vedirect_lorawan
vedirect_lorawan [2017-07-31 10:59] – [5. Details] justin | vedirect_lorawan [2022-04-25 09:59] – [Product compatibility] guystewart | ||
- | * [[https:// | + | |
- | ===== 2. Background Information | + | ===== Introduction |
- | The VE.Direct | + | Thank you for purchasing a VE.Direct |
- | You can even expand the IoT infrastructure to your area by establishing a new gateway, the hardware cost would be a few hundred Euro' | + | ===== LoRaWAN radio frequencies |
- | Note that whilst it's free to use, and long range, | + | **Warning: |
- | Note also that the VE.Direct LoRaWAN | + | The VE.Direct LoRaWAN |
- | ===== 3. Compatibility | + | **tip: Add your own gateway** |
+ | You can even expand the TTN infrastructure to your area by establishing a new gateway. The hardware cost would be a few hundred euro' | ||
+ | ==== Recommended LoRaWAN gateways | ||
+ | https://www.lorixone.io/ | ||
+ | https:// | ||
+ | We do not support the TTN AS923 frequency for Australia, only AU915. Please make sure your gateways are on the correct frequency. | ||
+ | Whilst it's free to use, and long range, LoRaWAN is not high bandwidth. Therefore the most important data is only sent once an hour and some less important data is only sent once every 24 hours. (See below for more information.) | ||
+ | * ASS030538010 - VE.Direct LoRaWAN EU863-870 module | ||
+ | * ASS030540010 - VE.Direct LoRaWAN US902-928 module | ||
+ | * ASS030542010 - VE.Direct LoRaWAN AU915-928 module* | ||
+ | The EU version can be used in most of Europe and certain countries in Africa. The US model can be used in the Americas. | ||
+ | ===== Product compatibility | ||
- | * [[https:// | + | * Phoenix Inverter VE.Direct models |
+ | The module is not compatible with our Peak Power Packs - even though they have a VE.Direct Port. | ||
- | The module is not compatible with our **Peak Power Packs** - even though they have a VE.Direct Port. | + | The LoRaWAN |
- | * 1.5m power cable with inline fuse and M8 eyelets. | + | * 1.5m power cable with 3A inline fuse and M10 eyelets. |
- | - Connect the DC Power (8V - 68V). (The in-line fuse is rated at 3A) | + | - Connect the DC Power (8V - 68V, looking to the module with green connector below of the module, the positive |
Line 65: | Line 93: | ||
- | __MPPT | + | **MPPT |
Line 71: | Line 99: | ||
- | __Phoenix | + | **Phoenix |
Line 81: | Line 109: | ||
+ | **Step 2:** LoRaWAN connection: Verify that the LED is blinking either green or yellow. After powerup, the LED will first blink blue. Which indicates that it is establishing communication with the LoRaWAN gateway and the TTN Network. Once connected to both, it will start blinking green (when there is a VE.Direct device) or yellow (when there is no VE.Direct device). In case it keeps blinking blue, check that the LoRaWAN gateway is in range, and check that the region and frequencies of the Gateway and the module match. See above for details. | ||
+ | ===== FAQ ===== | ||
+ | No. | ||
+ | No. | ||
+ | You can' | ||
+ | No you can' | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
+ | No. | ||
- | ===== 6. FAQ ===== | + | - Change the parameters in the VE.Direct LoRaWAN module - which is currently not possible as there is no user interface nor communications port and or protocol to change its settings. |
- | //Will the module store data and send it out later when the gateway | + | The -unfortunate- conclusion |
- | *No. | + | |
- | *No. | + | |
- | //Can the module be used to remotely switch the load output of an MPPT?// | + | |
- | *No. | + | |
- | *No. | + | |
- | //Can the module be used to remotely change the configuration | + | |
- | *No. | + | |
- | *No. | + | |
- | //The **Peak Power Pack** has a VE.Direct port, will the device work with that?// | + | |
- | *No. | + | |
+ | **Q14 How about the TTN new v3 infrastructure? | ||
+ | The Things Network (TTN) has rolled out a new version of their infrastructure called V3. We migrated to this new V3 version of TTN in September 2021. For most users no action will be required, as | ||
- | ===== 7. DISQUS ===== | + | Note: If you are running your own gateway, please make sure you update it to work with the latest version of TTN and connect it to the appropriate cluster for your region, as they are taking their old infrastructure offline in December 2021 and all gateways still using this old version will cease to work. If you have an TTN account you will already have received an email about this change. Some users running their own gateways reported some problems with connectivity which was resolved by power cycling their gateways and VE.Direct LoRaWAN modules. |
