vedirect_lorawan
vedirect_lorawan [2022-04-25 09:59] – [Product compatibility] guystewart | vedirect_lorawan [2023-10-10 11:54] (current) – [Details] sloges | ||
Line 9: | Line 9: | ||
- | Thank you for purchasing a VE.Direct LoRaWAN module. It allows you to connect other Victron equipment, such as your Battery Monitor (BMV); Solar Charger; or Phoenix | + | Thank you for purchasing a VE.Direct LoRaWAN module. It allows you to connect other Victron equipment, such as your Battery Monitor (BMV); Solar Charger; or Inverter |
===== LoRaWAN radio frequencies and coverage ===== | ===== LoRaWAN radio frequencies and coverage ===== | ||
Line 53: | Line 53: | ||
* BMV Battery Monitor 700 series | * BMV Battery Monitor 700 series | ||
* BMV Battery Monitor 712 Smart series | * BMV Battery Monitor 712 Smart series | ||
- | * Phoenix | + | * Inverter VE.Direct models |
The module is not compatible with our Peak Power Packs - even though they have a VE.Direct Port. | The module is not compatible with our Peak Power Packs - even though they have a VE.Direct Port. | ||
Line 102: | Line 102: | ||
- | **Phoenix | + | **Inverter |
* Battery Voltage | * Battery Voltage |
