vedirect_lorawan
vedirect_lorawan [2019-01-21 11:20] – [7. DISQUS] ictbeheer | vedirect_lorawan [2019-11-08 14:53] – lasse | ||
+ | **tip: Software Update** | ||
+ | All units with versions earlier than v1.05 have been recalled for a free software update; due to the issue that they stop transmitting after a while. How long it takes before they stop transmitting varies; and is typically between 12 and 60 days. | ||
+ | You can find your version number in the VRM portal. Go to your installation -> open device list in the left menu -> unfold the gateway tab and find the firmware version. | ||
- | ===== 1. Introduction ===== | + | ===== Introduction ===== |
+ | Thank you for purchasing a VE.Direct LoRaWAN module. It allows you to connect other Victron equipment, such as your Battery Monitor (BMV); Solar Charger; or Phoenix Inverter, to the Victron Remote Management (VRM Portal) portal. The portal is available to use free of charge, and from it you can view the status of your installation from anywhere in the world using your desktop device or mobile phone. Here are some examples of the kind of information you will be able to view: | ||
- | Thank you for purchasing a [[https://www.victronenergy.com/ | + | [[https://vrm.victronenergy.com/ |
- | * [[https:// | + | ===== LoRaWAN radio frequencies and coverage ===== |
- | * [[https:// | + | |
- | ===== 2. LoRaWAN | + | **warning: |
+ | The LoRaWAN network is not a commercial network. Public gateways are maintained by the community | ||
- | The VE.Direct LoRaWAN (Long Range wide area network) module is essentially a radio transmitter which broadcasts data (in this instance information about the status of your Victron installation) to a nearby Internet of Things (IoT) gateway. The gateway should be within about 2km of your location if you live in a town, but could be as far away as 30km if you live in a rural location. This device uses infrastructure provided by 'The Things Network' | + | The VE.Direct LoRaWAN (Long Range wide area network) module is essentially a radio transmitter which broadcasts data (in this instance information about the status of your Victron installation) to a nearby Internet of Things (IoT) gateway. The gateway should be within about 2km of your location if you live in a town, but could be as far away as 15km if you live in a rural location. This device uses infrastructure provided by 'The Things Network' |
You can even expand the IoT infrastructure to your area by establishing a new gateway. The hardware cost would be a few hundred Euro' | You can even expand the IoT infrastructure to your area by establishing a new gateway. The hardware cost would be a few hundred Euro' | ||
- | ==== 2.1 Recommended LoRaWAN gateways ==== | + | ==== Recommended LoRaWAN gateways ==== |
- | * https:// | + | https:// |
- | ==== 2.2 Bandwidth and frequencies ==== | + | You can follow this great guide on how to setup for the The Things Network: |
+ | https://www.thethingsnetwork.org/ | ||
- | Note that whilst | + | ==== Bandwidth and frequencies ==== |
+ | **warning: Unsupported Frequencies** | ||
+ | We do not support the TTN AU923 Frequency for Australia, only the AU915Mhz. Please make sure your gateways are on the correct frequency. | ||
+ | Whilst | ||
- | Frequencies used by the LoRaWAN module differ by region and country. We stock two different versions: | ||
* ASS030540010 - VE.Direct LoRaWAN US902-928 module | * ASS030540010 - VE.Direct LoRaWAN US902-928 module | ||
- | * ASS030542010 - VE.Direct LoRaWAN AU915-928 module | + | * ASS030542010 - VE.Direct LoRaWAN AU915-928 module* |
- | The EU version can be used in most of Europe and certain countries in Africa. The US model can be used in the Americas. [[https:// | + | The EU version can be used in most of Europe and certain countries in Africa. The US model can be used in the Americas. |
- | ===== 3. Product compatibility ===== | + | ===== Product compatibility ===== |
- | * [[https:// | + | * BMV Battery Monitor 710 Smart series |
- | * [[https:// | + | * Phoenix Inverter VE.Direct models |
* 1.5m power cable with 3A inline fuse and M10 eyelets. | * 1.5m power cable with 3A inline fuse and M10 eyelets. | ||
Line 59: | Line 78: | ||
- Connect the DC Power (8V - 68V) | - Connect the DC Power (8V - 68V) | ||
Line 76: | Line 94: | ||
- | __MPPT | + | **MPPT |
Line 82: | Line 100: | ||
- | __Phoenix | + | **Phoenix |
Line 92: | Line 110: | ||
| Blinking green | Everything is OK and a connection has been made both to LoRaWAN and to the VE.Direct device. | | | Blinking green | Everything is OK and a connection has been made both to LoRaWAN and to the VE.Direct device. | | ||
Line 102: | Line 121: | ||
- | | + | 15 mA @ 12V |
- | * 8,5 mA @ 24V | + | 8,5 mA @ 24V |
- | * 5,5 mA @ 48V | + | 5,5 mA @ 48V |
+ | **Step 2:** LoRaWAN connection Verify that the LED is blinking either green or yellow. After powerup, the LED will first blink blue. Which indicates that it is establishing communication with the LoRaWAN gateway and the TTN Network. Once connected to both, it will start blinking green (when there is a VE.Direct device) or yellow (when there is no VE.Direct device). In case it keeps blinking blue, check that the LoRaWAN gateway is in range, and check that the region and frequencies of the Gateway and the module match. See above for details. | ||
+ | ===== FAQ ===== | ||
+ | No. | ||
+ | No. | ||
+ | You can' | ||
+ | No you can' | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
+ | No, the data will be sent straight to the VRM Portal. | ||
- | ===== 6. FAQ ===== | + | No. |
- | //Will the module store data and send it out later when the gateway is in range?// | + | **Q11 I connected the module to a BMV, and then later connected it to an MPPT - but I can't see the new data …why not?** |
- | *No. | + | |
- | //How can I connect multiple VE.Direct devices to one LoRaWAN module?// | + | |
- | *You can' | + | |
- | *No you can' | + | |
- | //Can the module be used to remotely switch the load output of an MPPT?// | + | |
- | *No. | + | |
- | *No. | + | |
- | //Can the module be used to remotely change the configuration of the BMV, MPPT or Inverter?// | + | |
- | *No. | + | |
- | *No. | + | |
