vebus_smart_dongle_manual [2021-01-18 12:22] – [Introduction] guystewart | vebus_smart_dongle_manual [2021-03-20 03:25] – guystewart |
^ Function ^ Minimum Multi firmware version ^ Note ^ | ^ Function ^ Minimum Multi firmware version ^ Note ^ |
| Battery voltage and temperature sense | 419 | | | | Battery voltage and temperature sense | 419 | | |
| Input current limit and on/off/charger only control | 415 | Not supported when a DMC and/or VeBus BMS is installed | | | Input current limit and on/off/charger only control | 415 | Not supported when a Digital Multi Control (DMC) is installed, VE.Bus Smart Dongle requires VictronConnect 5.36 or later | |
When used with Multi- inverter/chargers the dongle provides //on-battery// temperature and voltage sensing capabilities - allowing compensation for possible cable losses which can occur during charging and discharging. Temperature sensing allows accurate temperature-compensation during battery charge cycles. The dongle is, at present, the //only// way to add an "on-battery" sensing capability to the MultiPlus-II models, if they are not also connected to a [[venus-os:start|GX device]] and CANbus battery. | When used with Multi- inverter/chargers the dongle provides //on-battery// temperature and voltage sensing capabilities - allowing compensation for possible cable losses which can occur during charging and discharging. Temperature sensing allows accurate temperature-compensation during battery charge cycles. The dongle is, at present, the //only// way to add an "on-battery" sensing capability to the MultiPlus-II models, if they are not also connected to a [[venus-os:start|GX device]] and CANbus battery. |
The dongle can be used in systems with or without a [[venus-os:start|GX device]] - such as the CCGX. In systems //with// a [[venus-os:start|GX device]], and another source of temperature and voltage data (eg from a CANbus battery), the CCGX data will override temperature and voltage information from the dongle. In this role the dongle will still provide live-information via its VictronConnect interface; and it will provide firmware updates without requiring an internet connection. | The dongle can be used in systems with or without a [[venus-os:start|GX device]] - such as the Cerbo GX. In systems //with// a [[venus-os:start|GX device]], and another source of temperature and voltage data (eg from a CANbus battery), the GX device data will override temperature and voltage information from the dongle. In this role the dongle will still provide live-information via its VictronConnect interface; and it will provide firmware updates without requiring an internet connection. |
When the dongle is used in systems which //do not// have a [[venus-os:start|GX device]], the dongle's voltage and temperature data becomes the primary source of that information, and can be used by other connected devices for voltage compensation. | When the dongle is used in systems which //do not// have a [[venus-os:start|GX device]], the dongle's voltage and temperature data becomes the primary source of that information, and can be used by other connected devices for voltage compensation. |
===== Modes of operation ==== | ===== Modes of operation ==== |
The dongle can operate both as a //primary// and a //background// information source. It will assume either role automatically depending on whether a [[venus-os:start|GX device]] (CCGX/VenusGX/OctoGX) is present in the system. | The dongle can operate both as a //primary// and a //background// information source. It will assume either role automatically depending on whether a [[venus-os:start|GX device]] (Cerbo GX) is present in the system. |
Due to restrictions in the VE.Bus communication protocol only one device can access data such as power readings. | Due to restrictions in the VE.Bus communication protocol only one device can access data such as power readings. |
