vedirect_lorawan
vedirect_lorawan [2019-10-02 11:11] – mvader | vedirect_lorawan [2020-11-23 15:48] – [Product compatibility] lasse | ||
- | This manual has moved to [[https://docs.victronenergy.com/ | + | **NOTICE: Software Update** |
+ | All units with versions earlier than v1.05 have been recalled for a free software update; due to the issue that they stop transmitting after a while. How long it takes before they stop transmitting varies; and is typically between 12 and 60 days. | ||
+ | You can find your version number in the VRM portal. Go to your installation -> open device list in the left menu -> unfold the gateway tab and find the firmware version. | ||
+ | ===== Introduction ===== | ||
+ | Thank you for purchasing a VE.Direct LoRaWAN module. It allows you to connect other Victron equipment, such as your Battery Monitor (BMV); Solar Charger; or Phoenix Inverter, to the Victron Remote Management (VRM Portal) portal. The portal is available to use free of charge, and from it you can view the status of your installation from anywhere in the world using your desktop device or mobile phone. | ||
+ | ===== LoRaWAN radio frequencies and coverage ===== | ||
+ | **warning: LoRaWAN Coverage** | ||
+ | The VE.Direct LoRaWAN (Long Range wide area network) module is essentially a radio transmitter which broadcasts data (in this instance information about the status of your Victron installation) to a nearby Internet of Things (IoT) gateway. The gateway should be within about 2km of your location if you live in a town, but could be as far away as 15km if you live in a rural location. | ||
+ | You can even expand the TTN IoT infrastructure | ||
+ | ==== Recommended LoRaWAN gateways ==== | ||
+ | https://www.lorixone.io/ | ||
+ | https:// | ||
+ | **warning: Unsupported Frequencies** | ||
+ | We do not support the TTN AU923 Frequency for Australia, only the AU915Mhz. Please make sure your gateways are on the correct frequency. | ||
+ | Whilst it's free to use, and long range, LoRaWAN is not high bandwidth. Therefore data is only sent once an hour …some less important data is only sent once every 24 hours. (See below for more information.) | ||
+ | * ASS030538010 - VE.Direct LoRaWAN EU863-870 module | ||
+ | * ASS030540010 - VE.Direct LoRaWAN US902-928 module | ||
+ | * ASS030542010 - VE.Direct LoRaWAN AU915-928 module* | ||
+ | The EU version can be used in most of Europe and certain countries in Africa. The US model can be used in the Americas. | ||
+ | ===== Product compatibility ===== | ||
+ | This module has one VE.Direct port and is compatible with: | ||
+ | * All MPPT Solar Charge Controllers which have a VE.Direct Port | ||
+ | * BMV Battery Monitor 700 series | ||
+ | * BMV Battery Monitor 712 Smart series | ||
+ | * Phoenix Inverter VE.Direct models | ||
+ | The module is not compatible with our Peak Power Packs - even though they have a VE.Direct Port. | ||
+ | More information is also available on our website: https://www.victronenergy.com/ | ||
+ | ===== Installation ===== | ||
+ | ==== What's in the box? ==== | ||
+ | * VE.Direct LoRaWAN module, with 1.5m VE.Direct cable | ||
+ | * RPSMA Antenna | ||
+ | * 1.5m power cable with 3A inline fuse and M10 eyelets. | ||
+ | * Quick-install guide | ||
+ | === Assembly instructions ==== | ||
+ | - Screw the antenna onto the LoRaWAN Module | ||
+ | - Mount the LoRaWAN Module close to the device you wish to monitor | ||
+ | - Connect the VE.Direct cable between devices | ||
+ | - Connect the DC Power (8V - 68V, looking to the module with green connector below of the module, the positive is on the left) | ||
+ | - After a short wait the LED will blink green indicating that all is OK | ||
+ | - Go to the VRM Portal to add your installation | ||
+ | ===== Details ===== | ||
+ | After power-up, the module will gather information from the VE.Direct device. Once received it connects to the LoRaWAN network, and then sends all available data to the VRM Portal. | ||
+ | After this first transmission, | ||
+ | **BMV Battery Monitor (It does not support the SmartShunt)** | ||
+ | * Battery Voltage | ||
+ | * Battery Current | ||
+ | * Battery Power | ||
+ | * State of Charge | ||
+ | * Alarm status & reason | ||
+ | **MPPT Solar Charger** | ||
+ | * Solar Power | ||
+ | * Error code | ||
+ | * Charge state (Off, Bulk, Absorption, Equalize, Float) | ||
+ | **Phoenix VE.Direct Inverters** | ||
+ | * AC Output current | ||
+ | * Mode (On/ | ||
+ | Note that data may not always arrive at the VRM Portal every hour. Transmission over the air can fail - even when your LoRaWAN device is mounted close to a gateway. This is normal and part of the LoRaWAN concept. | ||
+ | **LED Codes** | ||
+ | | LED Status | Definition | | ||
+ | | Blinking blue | Connecting to LoRaWAN. If your module keeps blinking blue, check LoRaWAN Network coverage. | | ||
+ | | Blinking green | Everything is OK and a connection has been made both to LoRaWAN and to the VE.Direct device. | | ||
+ | | Blinking yellow | You're connected to LoRaWAN, but not to the VE.Direct device: Check the cable & power to the VE.Direct device. | | ||
+ | | Continuous red | Error. The module will automatically reboot within ten seconds. | | ||
+ | **Current draw** | ||
+ | * 15 mA @ 12V | ||
+ | * 8,5 mA @ 24V | ||
+ | * 5,5 mA @ 48V | ||
+ | **Step 2:** LoRaWAN connection Verify that the LED is blinking either green or yellow. After powerup, the LED will first blink blue. Which indicates that it is establishing communication with the LoRaWAN gateway and the TTN Network. Once connected to both, it will start blinking green (when there is a VE.Direct device) or yellow (when there is no VE.Direct device). In case it keeps blinking blue, check that the LoRaWAN gateway is in range, and check that the region and frequencies of the Gateway and the module match. See above for details. | ||
+ | ===== FAQ ===== | ||
+ | No. | ||
+ | No. | ||
+ | You can' | ||
+ | No you can' | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
+ | - Change the parameters in the VE.Direct LoRaWAN module - which is currently not possible as there is no user interface nor communications port and or protocol to change its settings. | ||
+ | The -unfortunate- conclusion is that the VE.Direct LoRaWAN module can only be used with the TTN network, and that we cannot help with with or support other networks. End of 2020 we'll launch another product, which uses the cellular LTE-M networks, and is a good alternative. | ||
