ve_power_setup
VE Power Setup
VE Power Setup is a tool to update firmwares locally and remotely, or to remotely perform VE Configure, in conjunction with VEConfig.
You can read about remote operations possible with VE Power Setup.
You can download it on the software page.
Troubleshooting
Windows XP
VE Power Setup runs on Windows XP, but you may have to perform a few manual steps.
- Because Windows XP is no longer maintained by Microsoft, some installations don't have the proper SSL CA certificates installed, so you may need to install them as outlined by the Global Sign website. Power Setup needs the following:
- If you get a crash right at start up, you need to install the Microsoft Visual C 2008 redistributable.
Discussion
ve_power_setup.1444746815.txt.gz · Last modified: by wiebe
