vedirect_lorawan
vedirect_lorawan [2018-04-30 21:35] – [3. Compatibility] mvader | vedirect_lorawan [2023-10-10 11:54] (current) – [Details] sloges | ||
- | * [[https:// | + | |
- | The VE.Direct LoRaWAN (Long Range wide area network) module is essentially a radio transmitter which broadcasts data (in this instance information about the status of your Victron | + | Thank you for purchasing a VE.Direct LoRaWAN |
- | You can even expand the IoT infrastructure to your area by establishing a new gateway. The hardware cost would be a few hundred Euro' | + | ===== LoRaWAN radio frequencies |
- | ==== 2.1 Recommended | + | **Warning: |
- | * https://lorixone.io/#products | + | The VE.Direct LoRaWAN (Long Range Wide Area Network) module is essentially a radio transmitter which broadcasts data (in this instance information about the status of your Victron installation) to a nearby LoRaWAN gateway. Typical range of a gateway is about 2km if you live in a town, but could be as far away as 15km if you live in a rural location. The VE.Direct LoRaWAN module uses the gateway infrastructure of 'The Things Network' |
- | ==== 2.2 Bandwidth | + | **tip: Add your own gateway** |
+ | You can even expand the TTN infrastructure to your area by establishing a new gateway. The hardware cost would be a few hundred euro' | ||
- | Note that whilst | + | ==== Recommended LoRaWAN gateways ==== |
+ | https:// | ||
+ | https:// | ||
+ | We do not support the TTN AS923 frequency for Australia, only AU915. Please make sure your gateways are on the correct frequency. | ||
+ | Whilst | ||
- | Frequencies used by the LoRaWAN module differ by region and country. We stock two different versions: | ||
* ASS030540010 - VE.Direct LoRaWAN US902-928 module | * ASS030540010 - VE.Direct LoRaWAN US902-928 module | ||
- | * ASS030542010 - VE.Direct LoRaWAN AU915-928 module | + | * ASS030542010 - VE.Direct LoRaWAN AU915-928 module* |
+ | The EU version can be used in most of Europe and certain countries in Africa. The US model can be used in the Americas. | ||
- | The EU version can be used in most of Europe and certain countries in Africa. The US model can be used in the Americas. [[https:// | + | The Things Network deploys multiple clusters. If you are setting up your own gateway, please make sure it is connected to the appropriate TTN cluster for your region. EU868 should use '' |
- | ===== 3. Product compatibility ===== | + | ===== Product compatibility ===== |
- | * [[https:// | + | * Inverter VE.Direct models |
* 1.5m power cable with 3A inline fuse and M10 eyelets. | * 1.5m power cable with 3A inline fuse and M10 eyelets. | ||
Line 76: | Line 93: | ||
- | __MPPT | + | **MPPT |
Line 82: | Line 99: | ||
- | __Phoenix | + | **Inverter |
Line 92: | Line 109: | ||
+ | **Step 2:** LoRaWAN connection: Verify that the LED is blinking either green or yellow. After powerup, the LED will first blink blue. Which indicates that it is establishing communication with the LoRaWAN gateway and the TTN Network. Once connected to both, it will start blinking green (when there is a VE.Direct device) or yellow (when there is no VE.Direct device). In case it keeps blinking blue, check that the LoRaWAN gateway is in range, and check that the region and frequencies of the Gateway and the module match. See above for details. | ||
+ | ===== FAQ ===== | ||
+ | No. | ||
+ | No. | ||
+ | You can' | ||
+ | No you can' | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
+ | - Change the parameters in the VE.Direct LoRaWAN module - which is currently not possible as there is no user interface nor communications port and or protocol to change its settings. | ||
- | ===== 6. FAQ ===== | + | The -unfortunate- conclusion is that the VE.Direct LoRaWAN module can only be used with the TTN network, and that we cannot help with with or support other networks. End of 2020 we launched another product, which uses the cellular LTE-M networks, and is a good alternative. See for more information: |
- | //Will the module store data and send it out later when the gateway is in range?// | + | **Q14 How about the TTN new v3 infrastructure?** |
- | //How can I connect multiple VE.Direct devices to one LoRaWAN module?// | + | |
- | *You can' | + | |
- | //Can the module be used to remotely switch the load output of an MPPT?// | + | |
- | *No. | + | |
- | //Can the module be used to remotely change the configuration of the BMV, MPPT or Inverter?// | + | |
- | *No. | + | |
- | *No. | + | |
- | *No. | + | |
- | ===== 7. DISQUS ===== | + | The Things Network (TTN) has rolled out a new version of their infrastructure called V3. We migrated to this new V3 version of TTN in September 2021. For most users no action will be required, as |
- | ~~DISQUS~~ | + | Note: If you are running your own gateway, please make sure you update it to work with the latest version of TTN and connect it to the appropriate cluster for your region, as they are taking their old infrastructure offline in December 2021 and all gateways still using this old version will cease to work. If you have an TTN account you will already have received an email about this change. Some users running their own gateways reported some problems with connectivity which was resolved by power cycling their gateways and VE.Direct LoRaWAN modules. |
