Both sides previous revisionPrevious revision | Next revisionBoth sides next revision |
vedirect_lorawan [2019-01-22 10:16] – external edit 127.0.0.1 | vedirect_lorawan [2019-05-23 16:14] – [1. Introduction] guy_stewart |
===== 1. Introduction ===== | ===== 1. Introduction ===== |
Thank you for purchasing a [[https://www.victronenergy.com/panel-systems-remote-monitoring/ve-direct-lorawan|VE.Direct LoRaWAN module]]. It allows you to connect other Victron equipment, such as your Battery Monitor (BMV); Solar Charger; or Phoenix Inverter, to the Victron Remote Management ([[https://vrm.victronenergy.com/|VRM Portal]]) portal. The portal is available to use free of charge, and from it you can view the status of your installation from anywhere in the world using your desktop device or mobile phone. Here are some examples of the kind of information you will be able to view: | Thank you for purchasing a [[https://www.victronenergy.com/panel-systems-remote-monitoring/ve-direct-lorawan|VE.Direct LoRaWAN module]]. It allows you to connect other Victron equipment, such as your Battery Monitor (BMV); MPPT Solar Charger; or Phoenix Inverter, to the Victron Remote Management ([[https://vrm.victronenergy.com/|VRM Portal]]) portal. The portal is available to use free of charge, and from it you can view the status of your installation from anywhere in the world using your desktop device or mobile phone. Here are some examples of the kind of information you will be able to view: |
* [[https://vrm.victronenergy.com/installation/13561/share/dc5d745e|BMV Battery Monitor demo]] | * [[https://vrm.victronenergy.com/installation/13561/share/dc5d745e|BMV Battery Monitor demo]] |
