ||
* Phoenix Inverter VE.Direct models | * Phoenix Inverter VE.Direct models | ||
Line 74: | Line 75: | ||
- Go to the VRM Portal to add your installation | - Go to the VRM Portal to add your installation | ||
Line 84: | Line 85: | ||
- | **BMV and SmartShunt | + | **BMV Battery Monitor |
Line 195: | Line 196: | ||
It is not possible to connect a VE.Direct devices with a single communications port (eg MPPT or BMV) to a GX device and the LoRaWan dongle at the same time. | It is not possible to connect a VE.Direct devices with a single communications port (eg MPPT or BMV) to a GX device and the LoRaWan dongle at the same time. | ||
+ | - Change the parameters in the VE.Direct LoRaWAN module - which is currently not possible as there is no user interface nor communications port and or protocol to change its settings. | ||
+ | The -unfortunate- conclusion is that the VE.Direct LoRaWAN module can only be used with the TTN network, and that we cannot help with with or support other networks. End of 2020 we'll launch another product, which uses the cellular LTE-M networks, and is a good alternative. | ||
