vedirect_lorawan
vedirect_lorawan [2017-11-22 14:16] – [2. LoRaWAN radio frequencies and coverage] mvader | vedirect_lorawan [2022-04-25 09:59] – [Product compatibility] guystewart | ||
- | * [[https:// | + | |
- | The VE.Direct LoRaWAN (Long Range wide area network) module is essentially a radio transmitter which broadcasts data (in this instance information about the status of your Victron | + | Thank you for purchasing a VE.Direct LoRaWAN |
- | You can even expand the IoT infrastructure to your area by establishing a new gateway. The hardware cost would be a few hundred Euro' | + | ===== LoRaWAN radio frequencies |
- | Note that whilst it's free to use, and long range, | + | **Warning: |
- | Frequencies used by the LoRaWAN module differ by region and country. We stock two different versions: | + | The VE.Direct LoRaWAN |
- | * ASS030538010 - VE.Direct LoRaWAN | + | |
- | * ASS030540010 - VE.Direct | + | |
- | * ASS030542010 - VE.Direct LoRaWAN | + | |
- | The EU version | + | **tip: Add your own gateway** |
+ | You can even expand the TTN infrastructure to your area by establishing a new gateway. The hardware cost would be a few hundred euro's, and you would need a power supply and an internet connection. Make sure to buy a multi channel gateway. The lower cost single channel gateways are not supported. | ||
- | ===== 3. Application example: small boat monitoring ===== | + | ==== Recommended LoRaWAN gateways |
- | How to monitor, on a (small, perhaps electric-) boat, that the shore is properly connected and the battery is being charged, as well as one or more bilge alarms? | + | https:// |
- | All that is needed is a BMV-712 (or BMV-702) and the VE.Direct LoRaWAN module. Instructions: | + | You can follow this great guide on how to setup for the The Things Network: |
+ | https://www.thethingsnetwork.org/ | ||
- | * Wire and configure the BMV and its main voltage input & shunt as usual | + | ==== Bandwidth |
- | * Wire the aux voltage sense input on the BMV via the normally closed contact of the bilge alarm to the battery positive as well. In case of multiple bilge alarms, wire them in series. | + | |
- | * Connect and install the VE.Direct LoRaWAN module, as explained below. | + | |
- | To get all alerts, make the following setup on VRM: | + | **Warning: Unsupported Frequencies** |
- | * Enable | + | We do not support |
- | * Create an alarm on main battery voltage ( > 13.0 V to see that its being charged. Once the charger is not charging, for whatever reason such as for example a unplugged shore cable, the battery voltage will drop. A fully charged, disconnected, | + | |
- | * Create an alarm on the aux voltage; that triggers when the voltage is below 6V. In an open circuit condition, the voltage measured by the AUX input on the BMV will be 0V. | + | |
- | ===== 4. Compatibility | + | Whilst it's free to use, and long range, LoRaWAN is not high bandwidth. Therefore the most important data is only sent once an hour and some less important data is only sent once every 24 hours. (See below for more information.) |
+ | * ASS030538010 - VE.Direct LoRaWAN EU863-870 module | ||
+ | * ASS030540010 - VE.Direct LoRaWAN US902-928 module | ||
+ | * ASS030542010 - VE.Direct LoRaWAN AU915-928 module* | ||
+ | The EU version can be used in most of Europe and certain countries in Africa. The US model can be used in the Americas. | ||
+ | ===== Product compatibility | ||
- | * [[https:// | + | * Phoenix Inverter VE.Direct models |
- | ===== 5. Installation ===== | + | ===== Installation ===== |
* 1.5m power cable with 3A inline fuse and M10 eyelets. | * 1.5m power cable with 3A inline fuse and M10 eyelets. | ||
- | ===== 6. Details ===== | + | ===== Details ===== |
Line 86: | Line 93: | ||
- | __MPPT | + | **MPPT |
Line 92: | Line 99: | ||
- | __Phoenix | + | **Phoenix |
Line 102: | Line 109: | ||
+ | **Step 2:** LoRaWAN connection: Verify that the LED is blinking either green or yellow. After powerup, the LED will first blink blue. Which indicates that it is establishing communication with the LoRaWAN gateway and the TTN Network. Once connected to both, it will start blinking green (when there is a VE.Direct device) or yellow (when there is no VE.Direct device). In case it keeps blinking blue, check that the LoRaWAN gateway is in range, and check that the region and frequencies of the Gateway and the module match. See above for details. | ||
+ | ===== FAQ ===== | ||
+ | No. | ||
+ | No. | ||
+ | You can' | ||
+ | No you can' | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
+ | - Change the parameters in the VE.Direct LoRaWAN module - which is currently not possible as there is no user interface nor communications port and or protocol to change its settings. | ||
- | ===== 7. FAQ ===== | + | The -unfortunate- conclusion is that the VE.Direct LoRaWAN module can only be used with the TTN network, and that we cannot help with with or support other networks. End of 2020 we launched another product, which uses the cellular LTE-M networks, and is a good alternative. See for more information: |
- | //Will the module store data and send it out later when the gateway is in range?// | + | **Q14 How about the TTN new v3 infrastructure?** |
- | //How can I connect multiple VE.Direct devices to one LoRaWAN module?// | + | |
- | *You can' | + | |
- | //Can the module be used to remotely switch the load output of an MPPT?// | + | |
- | *No. | + | |
- | //Can the module be used to remotely change the configuration of the BMV, MPPT or Inverter?// | + | |
- | *No. | + | |
- | *No. | + | |
- | *No. | + | |
- | ===== 8. DISQUS ===== | + | The Things Network (TTN) has rolled out a new version of their infrastructure called V3. We migrated to this new V3 version of TTN in September 2021. For most users no action will be required, as |
- | ~~DISQUS~~ | + | Note: If you are running your own gateway, please make sure you update it to work with the latest version of TTN and connect it to the appropriate cluster for your region, as they are taking their old infrastructure offline in December 2021 and all gateways still using this old version will cease to work. If you have an TTN account you will already have received an email about this change. Some users running their own gateways reported some problems with connectivity which was resolved by power cycling their gateways and VE.Direct LoRaWAN modules. |
