vedirect_lorawan
vedirect_lorawan [2019-11-08 14:53] – lasse | vedirect_lorawan [2023-10-10 11:54] (current) – [Details] sloges | ||
- | **tip: Software Update** | + | ====== VE.Direct LoRaWAN module manual ====== |
+ | **NOTICE: Software Update** | ||
All units with versions earlier than v1.05 have been recalled for a free software update; due to the issue that they stop transmitting after a while. How long it takes before they stop transmitting varies; and is typically between 12 and 60 days. | All units with versions earlier than v1.05 have been recalled for a free software update; due to the issue that they stop transmitting after a while. How long it takes before they stop transmitting varies; and is typically between 12 and 60 days. | ||
You can find your version number in the VRM portal. Go to your installation -> open device list in the left menu -> unfold the gateway tab and find the firmware version. | You can find your version number in the VRM portal. Go to your installation -> open device list in the left menu -> unfold the gateway tab and find the firmware version. | ||
- | ====== VE.Direct LoRaWAN module manual ====== | ||
- | + | Thank you for purchasing a VE.Direct LoRaWAN module. It allows you to connect other Victron equipment, such as your Battery Monitor (BMV); Solar Charger; or Inverter | |
- | Thank you for purchasing a VE.Direct LoRaWAN module. It allows you to connect other Victron equipment, such as your Battery Monitor (BMV); Solar Charger; or Phoenix | + | |
- | [[https:// | + | |
===== LoRaWAN radio frequencies and coverage ===== | ===== LoRaWAN radio frequencies and coverage ===== | ||
- | **warning: LoRaWAN Coverage** | + | **Warning: LoRaWAN Coverage** |
- | The LoRaWAN network is not a commercial network. Public gateways are maintained by the community and coverage can not be guaranteed. | + | The "The Things Network" |
- | The VE.Direct LoRaWAN (Long Range wide area network) module is essentially a radio transmitter which broadcasts data (in this instance information about the status of your Victron installation) to a nearby | + | The VE.Direct LoRaWAN (Long Range Wide Area Network) module is essentially a radio transmitter which broadcasts data (in this instance information about the status of your Victron installation) to a nearby |
**tip: Add your own gateway** | **tip: Add your own gateway** | ||
- | You can even expand the IoT infrastructure to your area by establishing a new gateway. The hardware cost would be a few hundred | + | You can even expand the TTN infrastructure to your area by establishing a new gateway. The hardware cost would be a few hundred |
==== Recommended LoRaWAN gateways ==== | ==== Recommended LoRaWAN gateways ==== | ||
Line 35: | Line 30: | ||
==== Bandwidth and frequencies ==== | ==== Bandwidth and frequencies ==== | ||
- | **warning: Unsupported Frequencies** | + | We do not support the TTN AS923 frequency |
- | We do not support the TTN AU923 Frequency | + | |
- | Whilst it's free to use, and long range, LoRaWAN is not high bandwidth. Therefore data is only sent once an hour …some less important data is only sent once every 24 hours. (See below for more information.) | + | Whilst it's free to use, and long range, LoRaWAN is not high bandwidth. Therefore |
Frequencies used by the LoRaWAN module differ by region and country. We stock three different versions: | Frequencies used by the LoRaWAN module differ by region and country. We stock three different versions: | ||
Line 47: | Line 42: | ||
* ASS030542010 - VE.Direct LoRaWAN AU915-928 module* | * ASS030542010 - VE.Direct LoRaWAN AU915-928 module* | ||
- | The EU version can be used in most of Europe and certain countries in Africa. The US model can be used in the Americas. | + | The EU version can be used in most of Europe and certain countries in Africa. The US model can be used in the Americas. |
Line 55: | Line 52: | ||
* All MPPT Solar Charge Controllers which have a VE.Direct Port | * All MPPT Solar Charge Controllers which have a VE.Direct Port | ||
* BMV Battery Monitor 700 series | * BMV Battery Monitor 700 series | ||
- | * BMV Battery Monitor | + | * BMV Battery Monitor |
- | * Phoenix | + | * Inverter VE.Direct models |
The module is not compatible with our Peak Power Packs - even though they have a VE.Direct Port. | The module is not compatible with our Peak Power Packs - even though they have a VE.Direct Port. | ||
Line 76: | Line 75: | ||
- Go to the VRM Portal to add your installation | - Go to the VRM Portal to add your installation | ||
Line 86: | Line 85: | ||
- | **BMV Battery Monitor** | + | **BMV Battery Monitor |
Line 103: | Line 102: | ||
- | **Phoenix | + | **Inverter |
Line 117: | Line 116: | ||
**Current draw** | **Current draw** | ||
- | 15 mA @ 12V | + | * 15 mA @ 12V |
- | 8,5 mA @ 24V | + | |
- | 5,5 mA @ 48V | + | |
===== Trouble shooting the connection ===== | ===== Trouble shooting the connection ===== | ||
Line 130: | Line 129: | ||
**Step 1:** Power: Verify that there is proper power supply connected, by checking the LED. It will always blink in some colour. | **Step 1:** Power: Verify that there is proper power supply connected, by checking the LED. It will always blink in some colour. | ||
- | **Step 2:** LoRaWAN connection Verify that the LED is blinking either green or yellow. After powerup, the LED will first blink blue. Which indicates that it is establishing communication with the LoRaWAN gateway and the TTN Network. Once connected to both, it will start blinking green (when there is a VE.Direct device) or yellow (when there is no VE.Direct device). In case it keeps blinking blue, check that the LoRaWAN gateway is in range, and check that the region and frequencies of the Gateway and the module match. See above for details. | + | **Step 2:** LoRaWAN connection: Verify that the LED is blinking either green or yellow. After powerup, the LED will first blink blue. Which indicates that it is establishing communication with the LoRaWAN gateway and the TTN Network. Once connected to both, it will start blinking green (when there is a VE.Direct device) or yellow (when there is no VE.Direct device). In case it keeps blinking blue, check that the LoRaWAN gateway is in range, and check that the region and frequencies of the Gateway and the module match. See above for details. |
**Step 3:** VE.Direct Make sure the LED is blinking green. In case its blinking yellow, check the cable to the VE.Direct device, and power to the VE.Direct device. | **Step 3:** VE.Direct Make sure the LED is blinking green. In case its blinking yellow, check the cable to the VE.Direct device, and power to the VE.Direct device. | ||
Line 137: | Line 136: | ||
Note that adding the installation on VRM can only be done when the result of the previous steps is OK: the LoRaWAN connections needs be ok and the VE.Direct cable needs to be connected to a product & communication properly. In short, the LED needs to blink green. If there is no VE.Direct data, the module will not send any data to VRM; and then will not be possible to register the installation on VRM. | Note that adding the installation on VRM can only be done when the result of the previous steps is OK: the LoRaWAN connections needs be ok and the VE.Direct cable needs to be connected to a product & communication properly. In short, the LED needs to blink green. If there is no VE.Direct data, the module will not send any data to VRM; and then will not be possible to register the installation on VRM. | ||
**Step 5:** Check LoRaWAN signal strength On VRM, go to the Device list entry and unfold the Gateway entry. In the list you will find the RSSI and SNR parameters, whom together indicate the quality of the wireless connection. | **Step 5:** Check LoRaWAN signal strength On VRM, go to the Device list entry and unfold the Gateway entry. In the list you will find the RSSI and SNR parameters, whom together indicate the quality of the wireless connection. | ||
===== FAQ ===== | ===== FAQ ===== | ||
Line 177: | Line 188: | ||
**Q9 Is a GX Device like a Color Control GX or Venus GX required?** | **Q9 Is a GX Device like a Color Control GX or Venus GX required?** | ||
- | No, the data will be sent straight to the VRM Portal. | + | No, a GX device is not required, the data from the VE.Direct device |
**Q10 The Peak Power Pack has a VE.Direct port, will the device work with that?** | **Q10 The Peak Power Pack has a VE.Direct port, will the device work with that?** | ||
- | No. | + | No. |
**Q11 I connected the module to a BMV, and then later connected it to an MPPT - but I can't see the new data …why not?** | **Q11 I connected the module to a BMV, and then later connected it to an MPPT - but I can't see the new data …why not?** | ||
Line 187: | Line 198: | ||
Make sure you power-cycle the LoRaWAN module by switching it off whilst connecting it to a different VE Direct device. Or wait for a minimum of 24 hours. | Make sure you power-cycle the LoRaWAN module by switching it off whilst connecting it to a different VE Direct device. Or wait for a minimum of 24 hours. | ||
+ | - Change the parameters in the VE.Direct LoRaWAN module - which is currently not possible as there is no user interface nor communications port and or protocol to change its settings. | ||
+ | The -unfortunate- conclusion is that the VE.Direct LoRaWAN module can only be used with the TTN network, and that we cannot help with with or support other networks. End of 2020 we launched another product, which uses the cellular LTE-M networks, and is a good alternative. See for more information: | ||
+ | **Q14 How about the TTN new v3 infrastructure? | ||
+ | The Things Network (TTN) has rolled out a new version of their infrastructure called V3. We migrated to this new V3 version of TTN in September 2021. For most users no action will be required, as | ||
+ | Note: If you are running your own gateway, please make sure you update it to work with the latest version of TTN and connect it to the appropriate cluster for your region, as they are taking their old infrastructure offline in December 2021 and all gateways still using this old version will cease to work. If you have an TTN account you will already have received an email about this change. Some users running their own gateways reported some problems with connectivity which was resolved by power cycling their gateways and VE.Direct LoRaWAN modules. |
